can someone explain the physics behind this? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 3 Post By telsa
  • 4 Post By HackWork
  • 2 Post By joebanana
  • 1 Post By RePhase277
  • 1 Post By dmxtothemax
  • 2 Post By HackWork
  • 1 Post By wildleg
Old 06-06-2017, 10:26 PM   #1
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 216
Default can someone explain the physics behind this?
Yesterday it was 34 VAC.
Take one standard grounded computer cable.
roll over it a couple of hundred times a day with a chair. (Note the bottom loop from the tie wrap.)
Voila!
Cowboy words of wisdom.
Old 06-06-2017, 10:51 PM   #2
Rewards Points: 26,502
It looks like you ran over the Fluke 23, too.
Double check your leads.
wildleg, mpoulton and LARMGUY like this.
Old 06-06-2017, 10:56 PM   #3
Rewards Points: 1,191
The more it gets run over, the more volts fall out of it?
mpoulton, LARMGUY, telsa and 1 others like this.
Old 06-06-2017, 10:58 PM   #4
LARMGUY's Avatar
Rewards Points: 216
Third set for this old meter.
I replaced the cord and the device works now.
Old 06-07-2017, 12:45 AM   #5
Rewards Points: 7,569
Hey, ya know how to prevent that?
DON'T RUN OVER IT WITH THE CHAIR.
LARMGUY and Mike_kilroy like this.
Old 06-07-2017, 01:04 AM   #6
Rewards Points: 1,361
One conductor or both is broken and the loop is making a really crappy transformer
samgregger is online now   Reply With Quote
Old 06-07-2017, 01:27 AM   #7
LARMGUY's Avatar
Rewards Points: 216
An autopsy proved the hot was cut in two and the neutral was shorting to ground.
Old 06-07-2017, 02:12 AM   #8
Rewards Points: 1,360
The voltage was due to the capacitance of the air gap between the ends of the broken conductor.
mpoulton likes this.
Old 06-07-2017, 04:34 AM   #9
Rewards Points: 1,508
QUOTE - The voltage was due to the capacitance of the air gap between the ends of the broken conductor.
RePhase277 likes this.
Old 06-07-2017, 07:52 AM   #10
I am sticking with the volts falling out.
mpoulton and Mike_kilroy like this.
Moonshot180 (06-07-2017)
Old 06-07-2017, 07:58 AM   #11
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
maybe the cord was only pre charged with 14 volts from the factory. send the whole thing back.
Old 06-07-2017, 10:35 AM   #12
Band Member
emtnut's Avatar
Rewards Points: 1,974
Personally, I'd ditch the physics, and use my wiggy
Old 06-07-2017, 08:08 PM   #13
Watt Pusher
B-Nabs's Avatar
Rewards Points: 472
Better arc fault that circuit
Sent from the unmarked van outside HackWork's house.
can anyone explain how this VFD diagram works? especially the IGBT mike883 General Electrical Discussion 10 05-23-2016 04:43 PM
Do You Ever Have To Explain Basic Electrical Concepts To Customers? Cricket General Electrical Discussion 55 05-21-2016 09:20 PM
can anyone explain why in a 3 phase system, any 2 phase can share a neutral? mike883 General Electrical Discussion 27 05-09-2016 08:46 AM
Explain these renovation ESA fees to me NDC Canadian Electrical Forum 17 03-19-2016 04:42 PM
How Do You Explain an Increase in your Original Estimate? Cricket Business, Marketing, and Sales 40 01-08-2016 10:52 AM
