Carter System? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
Old 01-15-2017, 11:01 PM   #21
Smile Carter System 3-Way Wiring
You can service them all you want. I'll replace them instead.
The knob & tube wiring for the chandelier above the stairway has 1 wire running to the top of the stairs and one wire running to the bottom of the stairs.
Replacement will require getting behind wainscoting, fishing plaster & lath for days. Then you'll never match the texture of the plaster even if done by a pro.
One of the 3-ways is still a push button
Has worked fine since 1890's
Customer obviously has no interest in taking on this project :-)
Problems:
1. Switching neutral not since 1923 allowed
2. 1/2 of the time the shell of the lamp socket is hot
3. Cannot be dimmed
Dayvieboy is offline   Reply With Quote
Old 01-15-2017, 11:49 PM   #22
backstay's Avatar
Rewards Points: 296
8 year old thread.
Old 01-15-2017, 11:54 PM   #23
Rewards Points: 2,232
I do understand why a Carter 3 way is illegal that is a no brainer. The Coast 3 way in a conduit with all of the circuit conductors in 1 conduit I just see the problem with it.
As a matter of fact I use the Coast between the house and the garage because I have different sections of the garage on different switches but all on 1 lighting circuit and a 3 way switch that I can turn some lights on and off from the house.
I just can't see the problem with a conduit install.
LC
Ungrounded system? Ray Cyr Services and Service Equipment 13 10-16-2013 05:59 PM
Three way switching standard, coast, carter 5volts General Electrical Discussion 34 08-01-2010 02:45 PM
isolated ground system shunt trip General Electrical Discussion 1 01-20-2009 08:18 PM
need a better/different lightin system nap Lighting Design 16 03-06-2008 11:36 PM
New lighting system Joe Momma Lighting Design 11 02-14-2007 04:29 PM
