CEC code discuss: for direct buried PVC like this, we have to use table D11A? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 7 Post By PlugsAndLights
  • 1 Post By 51360
  • 3 Post By daveEM
  • 2 Post By 51360
  • 1 Post By Gnome
Old 06-28-2016, 11:27 PM
Rewards Points: 540
Default CEC code discuss: for direct buried PVC like this, we have to use table D11A?
we can't use table 2 or table 4 for calculate the conductor's ampere for this situation, right?
CEC code discuss: for direct buried  PVC like this, we have to use table D11A?-img_4339.jpg
mike883 is offline
Old 06-28-2016, 11:41 PM
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Why do you keep posting CEC questions to the general electrical section?
You know there's a CEC section right?
P&L
PlugsAndLights is offline
Signal1 (07-09-2016)
Old 06-29-2016, 12:30 AM
Rewards Points: 540
P&L
hey, what do you think about my question?
mike883 is offline
Old 06-29-2016, 01:44 AM
Rewards Points: 3,090
I must be missing something. What exactly is the question?
Borgi
electricguy likes this.
51360 is offline
Old 06-29-2016, 09:15 AM
daveEM's Avatar
Rewards Points: 2,382
Post it in the Canadian section. You should learn how to use the site.
Canada is a big place. Maybe narrow it down a bit.
I like perfect.
daveEM is offline
Old 06-29-2016, 07:55 PM
Rewards Points: 540
nobody knows?
mike883 is offline
Old 06-29-2016, 07:57 PM
nobody knows?
All I know is, a three hundred pound dog, is a big dog.
Borgi
electricguy and MechanicalDVR like this.
51360 is offline
Old 06-29-2016, 07:58 PM
Rewards Points: 540
in which situation do we need to use D11A?
nobody knows?
mike883 is offline
Old 06-29-2016, 08:23 PM
nobody knows?
Ok, I'll be more serious.
You have a code book that explains, answers your question. Seems clear to me.
If you are in need of help understanding the table, and Rule 4-004, ask a more specific question, and someone will most certainly help.
Borgi
51360 is offline
Old 06-30-2016, 12:41 AM
Rewards Points: 540
Borgi
here are the my specific question, when should we use this table?
CEC code discuss: for direct buried  PVC like this, we have to use table D11A?-qq-20160629233934.png
mike883 is offline
Old 06-30-2016, 12:47 AM
When your installation requires it.
The code book is your friend!
Borgi
51360 is offline
Old 07-05-2016, 10:53 PM
Rewards Points: 540
up.........................
mike883 is offline
Old 07-06-2016, 02:56 AM
Rewards Points: 763
The intent of the D11 rules is permit higher ampacities by incorporating the large heat conducting capacity of the earth to keep the insulation from being damaged. However those higher ampacities were calculated with certain minimum spacing assumptions and the D11 rules enforce the use of those assumptions. IE: you need a minimum amount of earth around your conduit/cable for the earth to be able to absorb the heat and carry it away.
So you can't use D11 unless your conduit spacing matches or exceeds the spacing shown on the associated diagram for the specific sub table. That big pile of conduits isn't going to match anything in that section.
Which means you have to fall back on 4-004(1) or (2) modified by by other 4-004 sub-rules (and 8-104 if it applies) as needed.
LuckyLuke likes this.
Gnome is offline
Old 07-06-2016, 04:54 AM
Rewards Points: 3,006
Good answer, makes sense.
MechanicalDVR is offline
Old 07-06-2016, 06:17 PM
Rewards Points: 540
thanks,
everybody please add your comments
mike883 is offline
Old 07-09-2016, 12:02 AM
Rewards Points: 540
up................................................
mike883 is offline
code question: is ENT inside the concrete slab considered direct buried in a raceway? mike883 General Electrical Discussion 20 06-30-2016 12:30 AM
