Ceiling fan capacitor - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 1 Post By cabletie
  • 1 Post By electricmaster
  • 1 Post By KnightPower
  • 1 Post By Joe Robert
  • 1 Post By cuba_pete
  • 1 Post By glen1971
  • 2 Post By 99cents
  • 5 Post By cabletie
  • 1 Post By 99cents
  • 1 Post By wildleg
  • 1 Post By splatz
  • 1 Post By gpop
Old 07-05-2018, 12:06 AM   #1
cabletie's Avatar
Rewards Points: 1,274
Default Ceiling fan capacitor
Has anyone had any luck fixing a ceiling fan by replacing the capacitor?
I have a ceiling fan in our computer room/home office. One day I noticed it was making a louder than usual hum, and spinning on low speed. I tried putting it on high from the wall fan speed control, but it didn't change the speed, and still hums. The fan is kind of futuristic and has no pull chains to change speed.
I took out the combination light dimmer/speed controller from the wall, and removed the matching remote from under the canopy. I wired the fan straight though. Still only low speed with a louder than normal hum. Looking at the wiring I noticed a rectangular box 5uf capacitor that looked impregnated. It looked like it was in its third trimester.
I know I should call an electrician and this is not a DIY site, but has anyone ever replaced one of these. I went online and sure enough there is a market for these things. I ordered one, and it should be in in a few days.
They didn't have any at the Home Depot, and every guy I asked said they weren't an electrician.
Any thoughts?
Old 07-05-2018, 12:17 AM   #2
electricmaster's Avatar
Rewards Points: 12
Call a electrician
Sent from my SM-G965W using Tapatalk
electricmaster is offline   Reply With Quote
The Following User Says Thank You to electricmaster For This Useful Post:
cabletie (07-05-2018)
Old 07-05-2018, 12:36 AM   #3
Magic Smoke Remover
Rewards Points: 1,966
Ibtl
Old 07-05-2018, 12:42 AM   #4
I have fixed a couple of fans with replacing the capicator.. But for a new one I've had to order from Amazon. Anytime I take out a ceiling fan I usually gut it for the pull switches and capicators. Now I have a few motors, switches and capicators laying on the shelf.
Sent from my SM-G930V using Tapatalk
KnightPower is offline   Reply With Quote
Old 07-05-2018, 01:32 AM   #5
Joe Robert's Avatar
Rewards Points: 20
Seeing a bubbled capacitor always made me happy, knew it was going to be an easy fix! Assuming you donít have a meter that tests capacitance, seeing a bubble is the easiest way to tell if a capacitor has gone bad (though sometimes a bad cap wonít be bubbled).
Replacing that one will almost certainly solve your problem. And fyi, any hvac supply or electric motor store will have a wide range of caps in abundance.
Joe Robert is offline   Reply With Quote
Old 07-05-2018, 02:12 AM   #6
cuba_pete's Avatar
Rewards Points: 2,963
Ibtl
Troll in Training
Old 07-05-2018, 09:04 AM   #7
Rewards Points: 3,980
Call an electrician.. If they can't troubleshoot a ceiling fan or a capacitor, call a real one...
Old 07-05-2018, 09:31 AM   #8
Rewards Points: 14,015
You're going to lock a guy who has been here seven years and has 1472 posts? Brutal.
I don't have any advice. If it was a customer, I would tell him to go to HD and buy a new one (except I go into hiding whenever a ceiling fan is mentioned).
samgregger and tmessner like this.
Old 07-05-2018, 10:09 AM   #9
cabletie's Avatar
Thanks for all the input.
I called a local electronic place near me before I ordered it online. I can't believe no one around here has one. I would just replace the fan, but the wife always liked this one.
I don't have a tester for capacitance anymore. I didn't feel like cutting it out and seeing if it takes a charge on the resistance scale, and then reversing the meter. I know that's a half assed test.
I don't think I've ever heard any one fixing a ceiling fan before. Makes sense to cut out the working parts of old ones. I used to do stuff like that when I did service work type of stuff.
Thanks again! Maybe if the fan does need to be replaced, I'll call Angie's list. Then grab a chair and tell the guy how to do his job
wildleg, 99cents, daveEM and 2 others like this.
Old 07-05-2018, 10:46 AM   #10
daveEM's Avatar
Rewards Points: 2,382
You must have heard me giving advice to some apprentice years ago. I tell em to find a handyperson after they buy the fan.
I like perfect.
Old 07-05-2018, 10:50 AM   #11
I would rather do heat trace on the coldest day of winter than hang a ceiling fan .
tmessner likes this.
Old 07-05-2018, 10:56 AM   #12
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I enjoy occasionally repairing appliances (for myself or family only) for cheap just to get the bonus life out of them. I think I replaced just about every part on my washing machine at my last house, some x3; that thing was a tank and I stretched it to 25 yrs or so.
last xmas when i was up in NY, my wife's niece was getting ready to buy a new fridge cause the "appliance guy" wanted 600 bucks to fix the ice maker in their almost new one. sheesh. ten dollar solenoid that I had to pay 75 over the counter for.
good luck with the clg fan.
Old 07-05-2018, 12:41 PM   #13
Rewards Points: 1,130
Even though most of this crap is made to be disposable any more, I'll fix it sometimes because besides the cost savings sometimes it's easier to replace in place than the full rip out and replace.
Max C. likes this.
Old 07-05-2018, 02:36 PM   #14
Rewards Points: 1,760
Im more than willing to waste a day to fix something then once its fixed im more than willing to trash it and buy a new one. I think i have a mental problem where i just need to know why its broken.
Old 07-05-2018, 02:50 PM   #15
Rewards Points: 648
Am I truly one of the only "fantricians" around here Seriously though, Lowes has a tendency to carry quite a few replacement fan parts, as with most lighting showrooms...
Max C. is offline   Reply With Quote
Capacitor issue Shane8820 PLCs, VFDs, Motors and Controls 7 10-03-2017 07:13 PM
Who should install ceiling medallions? Canaduh Residential Electrical Forum 37 03-29-2017 06:04 AM
Drop ceiling? wiring Peter Goldwing NEC Code Forum 18 02-11-2017 07:19 PM
Capacitor bank Ryan6864 Services and Service Equipment 10 02-21-2016 02:01 AM
Difference Between Single and Dual Capacitor Ceiling Fan swimmer Residential Electrical Forum 6 01-08-2016 11:42 AM
