Ceiling Fans - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 4 Post By readydave8
  • 1 Post By Signal1
Old 05-30-2019, 06:52 PM   #1
Rewards Points: 8
Default Ceiling Fans
Hello,
I work on old coast guard dwelling units. Once in a while I run into a specific problem with the ceiling fans. All four ceiling fans make a humming sound. I replace the fans for new ones and all four keep making the same sound. After verifying the main grounded conductor and the grounding conductor and finding no voltage drop or unbalance, I still can not find or fix the problem. I wonder if anybody have an idea of what could be the problem. Thanks.
carloslt is offline   Reply With Quote
Old 05-30-2019, 09:48 PM   #2
DashDingo's Avatar
Rewards Points: 22
Did you replace them with the same model? Or totally different fans?
DashDingo is offline   Reply With Quote
Old 05-30-2019, 10:14 PM   #3
neutral member
readydave8's Avatar
Rewards Points: 138
standard or no wall switch, not controlled by speed controls?
Dave Ruth
Old 05-30-2019, 11:27 PM   #4
Rewards Points: 250
Welcome to the forum Carlo.
I have not installed many ceiling fans. Especially the new ones today. I'm sure there will be some help ahead.
Old 05-31-2019, 09:55 AM   #5
canbug's Avatar
Rewards Points: 1,876
I'm going to say, cheap fans hum at lower speeds. I haven't installed expensive ones so not sure about them?
Just my 2 cents.
Tim.
canbug is online now   Reply With Quote
Old 05-31-2019, 11:05 AM   #6
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,366
I've had speed controls cause this. Sometime very loud and obnoxious humming.
macmikeman likes this.
Old 05-31-2019, 12:44 PM   #7
Rewards Points: 18,279
Speed controls.
Maybe using one of Telsa's ferrite coils would fix that?
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 06-01-2019, 08:38 PM   #8
Rewards Points: 8
Yes. Not only that. I have had installed more than 25 of the same fans. They do not make the noise on all houses, just on a couple of them. On the other houses work just fine. I start to think that could be harmonics or some other problem coming from the transformer side. "That is just a speculation."
Old 06-01-2019, 10:56 PM   #9
Rewards Points: 250
You sure its not vibration? I installed a fan in my office. As soon as I turned it on you could hear it. Vibration. Little insulation in that area. Was a carport once.
I just took it down and to this very day, there is a round white blank up there......LOL
Old 06-02-2019, 07:09 PM   #10
Rewards Points: 8
Have you been close to a homing step down transformer. That is the humming I am talking about.
Old 06-02-2019, 07:12 PM   #11
MikeFL's Avatar
Rewards Points: 626
How is the power quality out there in PR?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 06-02-2019, 07:23 PM   #12
Rewards Points: 8
If you mean. voltage values: 248/124volt all over the base. But, that does not explains, three fans on one house are noisy and 6 fans "the same" make no noise on many other houses.
Old 06-02-2019, 08:02 PM   #13
MikeFL's Avatar
Rewards Points: 626
I just found this on a simple search "power quality in puerto rico".
When motors do what we don't expect and replacing the motor with a brand new motor results in the same thing, we look beyond the motor. That's the only reason I asked.
https://ieeexplore.ieee.org/document/1338511
GPS Timers
(833) GPS-TIME
