Central Vac Inlet - Electrician Talk - Professional Electrical Contractors Forum
Old 01-13-2013, 04:10 PM   #1
Rewards Points: 562
Default Central Vac Inlet
Anyone install or see a problem with installing a central vac inlet into the floor instead of the wall? I don't do too much central vac but a customer has asked if we could install a new inlet for there sunroom. No way of getting it into the wall.
CanadianSparky is offline   Reply With Quote
Old 01-13-2013, 04:14 PM   #2
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
You may need to ask the MFG this question... The cover may not be rated to be installed in the floor.
Old 01-13-2013, 04:15 PM   #3
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Other than getting a metal one vs plastic no big deal.
http://www.centralvacuumstores.com/I...unt-Chrome.php
Life is hard
The Following User Says Thank You to electricmanscott For This Useful Post:
CanadianSparky (01-13-2013)
Old 01-13-2013, 04:18 PM   #4
Ambassador of Amps
TOOL_5150's Avatar
looks like this would work with the floor adapter, but it also states this:
This non-electric inlet will work with most hoses.
So, it depends on your system.
Old 01-13-2013, 04:19 PM   #5
drspec's Avatar
Rewards Points: 1,120
I always install in the wall but have seen a lot of poorly done retrofit installs with the vacuum jacks in the floor.
It will work but wouldn't be my first choice.
Old 01-13-2013, 04:20 PM   #6
BBQ
Salty Member
BBQ's Avatar
It will still suck.
The Following 4 Users Say Thank You to BBQ For This Useful Post:
CanadianSparky (01-13-2013), CraigV (01-14-2013), guest (03-05-2013), Wirenuting (01-13-2013)
Old 01-13-2013, 04:49 PM   #7
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,592
Behind a door in the corner is about the best spot. Less traffic on it.
Old 01-13-2013, 05:09 PM   #8
Vintage Sounds's Avatar
Rewards Points: 4,004
I've seen this done on commercial central vac systems a bunch of times. They usually used a heavy duty round brass floor inlet.
Old 01-13-2013, 07:34 PM   #9
Rest In Peace
aftershockews's Avatar
Rewards Points: 7,003
Every house I have done remodel in that has a central vac system, it was removed. They just don't do as good the further the outlet is away from the motor.
aftershockews is offline   Reply With Quote
Old 01-13-2013, 07:39 PM   #10
drspec's Avatar
Every house that I have done a remodel in that has a central vac system, we added more inlets in the additions. The vacuum systems have come a long way. But the ones that performed poorly were mostly due to poor installs.
I've repaired a couple of piping systems that I added on to and the HO said it had never worked that good.
Old 01-13-2013, 07:47 PM   #11
Rest In Peace
Good reviews in your area, bad reviews in mine. Odd.
Old 01-13-2013, 09:32 PM   #12
Rewards Points: 21,898
The items I hate the most with central vac's is sharp 90 bends or ells they are one are most common curpits.
I used wide sweep ells that useally take care of the issue.
That I useally don't do often but one house I have to redo all the pipework due too many sharp 90's and elemated few of them by rerouteing them and put in a high perfomace unit that did have twice of power of the old one and my customer say it work heckva better then the old one and big plus it much quiter as well.
Merci,
Marc
Old 01-14-2013, 08:16 AM   #13
Retired Account
Rewards Points: 14,650
powered vs. non-powered....? ~CS~
Old 01-14-2013, 08:56 AM   #14
Rewards Points: 154
I did not install it, but one of my customers has inlets that the hose, with a sock on it, retracts right into the wall. The plate is about 5"x9." If I can find one I'm going to put it in my own home. I've also (mistakenly) promised my wife one of those toe kick inlets... maybe should would keep the kitchen clean, but I don't really feel like going into my own crawl space.
Article 90.1 is offline   Reply With Quote
Old 01-14-2013, 12:29 PM   #15
Jesus Scott
Rewards Points: 232
I installed a system in my house. It works great.
Life is hard
Old 01-14-2013, 01:13 PM   #16
Rewards Points: 250
We just installed one a couple years ago and it works great. If the inlet has electrical it might be a problem for floor installation.
Jbird66 is offline   Reply With Quote
Old 01-14-2013, 01:37 PM   #17
Rewards Points: 5,198
There is a unit that can be installed into the bottom skirt under the sink to vacuum,say, the kitchen floor into it. If wanted, a floor opening can be done.
I answered before reading the other posts. I could have just said "DITTO".
Old 03-05-2013, 06:14 AM   #18
Southeast Power's Avatar
Rewards Points: 9,244
I'm getting ready to install a central vac system in my own house.
And tips from veteran installers?
Marc mentioned the short 90s but I can't see how to avoid them when installing wall outlets.
I do have a couple of places where the walls come together as a tee, I could lay it out to fall in those spaces.
Do I really need to cut the pipe with a pipe cutter or do you guys use a hacksaw?
House is slab on grade but attic is 5' to 7' where I will be working.
All suggestions are welcome.
Old 03-05-2013, 06:23 AM   #19
nick.pei's Avatar
Rewards Points: 150
Here's my setup
How you do things today, will be your reputation tomorrow.
nick.pei is offline   Reply With Quote
Old 03-05-2013, 09:49 AM   #20
Rewards Points: 508
Don't put T directly above inlet, you don't want to fight gravity.
Wireless is offline   Reply With Quote
50A inlet boxes? 3xdad General Electrical Discussion 3 11-05-2012 02:27 PM
Generator inlet MDShunk General Electrical Discussion 16 07-31-2012 08:19 PM
50A flanged inlet 3xdad General Electrical Discussion 7 03-22-2012 11:22 PM
PB 30 Inlet boxes electricmanscott General Electrical Discussion 40 11-11-2011 09:05 AM
Direct connecting portable generator instead of using inlet? RobTownfold64 NEC Code Forum 9 03-22-2011 06:28 PM
