Change over - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 11-16-2013, 10:34 PM   #21
BBQ
Salty Member
BBQ's Avatar
We could get failed for lack of fittings on the end of the PVC.
We use these
denny3992 (11-16-2013)
Old 11-16-2013, 10:42 PM   #22
We use these
That's the first thing I noticed, no bell ends. I could understand why, they ain't cheap. I just paid $5 each for 2". Supply house fu*kers are robbing us blind.
DIYer4Life is offline   Reply With Quote
Old 11-16-2013, 10:45 PM   #23
Bkessler's Avatar
Rewards Points: 2,002
We could get failed for lack of fittings on the end of the PVC. We use these
A lot of hacks out here. We only use bell ends on vaults.
When ls lunch?
Old 11-16-2013, 10:58 PM   #24
Cow
Rewards Points: 5,118
It sounds like you get $hitty pricing for a contractor. The cash price from Platt is $3.53.
https://www.platt.com/platt-electric...spx?zpid=69188
Old 11-16-2013, 10:59 PM   #25
Rewards Points: 3,358
Originally Posted by Bkessler View Post
Again he says this is a special order transformer. No one on his crew has ever seen this set up before.
If the new transformer is a pad-mount, then indeed it is a special order.
Here's why I believe the existing service is a 120/240 3 4 wire ∆ with a high leg;
1) If it's the pole-mount transformers in the background, the center one is larger than the other two. This is very common for 240 4 wire ∆ systems. The larger pot is the two 120 legs, and they are usually loaded more than the high leg. The way the 4 wires come down from the pots is further indication of a ∆ system.
2) The CTs. With a 3 wye, each phase needs to have its own CT. With a 4 wire ∆ system, the two 120 legs can use one CT, but they need to run in opposite directions. The high leg needs its own CT.
Is the transformer for the new underground feed a pad-mount?
Old 11-16-2013, 11:00 PM   #26
Cow
You can see it in the first picture.
Old 11-16-2013, 11:30 PM   #27
Bkessler's Avatar
Pole mount transformers are gone.
Here's a pic of the new one only ID tag.
When ls lunch?
Old 11-16-2013, 11:33 PM   #28
MTW
Rewards Points: 11,454
Yep, that's one oddball transformer. I bet that cost a pretty penny.
Old 11-16-2013, 11:40 PM   #29
Bkessler's Avatar
It's hum did sound nice.....
When ls lunch?
Old 11-16-2013, 11:43 PM   #30
MTW
The poco better hope it never gives up the ghost because I doubt they have one sitting at the shop.
Old 11-16-2013, 11:56 PM   #31
Bkessler's Avatar
And if you look close at the first picture there was a second single phase 240 feed from the 50's entering the building as well that was for a single 150 amp X-Ray machine that had its own meter main.
When ls lunch?
Old 11-17-2013, 12:07 AM   #32
Yep, that's a special order allright!
The full-load current of that transformer is 1202 amps, and the short-circuit current is 30,050.
Old 11-17-2013, 12:12 AM   #33
Bkessler's Avatar
Yep, that's a special order allright! The full-load current of that transformer is 1202 amps, and the short-circuit current is 30,050.
I'm the instally person. All my knowledge on transformers would fit in the end of a 1/4" nut driver.
When ls lunch?
The Following User Says Thank You to Bkessler For This Useful Post:
220/221 (11-17-2013)
Old 11-17-2013, 12:49 AM   #34
Sometimes it pays to know a bit about things like transformers.
Using your installation as an example, I'd bet a lot that the panels in the building have breakers rated at 10,000 AIC (Amps Interrupting Current). I'd also bet a lot that there are more than 10,000 amps of available fault current at said panels.
What this translates into is that if one of those breakers is closed in to a bolted fault (dead short) there's a fair chance that it would explode.
Of course, engineers, contractors, owners, the POCO doesn't like to hear stuff like this.......lol.
Old 11-17-2013, 01:08 AM   #35
220/221's Avatar
Rewards Points: 4,274
Instally person....I like it.
Hey, someone has to pull the plow. Welcome to the club.
The Following 2 Users Say Thank You to 220/221 For This Useful Post:
Bkessler (11-17-2013), micromind (11-17-2013)
Old 11-17-2013, 01:31 AM   #36
Rewards Points: 250
Had a service to a building in southern IN. It was 120/240 delta. They used a single phase pad mount for the 120/240 and a second pad mount for the wild leg. Must have been open delta. Its all gone now and A 277/480 service from the POCO and A 480 to 120/208 step down transformer inside for the old system.
RandyM is offline   Reply With Quote
Old 11-17-2013, 11:51 AM   #37
Tool Fetish
Originally Posted by dronai View Post
If the plant is a 3 phase delta service with no neutral, is the high leg still required to be orange ? Working at one now with no marking.
There is NO high leg if there is NO neutral. If you are reading a high leg to ground then the transfomer has a center tap for the neutral. In a old service the neutral might not have been run to the building.The POCO might have connected a ground or the overhead messenger to the neutral point and you are reading it as a neutral. The NEC now requires the neutral, if there is one, to at least be brought to your service disconnect. If there is no neutral tap on the transformer(s) you shouldn't be reading any true voltage to ground, unless one phase leg is grounded. That's another story.
SteveBayshore is offline   Reply With Quote
Name Change brian john Business, Marketing, and Sales 11 11-11-2011 11:33 AM
oil change paul d. Tools, Equipment and New Products 37 01-30-2010 12:39 AM
