Changing the RPMs on a 1.2AMP, 120V, 1 phaze 60HZ Motor - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 04-10-2018, 01:06 PM   #1
Default Changing the RPMs on a 1.2AMP, 120V, 1 phaze 60HZ Motor
Hi looking for some guidance. I am a cabinet maker, woodworker, I am currently designing a small wood moving art project. I have an old King Scroll Saw and would like to use the variable speed motor in this project. Dilemma I have is the controls for the motor have it's slowest speed at 550rpm up to something like 1450rpm. I would like to if possible change the numbers, by that I mean, my slowest speed becomes 0 and as I turn the dial the rpms increase, do not need it anywhere near 1450rpms, so it doesn't really matters here it tops out at, just won't turn the dial that high. Is this possible, and or what might I need to alter the start up speed to zero.
Dusty is offline
Old 04-10-2018, 01:13 PM   #2
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,624
To alter the speed to ZERO, you need to use the OFF/ON switch.
The rest should work with he variable speed controller attached to the unit.
I doubt a scroll saw would last long at a near zero start up speed. You will be breaking blades quickly.
Wirenuting is offline
Old 04-10-2018, 01:15 PM   #3
Rewards Points: 256
Thanks for posting on ElectricianTalk.com.
However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
John Valdes is offline
The Following User Says Thank You to John Valdes For This Useful Post:
The_Modifier (04-10-2018)
Closed Thread
How long and what size of wire for a 1HP 110v 1 phase 60HZ motor? 111jag General Electrical Discussion 28 03-21-2018 09:08 PM
Changing a Baldor motor from 240 to 480 HobeComp General Electrical Discussion 12 03-13-2018 10:21 AM
Ammonia compressor motor MadDawg PLCs, VFDs, Motors and Controls 16 01-18-2018 03:44 PM
460V motor on 400V 60HZ? mikey383 PLCs, VFDs, Motors and Controls 6 07-25-2016 05:00 PM
Motor Rotation Changing CheapCharlie PLCs, VFDs, Motors and Controls 5 02-10-2016 12:56 AM
