Charging faults on EV - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 01-29-2017, 04:55 PM   #21
Can't Remember
Rewards Points: 1,532
I think one things for sure, these will expose any weakness in your connections all the way back to the meter. If I was doing new construction from the ground up, I might even consider bolt in circuit breakers.
Old 01-29-2017, 05:02 PM   #22
Liberal Lesbian
Rewards Points: 152
What is this about Tesla's having their own built in charger? What happens when you connect it to a charging station?
Old 01-29-2017, 06:18 PM   #23
Switched's Avatar
Rewards Points: 10,416
The software in the car adjusts to whatever you are connected to.
Old 01-29-2017, 06:28 PM   #24
Liberal Lesbian
Rewards Points: 152
So you can connect a car charger to a Tesla, or just a 50A feed?
Old 01-29-2017, 06:43 PM   #25
Switched's Avatar
Yes, you can connect to just about anything with those cars.
The Following User Says Thank You to Switched For This Useful Post:
HackWork (01-29-2017)
Old 01-29-2017, 08:00 PM   #26
Rewards Points: 12
Yes, I've seen everything from 120v,13A to 400v, 85A at the Tesla superchargers. Apparently the new superchargers put out 135kW. My car can take a 120kW charge. Charge tapers off as it nears capacity.
Brhodgins is offline   Reply With Quote
Old 01-29-2017, 08:14 PM   #27
Can't Remember
They are fun to drive.
Old 02-04-2017, 10:55 PM   #28
Rewards Points: 12
Default Thanks everyone for your reply.
So I finally found out what the problem was and why a "proximity fault" sounded odd...
The car was in for service, yesterday for regular maintenance, brake maintenance etc, and the techs looked onto the logs in more detail. Removing the Telsa's internal charging system, they found the "proximity harness" had corrosion on the contacts, so they replaced the whole thing.
Curious how the system wouldn't be sealed better. Maybe that's a improvement that will happen in later models.
B
The Following User Says Thank You to Brhodgins For This Useful Post:
backstay (02-04-2017)
Old 02-05-2017, 06:23 AM   #29
MikeFL's Avatar
Rewards Points: 916
Thanks for coming back with the update. That's a rare treat on forums. Now anyone searching for your trouble code can find the thread with a solution.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 02-05-2017, 02:44 PM   #30
nbb
Rewards Points: 516
At 400v supercharger stations the AC to DC conversion is done off the car, behind those fences. All the other voltages, the on board charger does the rectifying to DC.
To move the car, the DC from the battery is inverted back to AC and sent through a freq drive to 1 or 2 induction motors. More elegant than the permanent magnet DC motors on other electric cars, IMHO.
nbb is offline   Reply With Quote
Ground faults on old, unbonded resi wiring? 99cents Residential Electrical Forum 6 12-31-2016 08:14 AM
vfd fault issues garfield PLCs, VFDs, Motors and Controls 13 11-03-2016 04:13 PM
Charging Lithium Ion Batteries splatz Tools, Equipment and New Products 13 10-07-2016 06:09 PM
Arc faults in College Anathera NEC Code Forum 17 02-17-2016 06:26 PM
New Blackberry Priv phone charging polyguru Residential Electrical Forum 1 01-10-2016 12:04 PM
