check this beauty out: - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-27-2015, 08:04 PM   #41
Rewards Points: 121
Originally Posted by knomore View Post
If there is flexible stainless gas lines in the home you need to bond the gas line here in Iowa. You might want to see if that is the reason next time you go cutting stuff. Personally if you did that in my house you would be getting called back to fix it.
yep, our AHJ in Cheyenne WY has us BOND gas piping with sections of flexible gas line.
ibew415 is offline   Reply With Quote
Old 01-27-2015, 08:20 PM   #42
Rewards Points: 60
Is his name Jon Vosters?
Old 01-27-2015, 08:51 PM   #43
Galt's Avatar
Rewards Points: 1,187
The lp gas suppliers here have started putting dielectric unions at the house just after the copper underground pipe. To me this creates a lightning hazard.
Galt is offline   Reply With Quote
Old 01-27-2015, 09:05 PM   #44
Rewards Points: 60
They have to do that because they don't want us using their gas pipe as an electrode- that is dangerous. The nec forbids using the gas pipe as an electrode.
Old 01-27-2015, 09:52 PM   #45
Big Pickles's Avatar
Are you saying you used the gas pipe for your grounding electrode, since the water lines were all plastic?
no, 2 ground rods, have to bond gas pipe in certain cities here, usually we do hot/cold/gas @ water tank. Some houses have all pex.
Big Pickles is offline   Reply With Quote
Old 01-27-2015, 09:53 PM   #46
Originally Posted by mcclary's electrical View Post
Water lines have nothing to do with bonding a gas line.
Usally tri bond @ water tank, cant do that with pex.
The Following User Says Thank You to Big Pickles For This Useful Post:
BuzzKill (01-28-2015)
Old 01-28-2015, 06:26 PM   #47
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
This seems ludicrous: can't use the pipe as an electrode but sure as hell as when it enters a residence you need to bond it (with the option to the service N/G or a grounding electrode) and thus making it practically an electrode itself.
I was misunderstood saying that I terminated the gas bond to the sub; I terminated the #6 into the sub and abandoned the gas bond. When I get back there I will probably hook it back up, reluctantly, but suppose there is no corrugated tubing present for the gas feed? It looked to be straight piped to me.
The following is the ASGE gas code and bonding is 7.13.2.....I've never had an inspector worry aout gas pipe bonding and it is confusing.
http://www.asge-national.org/Content...2011_Cabot.pdf
I'd rather be sleeping.
Its a beauty Oakey Code Violation Discussion 5 12-16-2014 07:41 PM
ulta beauty flashover General Electrical Discussion 10 07-14-2013 01:14 PM
What a beauty hydro Services and Service Equipment 19 03-04-2013 12:00 PM
Little beauty frank Off Topic (Non Trade) 3 07-20-2010 01:32 PM
Found this beauty... running dummy Code Violation Discussion 30 06-22-2009 03:17 PM
