Circuit Mapper - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree66Likes
Old 12-01-2017, 08:37 PM   #41
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
Short people got..no body...short people got ...no reason...
Old 12-01-2017, 08:40 PM   #42
Rewards Points: 3,057
If I'm working for a GC, I tell him I will need a monkey for half an hour. If I am working for an HO, I will ask him if he is interested in helping. Takes no time with two people on cell phones.
Old 12-01-2017, 08:46 PM   #43
lighterup's Avatar
I write it on the NM cable when I drop the homeruns in front of the
panel...don't need the monkey , GC or the midgets
The Following User Says Thank You to lighterup For This Useful Post:
Dan the electricman (12-02-2017)
Old 12-01-2017, 09:13 PM   #44
Rewards Points: 3,096
Tasco usually deducts a 100.00 from their products, I have bought the inspector and the circuit tracer both at a 100.00 discount
The Following User Says Thank You to electricguy For This Useful Post:
telsa (12-02-2017)
Old 12-01-2017, 10:12 PM   #45
Rewards Points: 3,568
I use to use 3 different tone bells and a bright light on an extension cord, This was in the 70's, sped things up for a one-man service change.
Old 12-01-2017, 11:46 PM   #46
Rewards Points: 578
I'm talking about during a panel change on an old house.
Old 12-02-2017, 03:51 AM   #47
Rewards Points: 26,920
Originally Posted by Chris1971 View Post
I love mine.
Chris1971 (12-02-2017)
Old 12-02-2017, 03:53 AM   #48
I've done two panel changes in the past month and I didn't label all the circuits. My boss said it wasn't in the budget, so I didn't do it.
The NEC does not say that you have label things perfectly.
'Receptacles and Lights' covers a lot of ground.
electricguy likes this.
Old 12-02-2017, 06:28 AM   #49
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
This thread is dildos.
Old 12-02-2017, 08:30 AM   #50
Rewards Points: 578
Why do you make me disagree with you??? I think you do it on purpose.
408.4 Field Identification Required.
(A) Circuit Directory or Circuit Identification. Every
circuit and circuit modification shall be legibly identified as
to its clear, evident, and specific purpose or use. The identification
shall include an approved degree of detail that
allows each circuit to be distinguished from all others.
Spare positions that contain unused overcurrent devices or
switches shall be described accordingly. The identification
shall be included in a circuit directory that is located on the
face or inside of the panel door in the case of a panelboard
and at each switch or circuit breaker in a switchboard or
switchgear. No circuit shall be described in a manner that
depends on transient conditions of occupancy.
The code is very clear, labelling 25 circuits "Receptacles and Lights" will NOT work. You have to provide better detail as to where those receptacles and lights are in order to be able to distinguish them from all the others.
Old 12-02-2017, 08:37 AM   #51
Since when did you get OCD over code, Hacksy?
Use a jobsite radio with the volume on max.
Old 12-02-2017, 08:40 AM   #52
Rewards Points: 578
Jesus, OCD?
Did you not read any of the thread in which we discussed how this is a code requirement that the inspector is going to want to see? I just want to pass inspection, and labelling every circuit "Receptacles and Lights" would fail.
Again, we discussed this. At the very minimum that would be an average of 25 trips up and down 1-2 stories. A waste of time and energy, especially for a lazy person.
Old 12-02-2017, 08:47 AM   #53
lighterup's Avatar
Jesus, OCD?
The panel stickers don't have very much room on them , so I
made a record of what was what , took it home and typed it
up on a piece of paper , went back to the job and taped it to
the backside of the door and guess what happened.
The fricking inspector said I was not allowed to cover the door!
Now that s**t made me mad!
Old 12-02-2017, 08:55 AM   #54
Rewards Points: 578
Too many idiot inspectors out there. Yu went above and beyond and they still look for something to bitch about.
Old 12-02-2017, 09:02 AM   #55
lighterup's Avatar
Not to derail this thread , but between inconsistencies in inspection
departments and afci's , I have been very close to leaving this trade
numerous times.
Also inconsistencies in code instructors as well.
NDC likes this.
Old 12-02-2017, 09:02 AM   #56
Inspector arrives. I tell him I'm all done, just working on the panel directory. He gives me green sticker and leaves. I fill in the blanks with "Plugs and Lights".
The_Modifier and NDC like this.
Old 12-02-2017, 09:15 AM   #57
Rewards Points: 578
I really don't care what you do, since you are just trying to find ways to say that the device we want is unnecessary.
I don't have time to go back to a job and wait 3-6 hours for an inspector on every panel change that I do. There is no reason for me to be there.
BTW, calling receptacles "plugs" is what homeowners and handimen do.
Old 12-02-2017, 09:19 AM   #58
"Receptacles" is too long a word to fit on a panel sched.
Old 12-02-2017, 09:27 AM   #59
Rewards Points: 578
How about Outlet or RCPT like real electrician write?
brian john and PokeySmokey like this.
Old 12-02-2017, 09:47 AM   #60
A panel change is a 1 man job, except for the stupid part in which it needs to be labeled (screw you CMP!!!). The houses here all have the panels in the basement and 2 floors above so running back and forth isn't an option.
So I am exploring the circuit mapper options again.
Does anyone use one? Does it really work?
Based on this thread I just bought one I'll let you know how it works out.
Circuit Mapper HackWork Tools, Equipment and New Products 28 11-06-2019 06:22 PM
Points per circuit (LED's) meggerman Canadian Electrical Forum 36 08-23-2016 07:27 PM
New sump pump receptacle on an old circuit. Mugs Canadian Electrical Forum 14 07-30-2016 10:30 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
Combining circuit types in a conduit dkone NEC Code Forum 15 05-20-2016 06:08 PM
