CNC mill getting low voltage warning..... - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-09-2015, 08:58 AM   #21
Rewards Points: 3,078
Originally Posted by Jonl View Post
Wow, I appreciate all the responses, thanks guys. I will check it out tomorrow using all of your recommendations. Btw, I zoomed in on the name plate and says 220v.
Did you read the owner's manual in the link I posted?
Greg
Old 02-09-2015, 09:32 AM   #22
Rewards Points: 67
Sure did, thanks.
Jonl is offline   Reply With Quote
Old 02-09-2015, 09:45 AM   #23
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Originally Posted by dronai View Post
I can't see 240V on the nameplate ? McClary see's it somewhere, or is he assuming it wouldn't give a low voltage indicator if it was only 208V ?
It says 220 on the nameplate but we all know that is nominal voltage. I would buck boost this machine to 240 volts.
Old 02-09-2015, 10:18 AM   #24
Rewards Points: 14,714
I would check the motor rating and if it was 220, I think I would boost it to the mid 220s (like 225), maybe up to 230. I would also check into why the voltage was dropping to 200 with a not heavy load.
Old 02-09-2015, 10:22 AM   #25
al_smelter's Avatar
Rewards Points: 528
Regardless whether you finally get 208 out of the feeder or not, you are probably still on the low end for this machine. I have a small hobby machine shop with foreign made drives; most machines in the class you are working on are from either China, India, or Taiwan (there are very few US made machines, and they are made with foreign drives and the like anyway). I am not debating overseas design or workmanship here, but it is known that a lot of these machines like to run on the mid to high end of their nameplate.
When a foreign nameplate asks for "220 volts", that is commonly what they really want/need to function properly. Look on a few professional machinist sites, and you will see what I mean. This comes up frequently, especially around 208 three phase installs.
There are a lot of things happening at the same time on a competent CNC machine. Commonly all three servomotors (three drives) are active at the same time, along with the spindle motor (another drive) and computer controls.
I would suggest that Mr. McClary has the right idea, even when you find all 208 volts. It will probably make the machine happier, and it'll surly make the machine owner happier. Consider buck and boost.
Mark
al_smelter is offline   Reply With Quote
The Following 4 Users Say Thank You to al_smelter For This Useful Post:
8V71 (02-09-2015), hardworkingstiff (02-09-2015), mcclary's electrical (02-09-2015), samgregger (02-09-2015)
Low voltage and medium voltage devices sharing same enclusure AFE NEC Code Forum 12 05-20-2012 12:25 PM
minimum depth of burried low voltage and high voltage canada lortech NEC Code Forum 4 05-11-2012 09:05 PM
Low voltage or line voltage landscape lighting raider1 General Electrical Discussion 14 07-30-2011 07:10 AM
Typical low voltage guy asking high voltage question. LARMGUY General Electrical Discussion 13 09-02-2010 01:59 AM
Working with high voltage (warning, graphic) FAST LS1 General Electrical Discussion 39 05-24-2008 09:35 AM
