Code compliant? - Electrician Talk - Professional Electrical Contractors Forum
Old 09-10-2015, 03:37 PM   #1
Rewards Points: 123
Default Code compliant?
320 amp meter feeding two 200 amp panels. Would it be a violation to have a properly installed 200 amp automatic transfer switch and generator connected to only one of the panels?
Have a home inspector saying it is a violation.
brichter is offline   Reply With Quote
Old 09-10-2015, 03:39 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Ask the HI for a Code reference. That should shut 'im up.
Old 09-10-2015, 03:40 PM   #3
Very Long Vacation
Rewards Points: 5,262
Good read on the subject here:
http://www.inspectionnews.net/home_i...0a-panels.html
There would be no code violation just feeding one of the panels with back up power.
Old 09-10-2015, 03:46 PM   #4
Rewards Points: 123
That is the thread. Thanks!
Old 09-10-2015, 03:52 PM   #5
Very Long Vacation
In so far having one ATS feed a panel single panel like in the thread is complaint. Guy has some other violations but this is ok.
Old 09-10-2015, 04:03 PM   #6
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
Will the ATS become the service disconnect for one of the panels?
If so, will your service disconnects remain grouped?
Pete
Old 09-10-2015, 04:11 PM   #7
Rewards Points: 123
The argument by the HI is that the structure will be supplied by two services during a delay of transfer upon restoration of utility power.
Old 09-10-2015, 04:14 PM   #8
Pete m.'s Avatar
Rewards Points: 172
The structure will not be supplied by two services under any condition. Tell the HI to look at the definition of SERVICE in article 100 of the NEC.
The violation you actually have (at least the most glaring) is the fact that you are using a Service Rated ATS (which becomes a service disconnect) and now your service disconnects are not grouped.
Pete
Old 09-10-2015, 04:19 PM   #9
Rewards Points: 123
Pete
Not my install but thanks.
Old 09-10-2015, 04:20 PM   #10
Very Long Vacation
In any case I think that thread would make a good discussion here.
Old 09-10-2015, 04:31 PM   #11
Pete m.'s Avatar
Rewards Points: 172
Oops... sorry.
Pete
Is this code compliant? HackWork NEC Code Forum 42 05-13-2015 12:43 AM
Code compliant? navyman NEC Code Forum 11 10-23-2014 01:34 PM
Is this code compliant? Hexamexapex Residential Electrical Forum 11 02-26-2013 08:18 PM
Is this code compliant? Shockdoc General Electrical Discussion 40 06-15-2012 02:10 PM
Code compliant Gamit General Electrical Discussion 22 02-18-2012 09:00 PM
