Commercial island receps - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By 3DDesign
  • 1 Post By HackWork
  • 2 Post By backstay
  • 1 Post By FF301
Old 07-03-2017, 10:37 PM   #1
Rewards Points: 552
Default Commercial island receps
I need to install receptacles in or on an island in a commercial kitchen. What is the right way to do this? Is there is surface mount box for this? I think it would look better and be more accessible to have them on the countertop, but need ideas.
John M. is offline   Reply With Quote
Old 07-03-2017, 10:59 PM   #2
Rewards Points: 3,078
You're not giving any details on the island, a photo would help. Is it stainless steel?
Maybe something like this?
Dash Dingo likes this.
Greg
Old 07-03-2017, 11:12 PM   #3
Dash Dingo's Avatar
Rewards Points: 318
In the past I have used the appropriate size Minnie's and clamped them to the round stainless table leg. Then stuck a 1/4 bolt through them and mounted a outdoor bell box to it or 1900 box. That's if the feed comes through the floor.
If the feed is through a ceiling tile I have just dropped soow cord and used a bell box and strain relief.
Dash Dingo is offline   Reply With Quote
Old 07-04-2017, 12:16 AM   #4
Rewards Points: 26,486
In a Commercial Kitchen the usual solution is for Woodhead cord drops from the ceiling.
While not cheap to buy, they are easy to install and maintain.
They make the Food Inspector very happy.
Unlike your own kitchen, a commercial kitchen requires wash--down rated everythings.
That's why stainless steel is mandated... why you have to use Minnerallac straps to set off surface mounted EMT/ IMC... why GFI protection is required... and much more.
These are NOT cheap rooms to build.
The Woodhead cord drops are usually on a reel that has stops on the cord... in-use and retracted.
They will typically have integral caps, see the website, that exclude water during wash down.
The assumption here being that the central table is exactly where most of the food prep will occur.
You'll see this set up with butcher shops just about everywhere.
The OP does not mention anything being exotic, but Woodhead provides pin&sleeve and twist-lock pin-outs, too.
These have the terrific advantage of being much more robust, and of providing 'keyed' voltages// amps.
The problem with twist-locks is that the gorillas and chimps ruin them before they discover that such a beast even exists. Chimps usually comprise the entire wash down crew. Turn-over is staggering.
This means that, once they've ruined the connection, again, the cord set is ruined, again.
Hence, the pin&sleeve pair will prove out to be the cheapest most reliable connection. It's chimp proof. ( But not gorilla proof. )
It's common for such cord caps to be mounted with Woodhead stainless steel strain reliefs, too.
All of the 'cheaper solutions' crap out faster than you can possibly imagine.
Then the kitchen is out of action.... so the chimps start roping zip cord all over the joint.
The typical cutting// prep table only needs two power drops, so they're not going to break the bank.
http://www.molex.com/molex/industry/...nel=Industries
Old 07-04-2017, 07:23 AM   #5
Rewards Points: 552
This is a regular cabinet base with a granite top
Old 07-04-2017, 07:46 AM   #6
Commercial kitchens are held to an entirely different standard than a home kitchen.
Don't assume that the owner knows what he's doing.
Many guys jump into the restaurant game... only to discover they've no clue as to the Health Inspector's requirements.
Your post implies that this is your first commercial kitchen.
It's going to be an education.
The grocery chains and major franchises have tons of blow by blow contract specifics for such spaces.
If you have the nerve to ask, most grocers will let you look at their freezers, cold boxes and cutting rooms. It will prove an eye-opening experience.
Bring your smart phone// digital camera.
If there really was a cheaper way to build out these spaces, they would've done so.
They don't miss a trick... and they may well build a new store about every four-days !
Old 07-04-2017, 07:54 AM   #7
Can't Remember
Rewards Points: 490
I'd have to look in the book, but I'm guessing not required unless whoever writes the checks says they want them. As with residential kitchens, getting receptacles into islands and peninsulas can be an adventure.
Been using these of late:
http://www.legrand.us/wiremold/work-...ip-up-usb.aspx
Old 07-04-2017, 08:28 AM   #8
The AHJ that counts is the Health Inspector.
FORGET the NEC.
NRP3... I'd be astounded if any health inspector accepted the LeGrand solution.
You can't get it clean.
Not to the standards required.
It's the kind of gadget I can see installed in a McMansion and its granite counter top, though.
Commercial kitchens are cleaned by chimps, not %$#@ retentive housewives.
The authorities know that.
Old 07-04-2017, 08:29 AM   #9
Rewards Points: 1,153
Why not just pray and let god handle it for you?
dielectricunion likes this.
Old 07-04-2017, 08:31 AM   #10
But, it's the Seventh day, and you're resting.
Old 07-04-2017, 08:38 AM   #11
Can't Remember
Rewards Points: 490
I buy into the washdown thing and yes I spend my kitchen time with folks willing to spend those kinds of dollars, not the commercial kind. I like the cord drop idea, I'll remember that if I'm asked.
Old 07-04-2017, 11:14 AM   #12
backstay's Avatar
Rewards Points: 296
I'd be surprised if granite is allowed as a work surface in a commercial kitchen.
frenchelectrican and telsa like this.
Old 07-04-2017, 12:52 PM   #13
Can't Remember
Rewards Points: 490
For all I know this is where the cash register is.
Old 07-04-2017, 08:06 PM   #14
Rewards Points: 44
Culinary class room we built last summer
Commercial island receps-img_1259_1499209501592.jpg   Commercial island receps-img_1263_1499209549366.jpg
FF301 is offline   Reply With Quote
The Following User Says Thank You to FF301 For This Useful Post:
telsa (07-05-2017)
Old 07-04-2017, 09:03 PM   #15
Rewards Points: 21,896
That is pretty rare in commercal Kitchen location .,,
the only time I do see it .,, if it was casher location but most place will say super smooth countertop useally stainless steel.
( it our code too have stainless steel countertops over here too in commercal kitchens )
telsa (07-05-2017)
Old 07-04-2017, 09:10 PM   #16
Rewards Points: 1,146
I saw a really old commercial kitchen, it was actually a candy store where they made the chocolates, they had big granite tables, actually they might have been marble, they'd pour the fudge on there so it would cool fast or something.
They closed the place and they told me they cracked up the tabletops with a sledgehammer and left them at the curb to be hauled off. Cracked up the 100 year old frames from the tables and burned them in 55 gallon drums.
Old 07-04-2017, 09:20 PM   #17
Rewards Points: 3,002
Unless you are going to bring conduit up from below or drop down from above you are stuck with cord drops.
telsa (07-05-2017)
Residential Journeyman looking for commercial work in Washington State/Seattle area Hanford43 Looking For Work 2 08-21-2017 02:44 AM
Being charged commercial utility rates for home base ewing Business, Marketing, and Sales 22 04-22-2017 01:54 PM
Residential to Commercial electrician besc Commercial Electrical Forum 18 09-19-2016 10:11 AM
Commercial Electrical Estimator Jason Jones Commercial Electrical Forum 24 08-05-2016 11:43 PM
Do I need to have a commercial driver's license or even a simple driver's license... nadogger General Electrical Discussion 77 06-04-2016 11:51 PM
