Conduit Seals - Electrician Talk - Professional Electrical Contractors Forum
Old 02-12-2015, 09:42 AM   #1
Default Conduit Seals
I am required to connect new conduits to existing (empty) conduits but the existing conduits have hardened seals. Can the seals be removed and done so without damaging the seal body itself?
3rd Base Master is offline   Reply With Quote
Old 02-12-2015, 09:55 AM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
Yes the sealing compound can be removed. Usually use a screwdriver or small chisel to chip it out. It's much easier if there are no conductors to deal with.
Pete
Old 02-12-2015, 01:11 PM   #3
Rewards Points: 3,994
So someone poured an empty seal and now you are connecting your conduit to it? If there's no wires in it, you could just cut the old one out, or spin it off, and replace with a new one... If they are in the middle of a run and can't be easily taken out, cut it in half, remove and replace with a new seal and a union (depending on piping situation)...
Old 02-12-2015, 02:28 PM   #4
Rewards Points: 1,224
Around here, with the billing rate approaching $2 a minute, it will cost way more to chip out the sealing compound than it would to just replace the seal.
The Following 2 Users Say Thank You to don_resqcapt19 For This Useful Post:
glen1971 (02-13-2015), sparky970 (02-13-2015)
Conduit Seals in Hazardous Location KevinKM NEC Code Forum 14 10-17-2012 12:04 AM
Cut out seals R1989 UK Electrical Forum 21 01-14-2012 09:24 PM
Cut out seals R1989 UK Electrical Forum 1 11-23-2011 06:10 PM
KO seals residential ratrod56 Residential Electrical Forum 15 04-23-2011 08:55 PM
A Few Seals NevadaBoy Commercial Electrical Forum 26 06-16-2009 05:30 PM
