Conduit size for coax? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree52Likes
Unread 09-14-2019, 06:51 PM   #1
Rewards Points: 331
Default Conduit size for coax?
Doing some work for my in-laws and running a sub panel out to a garage while they are getting a new driveway installed. He wasn’t a a conduit for future use if he runs a single coax cable. I’ve never seen coax running in conduit and having a hard time figuring out size. I was guessing 1/2 or 3/4” but just wanted to verify
Smid is offline   Reply With Quote
Unread 09-14-2019, 06:57 PM   #2
Rewards Points: 3,798
3/4" or 1" should be adequate.. PVC is cheap.. Fighting with a 1/2" underground for any distance is not a good day..
Smid, splatz, stiffneck and 1 others like this.
Unread 09-14-2019, 06:58 PM   #3
CoolWill's Avatar
Rewards Points: 2,654
I'm sure it could be done with 1/2" but I wouldn't run a data conduit less than 3/4".
I'm With Her! Hillary 2016
Unread 09-14-2019, 06:59 PM   #4
Rewards Points: 4,396
A single RG6 will fit in a 1/2" conduit but I'd never go less than 1" in that situation, leave some room for additional communications / low voltage.
MechanicalDVR (09-15-2019)
Unread 09-14-2019, 07:12 PM   #5
HertzHound's Avatar
Rewards Points: 882
1” like Splatz said. One day they’ll want security, intercom or phone. Not just that but 1” for anything would be the minimum. One little piece of blue stone or your native rock will ruin your day. With 1” you might have a chance of blowing it out.
Now that I think about it, I would probably do 1-1/4. No wait! Two 1-1/4” one just for a spare. Maybe put the air compressor in the garage and drag in an air line to the house. Better make it three 1-1/4”.
Why say lot words when few words do trick
Unread 09-14-2019, 07:33 PM   #6
Mensa Player
Rewards Points: 663
I don't deal with 1" personally, just an odd size for me with no reason to stock any fittings. I would do 3/4" in some circumstances. But in most I would run 1-1/4".
Smid and HertzHound like this.
Unread 09-14-2019, 09:12 PM   #7
zac
Rewards Points: 822
I run 1" for spas. I run 1"1/4 for chases at what not. For service upgrades it's 1½ and 2".
We basically do the same thing and for me 1¼ is the odd man out.
Smid likes this.
Unread 09-14-2019, 09:21 PM   #8
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 162
If the burial depth is deep enough and being back filled with sand, I would use 2" DB2 For the underground portion... unless it's like 20'.
Navyguy and Smid like this.
Unread 09-14-2019, 09:23 PM   #9
Mensa Player
Rewards Points: 663
In my experience 1-1/4” is the standard for 100A services. That’s what the meter hubs that come with 100A meters are. Meter offsets are offered in 2” and 1-1/4”. And squeeze connectors for #2 SE cable are 1-1/4”.
Unread 09-14-2019, 09:25 PM   #10
MTW
MTW's Avatar
Rewards Points: 8,678
Bigger is better with PVC especially with low voltage cables. PVC insulated cables in PVC conduit = mega friction = no fun pulling.
Navyguy, glen1971, Smid and 1 others like this.
Unread 09-14-2019, 09:31 PM   #11
Rewards Points: 331
Lol, doing 1 1/4” for the sub panel. He literally just wants a single coax for a TV. It’s a small two car detached garage so not a lot of room for a ton of stuff. Will probably go 1” to be safe.
Unread 09-14-2019, 09:53 PM   #12
Mensa Player
Rewards Points: 663
You might as well just do 1-1/4" for both.
Navyguy and Kevin_Essiambre like this.
Unread 09-14-2019, 10:13 PM   #13
MTW
MTW's Avatar
See I.
Unread 09-15-2019, 12:47 AM   #14
Incidentally you will have to abuse the RG6 a bit to get it through a 1/2" LB, a 1" LB will be okay.
Unread 09-15-2019, 12:48 AM   #15
LUBE
Kevin_Essiambre likes this.
Unread 09-15-2019, 10:44 AM   #16
Rewards Points: 4,116
I have never really understood why people want to go small when putting pipe underground...
Even if you wanted to go smaller on both ends I could understand that perhaps, I would put a larger pipe in the ground then go to something smaller for your wire.
The only time I go with a smaller pipe in the ground is when it is for a specific piece of equipment that I know is not going to be changed like driveway heating, gate opener, etc.
Between buildings I would go larger; in 30 years never had anyone say the pipe is too big take it out, but have had lots of times where I have heard "lets dig it up again".
Above ground for your situation, nothing less then 3/4"... I would probably be going 1" and RG6 sucks in PVC unless you lube it and get the right lube too...
Cheers
John
MechanicalDVR and 99cents like this.
Unread 09-15-2019, 10:54 AM   #17
zac
Rewards Points: 822
Is the cable you have rated for wet locations? I see coax cable ran exterior all the time but inside of a conduit may cause problems.
Unread 09-15-2019, 11:06 AM   #18
Rewards Points: 11,867
Personally, I wouldn’t put anything smaller than 1” underground.
Unread 09-15-2019, 11:54 AM   #19
Rewards Points: 1,468
In your case I'd run 1" minimum, you never know what you may want in there in the future.
Unread 09-15-2019, 12:17 PM   #20
Mensa Player
Rewards Points: 663
All pipes should be properly sized. The idea that it is underground so it needs to be twice the normal size never made sense to me.
What's the difference underground or above ground in a building, 350' zigzaging thru a hell hole, in areas that will be finished, with lift rentals required, etc?
And I never understood why someone will want to install a huge pipe for a few smaller conductors, but they are perfectly OK with pulling 4 500's thru a 4" for services.
Really? I have never heard of that other than a broken pipe.
