cut in for pendant light canopy? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-14-2012, 12:09 AM   #1
Rewards Points: 192
Default cut in for pendant light canopy?
Could not find a cut in 3/o box for a canopy. had to crawl in the ceiling and use a 4/o box.
wow
newspark80 is offline   Reply With Quote
Old 04-14-2012, 12:14 AM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Okay that was easy....
Magnettica (04-14-2012)
Old 04-14-2012, 12:15 AM   #3
Rewards Points: 6,421
The brown Union boxes are the only one's I know of that meet your requirement. They're only rated for 6 pounds, though.
Old 04-14-2012, 12:20 AM   #4
Rewards Points: 192
my question is...... what if I did not have a crawl space?
wow
Old 04-14-2012, 12:22 AM   #5
Then you'd have to do something different. You're an electrician. Figure it out.
The Following 6 Users Say Thank You to MDShunk For This Useful Post:
19kilosparky984 (04-14-2012), bruce6670 (04-14-2012), Chris1971 (04-14-2012), electricmanscott (04-14-2012), HARRY304E (04-14-2012), MaxFuse (04-14-2012)
Old 04-14-2012, 12:24 AM   #6
RIP 1959-2015
HARRY304E's Avatar
Use a ceiling fan box kit.
Old 04-14-2012, 12:28 AM   #7
This is the only 3/0 old work box I know about:
newspark80 (04-14-2012)
Old 04-14-2012, 12:33 AM   #8
sstlouis03's Avatar
Use a pancake box
sstlouis03 is offline   Reply With Quote
The Following User Says Thank You to sstlouis03 For This Useful Post:
Old 04-14-2012, 12:33 AM   #9
B W E's Avatar
Rewards Points: 1,000
There's several
Old 04-14-2012, 12:33 AM   #10
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Arlington makes something similar. Not sure of the part number but I could take a picture of one I have in the van. They're perfect for those small canopy-type pendants.
Replies based on NEC 2014
Old 04-14-2012, 12:34 AM   #11
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by B W E View Post
There's several
Those are all 4/0 boxes.
They all look the same, but only the one on the right is used by hacks.
Old 04-14-2012, 12:35 AM   #12
Rewards Points: 192
I tried this but the metal tabs stuck out past it....
wow
Old 04-14-2012, 12:35 AM   #13
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
That's because they sell them at HD.
Old 04-14-2012, 12:35 AM   #14
Rewards Points: 192
There's several
these were too big...
wow
Old 04-14-2012, 12:36 AM   #15
RIP 1959-2015
HARRY304E's Avatar
Old 04-14-2012, 12:36 AM   #16
That's how it's supposed to work.
Old 04-14-2012, 12:40 AM   #17
Sometimes, in tough old work applications, you don't have a choice but to use a 4/0 box and put a 6" plain flat medallion behind the fixture canopy if you don't want to do plaster work. You could also have holesawed a hole and screwed a 3-1/4" pancake right to the joist. I've done that a time or 500.
Old 04-14-2012, 12:40 AM   #18
Rewards Points: 192
thanks guys but none of these quite work
I think the pancake box with a couple toggles is the best option.
know i know for the next time....
wow
Old 04-14-2012, 12:43 AM   #19
Toggles? What the hell for? If you have a canopy so small that the ears on an old work 3/0 box stick out past it, I highly doubt it has enough depth to conceal a surface mounted pancake.
Old 04-14-2012, 12:44 AM   #20
RIP 1959-2015
HARRY304E's Avatar
All you need for those is the right sized hole saw then push the box in the hole and take your Phillips and pound the screws till the metal toggle pops in and opens up in the ceiling then crank the screws and it will work just like a big toggle bolt.
Use of a 4sq as a pendant on a drop cord, violation? TOOL_5150 General Electrical Discussion 41 11-17-2014 09:24 AM
Canopy Lights Roger123 Lighting Design 14 03-15-2012 10:14 PM
Gas station canopy light fixture replacement Landmark General Electrical Discussion 5 06-03-2011 10:14 PM
pendant light installed above tub Jaga NEC Code Forum 13 05-09-2009 12:08 PM
Pendant light Installation dmanola7 Business, Marketing, and Sales 4 04-17-2009 11:33 AM
