Cutting oil - Electrician Talk - Professional Electrical Contractors Forum
Like Tree38Likes
Old 11-05-2018, 09:06 PM   #1
I had to do a lot of drilling today using the hole saw to make knockouts in pull boxes ,panels etc .
I didn’t want to burn up the bits so I asked the boss if he could buy cutting oil , he gave me w-d-40 instead and said it’s just as good .
In my opion it didn’t wrk well at all it continued to burn up to fast , I guess it cooled the bits, but made a lot of smoke .
I don’t believe it works as well as actual cutting oil .
Just wondering what others think on this
Unionpride277 is offline   Reply With Quote
Old 11-05-2018, 09:08 PM   #2
German Spy
Helmut's Avatar
Rewards Points: 3,843
KO sets work better.
Old 11-05-2018, 09:12 PM   #3
Bird dog's Avatar
Rewards Points: 1,864
Please refresh my memory. If you use a 3/8" drill bit, you can skip the 1/2" KO?
Hole cutters work better than hole saws.
Old 11-05-2018, 09:15 PM   #4
Jlarson's Avatar
Rewards Points: 4,032
WD-40 doesn't work good for steel cutting, it's works ok for aluminum though.
Old 11-05-2018, 09:16 PM   #5
German Spy
Helmut's Avatar
I use a uni- bit till the 1/2" KO, and go up from there with KO's
Beleive 1/2" KO is 7/8"
Old 11-05-2018, 09:22 PM   #6
Bird dog's Avatar
I was thinking of the size hole needed for the large KO stud and not mess with the 1/2" KO.
John Valdes likes this.
Old 11-05-2018, 09:24 PM   #7
German Spy
Helmut's Avatar
I think 3/4" or 7/8".
The Following User Says Thank You to Helmut For This Useful Post:
Bird dog (11-05-2018)
Old 11-05-2018, 09:32 PM   #8
Rewards Points: 2,188
You should not use a lubricating oil in a cutting application and you should not use cutting oil in a lubrication application.WD40 is more of a lubricant than a cutting fluid.
Cutting oil will work fine on holesaws. I get a cup and a brush and apply the oil with the brush and you should be fine. You might try CRC spray on cutting oil on the holesaws .
I have used CRC spray on cutting oil when threading pipe by hand with no problems. I have used it when using a pony motor it just cannot the heat and the threads were unuseable.
I have also heard of using a wax commode ring (unused of course) for cutter lubrication. I do know they make wax sticks for cutter lubrication.
https://www.mscdirect.com/browse/tnp...gaAuOPEALw_wcB
LC
Old 11-05-2018, 09:45 PM   #9
Rewards Points: 7,520
LC
I agree it is not good for cutting, but WD 40 is not a lubricant. Just sayin
Old 11-05-2018, 09:55 PM   #10
Rewards Points: 1,664
I didnít want to burn up the bits so I asked the boss if he could buy cutting oil , he gave me w-d-40 instead and said itís just as good .
In my opion it didnít wrk well at all it continued to burn up to fast , I guess it cooled the bits, but made a lot of smoke .
I donít believe it works as well as actual cutting oil .
Breathing that smoke IS NOT GOOD FOR YOU, did you have a proper mask?
Old 11-05-2018, 09:55 PM   #11
Eddy you are exactly right and sometimes It creates more problems that it solves.
One other thing in my shop I use a lot of ANCHOR LUBE . Works good on stainless and even better on carbon steel.
https://www.mscdirect.com/browse/tnp...YaAq95EALw_wcB
LC
Chops146 likes this.
The Following User Says Thank You to Lone Crapshooter For This Useful Post:
Chops146 (11-06-2018)
Old 11-06-2018, 06:25 AM   #12
Rewards Points: 1,114
I drill and hole cut a lot of stainless and i think drill speed, pressure on the bit and knowing how to sharpen a drill bit are way more important than then the type of oil being used.
If the drill is not cutting then its skidding causing the the layer that should be removed to heat harden, Oil keeps this from happening by acting as a coolant but its also stopping the the drill from cutting. The best stuff to use is water based cutting fluid pre mixed in a spray bottle but that causes its own problems around electrical. Oil also causes problems with staining on painted surfaces so i like to go old school and just drill the hole then sharper the bit. With a cutter i will go for a few seconds then stop and allow the cutter teeth to cool then go again.
Aluminum is a different ball game and i will use oil to stop the drill from getting a good bite.
Old 11-06-2018, 06:27 AM   #13
Rewards Points: 1,268
LC
Wax toilet rings have bee's wax in them which is a decent cutting fluid when it melts.
Worked on a high tech satellite project in the early 80s where the specs called for using raw bees wax for threading dies, taps, and hole saws. It came in paper tubes like huge chap stick containers. All the pipe and enclosures were made from Monel.
Old 11-06-2018, 06:37 AM   #14
I always carried clear & dark cutting oil along with tap magic on my work vehicle to cover all bases and also occasionally stick wax for driving large lag screws into old wood.
circuitman1, scotch and NewElect85 like this.
Old 11-06-2018, 07:36 AM   #15
Rewards Points: 3,078
Drill metal SLOW. Drill wood FAST.
1/2" Drill bit in steel should be about 200 RPM or slower
eddy current likes this.
Greg
Old 11-06-2018, 07:39 AM   #16
Rewards Points: 1,608
I suppose that this is one of those "anything is better than nothing" situations. Extending the life of a hole saw requires some sort of coolant and a slow speed.
I have had good luck with the Milwaukee "Shockwave" holesaws in panel enclosures. they are small, light, and cheap. I use my 12 volt impact and WD40. Note, these holesaws are useless in stainless.
Old 11-06-2018, 07:50 AM   #17
Rewards Points: 686
I made that mistake exactly once. I almost passed out. WD 40 and 226 are some nasty, nasty chemicals. you should never allow it to touch your skin much less breath in heated fumes.
I read the can after using it for 10 years to take bull off of me when working on roof jobs.
Its works way too good to be safe to use. Also worthless as a cutting fluid.
My go to is hands down a product named Tap Magic.
Its cheap, cleans up nice and flat out does the job.
MechanicalDVR and circuitman1 like this.
NewElect85 is offline   Reply With Quote
Old 11-06-2018, 08:08 AM   #18
Rewards Points: 4,082
Best stuff I have ever used...
https://www.jokisch-fluids.com/produ...-paste-897-cf/
Cheers
John
Old 11-06-2018, 09:08 AM   #19
Rewards Points: 4,270
For threading pipe, I don't think there's room to mess around, you want real cutting oil. For drilling holes in most metal (not stainless) and hole saws and cutters, I will use whatever's on hand if it works better than nothing.
WD40 is nothing special, it's mostly mineral oil. Plain mineral oil is not a bad cutting fluid.
I don't think WD40 is a great cutting lubricant but it seems to be better than nothing. It seems too light to be a good coolant but it should lubricate OK and lubrication is half the battle with a cutting oil.
(Actually with a hand saw, WD40 is as good as anything, except maybe silicone spray, but that's mostly just to lube the flat surface of the saw blade, no heat issue.)
You would want to try to keep the speed down so it's not burning (smoking). If it's burning, it's probably worse than nothing.
Vaseline seems to be a passable cutting fluid. It's basically mineral oil too, but more viscous.
I find the wax type a lot handier for use in the field. I even found one that's small enough to put in the case with the bits, like a big crayon. I can't remember the brand name. AGS makes Cut-Ease, I can't find it locally but that one looks like a good medium size made for the purpose.
For stainless, it's a mess, but I think evaporated milk actually works.
Old 11-06-2018, 09:12 AM   #20
Those things are great and they're cheap enough that I'm not going to sweat it if they don't last very long.
Anybody into chainsaws and wood cutting? MTW Off Topic (Non Trade) 41 03-19-2018 10:05 PM
Cutting a steel mudring WPNortheast General Electrical Discussion 26 01-23-2018 10:25 AM
Avoiding cutting ceiling moulding WronGun Residential Electrical Forum 28 05-03-2017 10:15 PM
Server cutting out Cl906um General Electrical Discussion 5 06-06-2016 10:21 AM
M18 metal cutting saw. WIsparky71 Tools, Equipment and New Products 7 01-25-2016 05:28 PM
