Damaged wiring inside a water heater - questions - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 5 Post By MechanicalDVR
  • 3 Post By Semi-Ret Electrician
  • 2 Post By MechanicalDVR
  • 2 Post By PlugsAndLights
  • 1 Post By sbrn33
  • 2 Post By Big John
  • 2 Post By Islander
Old 12-31-2016, 11:39 AM   #1
Islander's Avatar
Rewards Points: 630
Default Damaged wiring inside a water heater - questions
A plumber sent me this picture yesterday. It's at the bottom element of a water heater tank (GSW Series 6). Apparently there was a short circuit, and the wires melted.
I have a few questions about this:
1) Are we allowed to replace wiring inside the tanks insulation? If yes, what temperature rating would that wiring be?
2) How far back would that wiring likely be damaged? Just inside the tank's insulation? All the way to the connection point at the top of the tank? Beyond that?
3) If one element and/or thermostat has gone, isn't the other one like due to go as well? Should I recommend just replacing the whole tank?
4) What would cause this to happen? A short circuit, most likely, but where? Faulty wiring from the factory?
Thank you
Islander is offline   Reply With Quote
Old 12-31-2016, 11:59 AM   #2
Rewards Points: 2,912
The wires from the bottom element only go up to the top thermostat. The bottom element tends to go 3x as fast as the top as it gets the coldest water with the most mineral and oxygen content. No telling from a pic what caused the original problem, could have been several things. I believe the wires are marked 90deg c on the jacket. Pulling new wires with the old is easily done.
As far as swapping out the whole thing, look at the date on the label. They don't last much longer than the warranty period as a rule of thumb.
Old 12-31-2016, 12:24 PM   #3
Semi-Ret Electrician's Avatar
Rewards Points: 486
Did the WH have an insulation blanket?
A few manufacturers I talked to say it voids the warranty.
Old 12-31-2016, 12:37 PM   #4
Band Member
emtnut's Avatar
Rewards Points: 1,860
I'd do it on my own tank, but I would take the risk doing it for a customer!
Thank you
Depending on the age of the tank, a call to the Mfr might get you a helluva deal on a new tank
Old 12-31-2016, 12:37 PM   #5
Looking at the dust on the top I'd say there was no blanket.
Old 12-31-2016, 01:05 PM   #6
sbrn33's Avatar
Rewards Points: 3,490
Looks to me like it was just a bad connection at the bottom element. Good luck getting that out.
Old 12-31-2016, 01:09 PM   #7
Socket wrench!
jw0445 and circuitman1 like this.
Old 12-31-2016, 01:23 PM   #8
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Punch new holes in sheet metal and run powder coated EMT between top
and bottom burners. Get rid of that BX and put the feed in coloured EMT
too. Post pics to Mech's fancy wiring/pipe thread.
Must have too much time on my hands..........
P&L
MechanicalDVR and circuitman1 like this.
Old 12-31-2016, 01:37 PM   #9
sbrn33's Avatar
P&L
That;s funny because I thought that looked like a pretty hacky install also. My guys may have been redoing that one.
PlugsAndLights likes this.
Old 12-31-2016, 04:49 PM   #10
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I like to secure the flex to the tank with 3" long self-drilling screws.
macmikeman and Islander like this.
Always wear your gloves.
Old 12-31-2016, 04:58 PM   #11
Rewards Points: 17,793
That's too much work. Just do it like me and use a hilti gun and the long nails with a washer the carpenters shoot into bottom plates of partitions to hold them to the slabs.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 12-31-2016, 05:54 PM   #12
LawnGuyLandSparky's Avatar
Rewards Points: 172
Just don't forget the rubber washer and just a dab of silicone.
Old 12-31-2016, 06:05 PM   #13
Rewards Points: 1,335
That's you, buckaroo
samgregger is online now   Reply With Quote
Old 01-01-2017, 05:36 AM   #14
nbb
Rewards Points: 516
Me personally, I would never just replace burnt wire without figuring out why it burned. A bolted short would not do that, and are the only "quick" fixes in my book.
And please strap that flex, those cheap ass connectors are not designed to take that torque.
nbb is offline   Reply With Quote
Old 01-01-2017, 05:37 AM   #15
Islander's Avatar
Rewards Points: 630
Default Update
So, the existing wire was stuck in with the insulation pretty solidly. One wire on the bottom element was melted about 6" up from its connection. I just looked at it and told the plumber that there was no way I was going to install new wire down to the bottom element, as I considered it to be a sealed unit. He's putting in a new tank next week.
Oh, the wire insulation rating was 105 degrees C, btw.
Thanks for the info, and the humour.
readydave8 and circuitman1 like this.
Water Heater Pulls 18A But Water is Cold?? swimmer Residential Electrical Forum 33 12-29-2016 06:21 PM
RV Water Heater sparkysean40 Services and Service Equipment 4 10-31-2016 01:17 AM
Appliance whip on a hot water kick space heater shocksystems General Electrical Discussion 2 06-03-2016 01:31 AM
Panel to water heater distance AK_sparky Canadian Electrical Forum 2 05-20-2016 12:24 PM
shaking my head (water heater) hardworkingstiff General Electrical Discussion 34 04-25-2016 05:11 PM
