On Demand Water Heater - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By Chris1971
  • 1 Post By RePhase277
Old 08-15-2014, 08:38 AM   #1
Rewards Points: 804
Default On Demand Water Heater
I'm looking at a job where we'll have to hook up an electric on demand water heater. It requires three, 40 amp 240 volt circuits. So, would you put handle ties on the three, 2-pole breakers so they can simultaneously disconnect the electric water heater for servicing?
Old 08-15-2014, 08:41 AM   #2
Rest In Peace
aftershockews's Avatar
Rewards Points: 7,003
Why would you need to?
aftershockews is offline   Reply With Quote
Old 08-15-2014, 09:08 AM   #3
backstay's Avatar
Rewards Points: 296
No, it's not required.
The Following 2 Users Say Thank You to backstay For This Useful Post:
3D Electric (08-15-2014), Chris1971 (08-15-2014)
Old 08-15-2014, 09:22 AM   #4
Rewards Points: 804
From a service standpoint. Shut off all the power before working on the water heater. That was my thought.
TheLivingBubba likes this.
Old 08-15-2014, 09:34 AM   #5
Ditch Digging Dummy
3D Electric's Avatar
Rewards Points: 52
We have one in our shop although it takes two 60 amp 240v circuits. All I did was put two breakers in and at the water heater install two 60 amp disconnects.
3D Electric is offline   Reply With Quote
The Following User Says Thank You to 3D Electric For This Useful Post:
MHElectric (08-15-2014)
Old 08-15-2014, 09:52 AM   #6
A Little Short's Avatar
Rewards Points: 1,012
I'd probably try and talk the customer into a gas tankless!
Sure you'll make money on the install but you'll tick off a customer when they found out how much it costs to use it!
They'll be really ticked when their "hot" shower turns into the "ice capades" for a few seconds during the shower!
Old 08-15-2014, 11:18 AM   #7
jw0445's Avatar
Rewards Points: 1,818
I've done several and always place a subpanel at the unit. What's the draw? Can you get the breaker for the sub?
The Following User Says Thank You to jw0445 For This Useful Post:
samgregger (08-18-2014)
Old 08-15-2014, 12:17 PM   #8
Rewards Points: 804
Sounds like customer already owns the water heater. I do agree gas qouldbe cheaper. Not my call.
Old 08-15-2014, 05:58 PM   #9
220/221's Avatar
Rewards Points: 4,108
I'm gonna take a wild guess that there is no gas available.
If you or your AHJ felt the need for the whole thing to be disconnected with one switch, install a small sub.
220/221 is online now   Reply With Quote
Old 08-15-2014, 06:59 PM   #10
icemanjc's Avatar
Rewards Points: 109
I heard both sides of the story. Some say gas is cheap now, but the price will go up quite a bit in the I future years. While electricity will stay around the same price.
It also seems that electric on demand water heaters are much cheaper than gas of the same kind.
Some say installation costs are cheaper for electric, I find it hard to believe with the amount of amperage required. I've never installed one so I can't say
Apparently gas ODWH also requires servicing more often too.
I guess really it all depends on the homeowner and what they believe will work best for them. When I lived in Florida, gas wasn't provided to residences. However now that I'm in Michigan, everything runs on gas.
icemanjc is offline   Reply With Quote
Old 08-15-2014, 07:27 PM   #11
sbrn33's Avatar
Rewards Points: 3,510
Why would it go cold?
Old 08-15-2014, 08:48 PM   #12
backstay's Avatar
Rewards Points: 296
I've had one that the HO turned the temp all the way up. Then when it's running and gets to hot they turn down the flow to where it drops below the minimum and shuts the electric down. Service call cost them on that one.
Old 08-18-2014, 10:07 AM   #13
A lot of it depends on the temperature of the water supply. Whole house electric units are not recommended for areas where water supply is below a certain temperature, which a lot of times is well water.
Also, often times, if the hot water is being used at more than one location at a time, the unit can't keep up and some cold water will pass before it has a chance to heat back up. I've read about, actually talked to one person, where only one person was using it to take a shower and the water will not stay at a constant temp it has cold "spurts". I guess that depends on the size of the unit and the water flow.
Old 11-16-2017, 10:20 PM   #14
MTW
Rewards Points: 10,168
Did you end up getting this job?
Old 11-16-2017, 10:34 PM   #15
Rewards Points: 26,512
Three-year old thread.
Old 11-16-2017, 11:51 PM   #16
Rewards Points: 1,360
Can I have your rewards points?
TOOL_5150 likes this.
Old 11-17-2017, 03:23 AM   #17
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
The best kind..... Aged to perfection.
Water heater 347sparky Commercial Electrical Forum 8 03-21-2016 04:34 AM
On demand water heaters ohmega General Electrical Discussion 47 11-21-2012 04:45 PM
on demand water heaters, am I missing something? krypto Residential Electrical Forum 26 11-02-2009 02:55 AM
water heater GEORGE D General Electrical Discussion 57 04-14-2009 06:32 PM
OCP on Water Heater william1978 General Electrical Discussion 31 12-02-2008 10:32 PM
