Dimming LED Lights - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By frenchelectrican
Old 04-01-2016, 02:15 PM   #1
power's Avatar
Rewards Points: 573
Question Dimming LED Lights
Has anyone found weird things happening (strobing, flashing) when you start dimming various area's of LED lights?
We just finished a wine/liquor store, where virtually all various lights are of the LED type. Each different style of light fixture (pendants, pots, cove tape lights) are on separate LED dimmers. When dimming one type of lights, we are finding OTHER types of LED lights start strobing/flashing!!! In other words, when we start dimming the pots, the pendants will flash, or visa versa!!!
Does anyone know about this? Fixing it?
power is offline   Reply With Quote
Old 04-01-2016, 02:35 PM   #2
Rewards Points: 2,294
Are these on multiwire branch circuit's? I wonder if that is the reason
Old 04-01-2016, 03:01 PM   #3
power's Avatar
Rewards Points: 573
Its interesting you asked that....one of our guys was wondering the same thing!
We are using the same branch circuit to feed various different types of lights, yes. Too, the neutral is shared among A, B and C phases (as it typically is).
Your thinking maybe these LED dimmers produce "dirty" power, and potentially are polluting the signal to the other dimmers causing them to react unfavorably?
Old 04-01-2016, 03:08 PM   #4
Rewards Points: 21,898
The common netrual can wreck hovac on dimming system as you did see it..
The only soluation is run it own hot / netural for each circuit...
I done that route when a customer mention dimmer on MWBC so just run like a single circuit..
And try to keep on the same phase if you can that generally advoid flickering / strobe action...
power (04-01-2016)
Old 04-01-2016, 04:51 PM   #5
power's Avatar
Rewards Points: 573
Ok, thanks frenchelectrician. I appreciate your input! Much Thanks!
Old 04-01-2016, 05:48 PM   #6
Rewards Points: 26
The dimming LEDs i have installed require a particular dimmer that has additional + & - dc leads that tie to the LEDs power supply along with the line voltage hot and neutral.
Buttonwoodworks is offline   Reply With Quote
Old 04-01-2016, 06:31 PM   #7
Rewards Points: 64
0-10v dimming
604nguyen is offline   Reply With Quote
Old 04-01-2016, 06:34 PM   #8
If my hunch is right that it do requires 0 - 10 Vdc leads for dimming purpose ..
Brad L likes this.
Old 04-01-2016, 07:06 PM   #9
Rewards Points: 26
604 Is correct.
Tags
dimming led, how to dim an led light, how to dim led, led dimming
Buzzing LED lights - no dimmer quarky2001 General Electrical Discussion 2 03-17-2016 05:40 PM
Light dimming squiresj1 General Electrical Discussion 4 03-15-2016 01:01 PM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 06:38 PM
Workshop Subpanel - House lights dimming ispperformance General Electrical Discussion 1 01-06-2016 11:31 PM
120 washer lights dimming COSMOS275 Residential Electrical Forum 6 01-04-2016 11:40 PM
