Disabled washroom door opener - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 2 Post By HackWork
  • 1 Post By HackWork
  • 1 Post By Navyguy
  • 1 Post By MDShunk
Old 03-14-2018, 10:03 PM   #1
Rewards Points: 14,075
Default Disabled washroom door opener
Never done one before. What's involved?
Old 03-14-2018, 10:08 PM   #2
Rewards Points: 1,265
Probably some type of motor that gets powered by electricity.
Speedy Petey and dmxtothemax like this.
Old 03-14-2018, 10:11 PM   #3
Thanks .
I really need a detail on this thing from the owner, hopefully before drywall goes up .
Old 03-14-2018, 10:12 PM   #4
Probably a button too. Definitely a button.
Speedy Petey likes this.
Old 03-14-2018, 10:15 PM   #5
MTW
Rewards Points: 10,184
Don't forget conductors.
Old 03-14-2018, 10:26 PM   #6
360max's Avatar
Rewards Points: 1,234
Some require an outlet on wall near the top of the door (on hinge side).
Old 03-14-2018, 10:29 PM   #7
MTW
Wow, you made an electrical post? I'm surprised. I didn't even think you were an electrician.
Old 03-14-2018, 10:57 PM   #8
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,528
I installed a few like this a couple years ago. A receptacle above the door worked great.
Installed strike plates with them.
Knowing usage and furniture placement is important for the strike plates.
The strikes were LV and I left extra cable in the wall so the plate could be relocated later..
This model has a shorter hold open time then the ones I did. But I like the remote this one shows.
http://www.power-access.com/Model-2300-door-opener.html
Old 03-14-2018, 11:12 PM   #9
Rewards Points: 5,098
This is a complete kit that is required in most (perhaps all) areas.
http://www.kmthomas.ca/721-barrier-f...c-locking.html
Cheers
John
Wirenuting likes this.
Old 03-15-2018, 06:50 AM   #10
Rewards Points: 6,421
I've done a bunch of the stanley magic open door openers/closers. The full install manual is online.
Old 03-15-2018, 08:10 AM   #11
Service Call's Avatar
Rewards Points: 32
Most that I’ve connected were wired on the hinge side with a 120/15a circuit. Hard wired into the motor. You could hook up a cord though. The motor is mounted above the door. The remote switches can be either battery (wireless) or wired from the motor, low voltage.
Service Call is online now   Reply With Quote
Old 03-15-2018, 08:39 AM   #12
Wirenuting's Avatar
Cheers
John
I like the switch and lock option placement.
Thanks
Old 03-15-2018, 08:48 AM   #13
Speedy Petey's Avatar
Rewards Points: 600
I've done a couple of Stanley's as well and they are pretty specific. The ones I've done were hard wired and the feed had to be precisely placed since space inside the units was tight.
ABB ACS600 Run Status disabled argentum PLCs, VFDs, Motors and Controls 5 05-19-2017 06:49 PM
