Disconnect question - Electrician Talk - Professional Electrical Contractors Forum
Old 08-10-2014, 08:31 PM   #1
Rewards Points: 282
Default Disconnect question
My company has one work site that has outgrown its existing service.
Right now, the POCO has 3 phase, 200 amp, 250 volt service running down a utility pole, thru their Kw-hr meter, into our 400 amp TB. From the TB, the underground service wires run to 4 different buildings.
The manager wants to add a disconnect between the POCO meter & our TB; both for emergency isolation & because it just makes sense.
I asked the POCO Eng if he wanted to increase his service drop or CT the meter, but as of now, all that they will do is kill the power & lift the service mast off for me to install my new disconnect.
I could not find anywhere in the Code where it would require fuses, but I ordered a fused Disco anyway. I would rather blow a 400 amp fuse than ruin a 200' run of USE if there ever was a fault.
Is there any requirement to fuse that Disco?
Thanks,
Rick
subelect is offline   Reply With Quote
Old 08-10-2014, 09:30 PM   #2
Rewards Points: 3,360
I'm not sure, but I believe it would need overcurrent protection.
The reason is the wire is considered a service from the POCO to the line side of the disco, then it'd be a feeder from the disco to the TB. Feeders require O/C protection.
Also, 230.90 states that each ungrounded service conductor shall have overload protection.
subelect (08-10-2014)
Spa Disconnect Question 277v Residential Electrical Forum 19 02-24-2014 06:19 PM
Disconnect question wjf General Electrical Discussion 15 12-16-2012 05:17 PM
Disconnect Question lims640 General Electrical Discussion 25 12-01-2012 11:27 PM
A-C disconnect question CertElectric NEC Code Forum 2 09-01-2011 10:39 PM
Disconnect question. Mr. Sparkle General Electrical Discussion 12 08-30-2010 05:08 PM
