Distance meters - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By splatz
  • 1 Post By Rora
Old 02-11-2018, 01:04 PM   #1
Rewards Points: 55
Question Distance meters
I was wondering if anyone out there knows of any kind of distance meter that would work for clear liquids. (I E coconut oil). It seems a laser reads right through the oil and I'm not sure if a sonar unit would work either. I have a stainless steal tank that we would like to know how full or empty it is as the product is being used. Thanks for any thoughts.
Musky Hunter is offline   Reply With Quote
Old 02-11-2018, 01:55 PM   #2
Rewards Points: 5,116
I have used proximity sensors in water tanks, once you figure out what the percentage is to the mA you should be fine. You don't have to worry about Food Grade either because it is not in contact with the liquid.
Lots of options here https://www.endressdirect.us/level
Cheers
John
Old 02-11-2018, 02:01 PM   #3
Rewards Points: 18,197
This business of measuring coconut oil levels in Wisconsin is a bit off the charts frankly. Just sayin.....
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 02-11-2018, 07:40 PM   #4
Rewards Points: 199
I have seen ultrasonic measurement used before in wastewater wells, could be worth a look.
Paulusgnome is offline   Reply With Quote
Old 02-12-2018, 05:37 AM   #5
Rewards Points: 606
What about a flow monitor on the input and output pipes? And/or a simple float type transducer?
Pete E is offline   Reply With Quote
Old 02-12-2018, 06:06 AM   #6
Rewards Points: 1,224
Would a pressure transducer work for this?
Recent thread with a lot of good info...
http://www.electriciantalk.com/f28/n...r-tank-241434/
Old 02-12-2018, 09:38 AM   #7
Rora's Avatar
Rewards Points: 716
Laser probably isn't working because the clear liquid isn't reflecting enough back to register on the sensor. Utrasonic would work because the reflection is physical and the sensor will detect the echo off the surface.
There are lots of other options too, like pressure, GWR, capacitance... although ultrasonic is probably your best bet due to being non-contact, which is preferable in the food industry.
Although monitoring the flow in and out works in a perfect world, it's not a direct measurement and prone to developing an error/offset. Even then you'd need two Coriolis meters or something otherwise temperature/pressure corrected and it would end up being a lot more expensive. Floats only work for point detection, which is fine for simple fill/drain controls but not actual monitoring.
Pete E likes this.
Old 02-12-2018, 04:42 PM   #8
just the cowboy's Avatar
Rewards Points: 146
Default Any motion
Sonic or pressure transducers work fine as long as your not agitating the liquid.
Load cells on tanks works the best.
Old 02-12-2018, 05:50 PM   #9
Rewards Points: 416
Differential pressure works well for level monitoring as long as you have the fittings on the vessel you are measuring, ultrasonic will work as well as long as the surface is calm and there is no foaming (may need stilling well) and has the benefit of having no contact with the fluid. Capacitance probe may work but needs to sit in the fluid.
Float columns with magnetic switches work but the float is in the fluid.
mitch65 is offline   Reply With Quote
Meters for the Trade Neophyte Genius Electrician Apprentice Forum 14 10-24-2017 12:30 PM
replacing apartment meters John M. General Electrical Discussion 6 10-04-2017 09:42 AM
Combine Two Meters into One WaCkEdJoKeR Residential Electrical Forum 3 01-16-2017 08:52 PM
Voltage Increase along distance Hendra Tampang Allo General Electrical Discussion 14 01-23-2016 09:45 PM
