DIY service upgrade with live meter - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2015, 03:01 PM   #21
Rest In Peace
aftershockews's Avatar
Rewards Points: 7,003
Originally Posted by electricalwiz View Post
did he run the SE cable through the attic? Did I see that right
It looks like open conductors.
Official troll magnet.
aftershockews is offline   Reply With Quote
Old 02-27-2015, 03:02 PM   #22
Rest In Peace
That solves it, I now know who installed this panel.
The Following 5 Users Say Thank You to aftershockews For This Useful Post:
3D Electric (02-28-2015), guest (02-27-2015), JohnJ65 (03-01-2015), Lectric (02-27-2015), Magnettica (02-27-2015)
Old 02-27-2015, 03:03 PM   #23
Rewards Points: 1,138
Originally Posted by aftershockews View Post
He removed the glass cover from the meter?
And you can see where someone has hit the line side of that socket with the cover before.
I saw that too, why would you remove the glass cover
'I believe that banking institutions are more dangerous to our liberties than standing armies"
Thomas Jefferson
electricalwiz is offline   Reply With Quote
Old 02-27-2015, 03:04 PM   #24
I realized that after I said SE
Thomas Jefferson
Old 02-27-2015, 03:07 PM   #25
he hacked that together yet used copper conductors for the service
Thomas Jefferson
Old 02-27-2015, 03:21 PM   #26
Very Long Vacation
Rewards Points: 5,262
It just your brain trying to protect you from something to ugly to swallow.
The Following 2 Users Say Thank You to meadow For This Useful Post:
electricalwiz (02-27-2015), guest (02-27-2015)
Old 02-27-2015, 03:24 PM   #27
ET rocks
3xdad's Avatar
Rewards Points: 2,174
i guarantee you he didn't even know that was going to happen. Nice twisting motion to remove a meter.....cause & effect.
3xdad is offline   Reply With Quote
The Following 4 Users Say Thank You to 3xdad For This Useful Post:
51360 (02-27-2015), guest (02-27-2015), JohnJ65 (03-01-2015)
Old 02-27-2015, 04:13 PM   #28
Rns
Rewards Points: 29
Don't stand on the ground! Stand on plywood. Really? Now some poor sole will try this themselves thinking its completely safe from being shocked or electrocuted.
Rns is offline   Reply With Quote
Old 02-27-2015, 04:46 PM   #29
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
He you guys post your comments on his video,Don't hold back..
The Following 2 Users Say Thank You to Black Dog For This Useful Post:
guest (02-27-2015), Magnettica (02-27-2015)
Old 02-27-2015, 05:00 PM   #30
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I especially like, " I hope this video helps you and others like you to avoid being ripped off by overpriced electricians.".
STFU dude.
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
3xdad (02-27-2015)
Old 02-27-2015, 05:33 PM   #31
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Things you screwed up…
The meter pan cover comes off before the meter can be pulled (with this particular meter enclosure).
Depending on the utility company you may or may not be allowed to tie your grounding conductor to the meter enclosure.
Only a fool works with non-insulated tools when working with electricity.
Those “holes” in the top of the panel box are called knockouts.
Grounds and neutrals are NOT the same.
You’re right about mixing copper and aluminum.
Two “neutral” wires under the same terminal is an NEC violation and dangerous because the neutral is a carnet carrying conductor.
No connectors at the new “splice box” is also an NEC violation and dangerous.
I’m an electrical contractor and I’m licensed, insured, and bonded. Generac certified too!
The main bonding jumper’s installed in the main breaker panel but you’ve also bonded in the so-called “splice box” too and therefore you’ve created a parallel path for current to flow on parts that shouldn’t be energized.
Face away from the panel when turning on the breakers in case you’ve made a mistake.
Thanks for keeping guys like me in business!
Old 02-27-2015, 06:03 PM   #32
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
He deleted his quote which deleted my post so I just re-posted my comments...
Overpriced electricians AH Paul, how's that welfare check you're collecting each month....
Your video will be used against you in a court of law if there is a fire or someone gets electrocuted because you have no training in doing electrical work, standing on wood will get you belted just as fast because the wood will not insulate you from the ground.
You should work a four year apprenticeship and take the Journeyman electricians license then take the master electricians exam so that you can legally run a electrical contracting firm, I'll bet after you do all of that you will not think we are overpriced ripoff artists.
You do not see the danger in what you're doing because you do not have the proper training in the electrical field.
Old 02-27-2015, 06:06 PM   #33
Rewards Points: 804
Good thing net neutrality passed. This video can now be banned.
Old 02-27-2015, 06:15 PM   #34
Conduit Extraordinare
mdfriday's Avatar
Rewards Points: 1,510
The suspense was killing me.....
mdfriday is offline   Reply With Quote
Old 02-27-2015, 06:18 PM   #35
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
He's replying to the comments right now
The Following User Says Thank You to Black Dog For This Useful Post:
Old 02-27-2015, 06:35 PM   #36
Rewards Points: 864
I like the 2/0 copper 100 amp wire ding dong said he used. What a tool.
Thanks for posting this video I needed a good laugh!
Pride is doing what you know is right especially when no one else is looking.
Sparky J is offline   Reply With Quote
Old 02-27-2015, 06:40 PM   #37
ET rocks
3xdad's Avatar
Paul wrote:
In the video I said that electricity flows through the neutral wire, unless theres a problem then it will flow through the ground wire instead. The ground wire is a secondary backup in case there is a failure in the neutral wire.
Well hell, why don't you just nut the whites and greens together at each device then?
Old 02-27-2015, 06:48 PM   #38
Rewards Points: 88
I got to the 3:55 point and wanted to punch him in the face, what a jackwagon....but I digress
I am an Electrician....not a magician.....
Lectric is offline   Reply With Quote
The Following User Says Thank You to Lectric For This Useful Post:
guest (02-27-2015)
Old 02-27-2015, 07:41 PM   #39
Barjack's Avatar
Rewards Points: 280
Done
Edward Current 1 second ago
Reckless and irresponsible. Just out of curiosity, was a permit pulled and was there an inspection? Are you prepared to be held financially and criminally responsible should any of the myriad of errors in this installation cause a fire or electrocution? I truly hope it is just you living there. It would be unfortunate for an innocent person to suffer for your incompetence.
Note to viewers: DO NOT TAKE DIY ELECTRICAL ADVICE FROM A RANDOM DIRTBAG IN A TANK TOP AND JEANS SHORTS!
Barjack is offline   Reply With Quote
The Following User Says Thank You to Barjack For This Useful Post:
guest (02-27-2015)
Old 02-27-2015, 07:45 PM   #40
This gets better..he's spent the last two hours or so posting childish comments on my YouTube channel....
And the little crybaby deleted all of my posts too...
service live Lep Business, Marketing, and Sales 4 10-04-2014 03:47 PM
meter socket upgrade mangottado Residential Electrical Forum 5 09-10-2013 02:15 PM
Drooping Meter Live Tactics Cletis General Electrical Discussion 25 11-16-2011 12:37 AM
Panel and Meter Can Upgrade Price newspark80 Residential Electrical Forum 19 09-11-2011 11:55 AM
Anyone ever change out a res. meter bass LIVE (underground feed) 00Funk Services and Service Equipment 34 02-13-2011 09:51 AM
