Do new breakers trip faster? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-16-2015, 10:35 PM   #1
220/221's Avatar
Rewards Points: 4,116
Default Do new breakers trip faster?
Do new breakers (manufactured/installed in the last 10 years) short circuit trip faster than older ones?
In the last couple months, I have experienced a dead short on a 20A 120V circuit that barely made a spark. I was certain that it was a GFCI circuit because I saw no sign of arcing.
I used to be afraid to dead short a non GFCI circuit (to identify it ) because the arc freaked me out. In the old days, it was like a mini welder for a while until it tripped. Sometimes it would take more than one attempt.
I was just wondering if they changed the specs or design to recognize a short and trip faster.
Old 02-16-2015, 10:49 PM   #2
Very Long Vacation
Rewards Points: 5,262
Most newer breakers do trip faster on a dead short, while older ones varied a lot. Square D single poles trip the fastest at 6 times the handle rating. This paper makes mention of magnetic trip curves:
http://paceforensic.com/pdfs/Circuit..._of_Safety.pdf
The Following 2 Users Say Thank You to meadow For This Useful Post:
220/221 (02-17-2015), 51360 (02-17-2015)
Old 02-16-2015, 11:09 PM   #3
Rewards Points: 5,198
As far as I know they are designed to trip during a fault in a time frame that is measured in "cycles per second". I suppose that over time the manufacturers could figure how to gain more speed in the mechanics of it all.
Old 02-16-2015, 11:19 PM   #4
Rewards Points: 18,225
It all depends on the short itself, high resistance ones are going to be slower to trip, bolted solid ones are going to go thru the bell shaped curve faster and trip it better. Also the fault current available at each location will be different, so that explains why the fireworks are different sometimes. In a busy office building a short circuit can boom an electrician right into the burn unit or grave, so they are not something to mess around with.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
The Following 2 Users Say Thank You to macmikeman For This Useful Post:
hardworkingstiff (02-17-2015), MTW (02-16-2015)
Old 02-16-2015, 11:25 PM   #5
MTW
Rewards Points: 10,228
Square D has always made fast reaction time as a selling point with their breakers (QO- Quick Open, Homeline uses the same mechanism)
The Following 4 Users Say Thank You to MTW For This Useful Post:
220/221 (02-17-2015), meadow (02-16-2015), Tiger (02-17-2015), TOOL_5150 (02-17-2015)
Old 02-17-2015, 01:25 AM   #6
Rewards Points: 14,205
Hard to speed up the mechanics. That's why fuses are faster than circuit breakers on short circuit - nothing mechanical.
I agree that breakers are faster now. Maybe by design and maybe because old breakers are tired and slow.
The Following 2 Users Say Thank You to 99cents For This Useful Post:
Bad Electrician (02-17-2015), Spunk#7 (02-17-2015)
Old 02-17-2015, 03:23 AM   #7
Very Long Vacation
A lot of it has to do with manufacturers lowering the magnetic trip value. Some older breakers were over 35 times the handle rating with others like FPE and Bulldog not even having magnetic trip. Unless you were next to the panel and the utility gave you a good amount of short circuit current older breakers took their time to clear a fault. With those breaker you could short something out at the end of a circuit and the lights in the whole house would dim for a second or two
Over the last 20 years manufactures have settled at about 10x the rating.
Also a small contribution to the above is unlatching time and arc extinguishing time, which as a whole can add a cycle or two in clearing the fault.
Old 02-17-2015, 07:34 AM   #8
Retired Account
Rewards Points: 14,650
I've seen some serious FPE lightning bolts....
But now i'm curious, because i suspect the potential are older subpanel(s) fed via a Square D , or other magnetically lower main tripping before the branch circuits do....
Old 02-17-2015, 08:01 AM   #9
Rewards Points: 1,224
As far as I know the standard for breakers does not even require that the breaker have an instantaneous trip function. That being said, as far as I know all of the breakers do have that function, but the trip settings for the instantaneous trip vary over a wide range...from about 6x to about 25x as I recall.
The Following 2 Users Say Thank You to don_resqcapt19 For This Useful Post:
hardworkingstiff (02-17-2015), meadow (02-17-2015)
Old 02-17-2015, 08:02 AM   #10
Retired Account
And we are talkin' ground faults, not shorts right? I've found a good short to brighten up most jobs rather quickly....~CS~
Old 02-17-2015, 08:11 AM   #11
Retired Account
I'm told all molded case breakers used in resi are inverse time vs larger E frames /bolt in instantaneous .
That said , how much of a trip disparity can be expected, and under what conditions?
Old 02-17-2015, 08:13 AM   #12
Rewards Points: 14,714
I watched a guy turn a 6" long conductor (in a metal box) into a 2" long conductor before I got him to quit trying to trip the breaker by flashing the conductor to the box. Circa 1975 in a remodel job in downtown Norfolk. This was the same guy that did not understand you could not put two hot conductors from the same phase (different breakers) with the same neutral.
The Following User Says Thank You to hardworkingstiff For This Useful Post:
51360 (02-17-2015)
Old 02-17-2015, 08:16 AM   #13
Retired Account
Hopefully he gained some smarts since then Lou.....~CS~
Old 02-17-2015, 08:26 AM   #14
My Knipex circuit breaker tester still works after cutting through live cable - once with a fresh Siemens panel and once with a fresh QO panel.
Old 02-17-2015, 11:39 AM   #15
Rewards Points: 3,090
Even though it's over thirty years old, it's an excellent article meadow, thanks for sharing.
For me, it drives home the myths in those days and the misconceptions blindly followed by experienced professionals.
Also a very strong hint as to the development of AFCI protection. I think I will change my mind and support AFCI protection throughout the home.
Once again, I digress. Sorry.
Borgi
Old 02-17-2015, 02:37 PM   #16
The only breakers that can be instantaneous only are the ones that are part of a listed combination motor starter.
I believe that all most all of the common breakers are thermal magnetic. The thermal part provides the inverse time function and the magnetic part provides the intantaneous function.
The trip will be based on the breaker trip curves and the actual current flow.
Old 02-17-2015, 03:52 PM   #17
Very Long Vacation
Borgi
Welcome!
Keep in mind that lowering the magnetic trip and GFP will do exactly what an AFCI will do.
Instantaneous trip only breakers (at least from NEC rules) are used for fire pumps and critical process situations.
You are correct, UL does not require magnetic trip, though most breakers do have it simply because of manufactures adding it into the breakers.
Old 02-17-2015, 04:33 PM   #18
Rewards Points: 1,702
Not sure , but in the early 80's I have seen a coworker burn 18 inches of 12 awg wire to get a 20A I-Line breaker , to Trip !
Pete
pete87 is offline   Reply With Quote
Old 02-17-2015, 06:28 PM   #19
Rewards Points: 124
Interesting topic.
Circuit Tracer is offline   Reply With Quote
Push to trip breakers 10492 Services and Service Equipment 11 12-25-2013 11:46 PM
Breakers won't trip?!? (Square D QO breakers) Greg Sparkovich General Electrical Discussion 12 01-10-2013 09:37 AM
both breakers trip RH913RH General Electrical Discussion 3 07-11-2012 03:31 PM
No trip breakers Shockdoc General Electrical Discussion 12 05-21-2012 05:38 PM
Adjustable trip breakers NolaTigaBait General Electrical Discussion 34 01-19-2011 11:23 AM
