Do you own a megger - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Do you own a Megger
Yes I own a Megger 50 75.76%
No I do Not Own a Megger 11 16.67%
Whats a Megger? 5 7.58%
Voters: 66. You may not vote on this poll
Like Tree81Likes
Old 04-06-2017, 08:26 AM   #61
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
I'd thought of megging as common for larger feeds and such. I gather though
that some of you guys use it for every cct. Is that correct? If so, what would
the procedure be?
Here's what I'm thinking. Return to property to do finishing. Bonds & neutrals
are already terminated at panel. Install everything that won't be damaged by
testing. This'd be rcptcls and switchs. Leave off lights, dimmers, timers.
Temporarily make connections where dimmers and timers will be installed.
At each box where something (like a light) isn't installed, pull the leads out
and separate so they won't short to each other or the box.
At the panel: Prior to installing breakers - attach one lead of megger to
panel case then, one by one, attach other lead to each of the "hots".
Last step would be to investigate any low readings.
This would be somewhat time consuming but if it even occasionally found
a problem, it'd be worth it. Especially if that problem wouldn't have been
found anyways by tripping the breaker.
So, if some of you have been doing this, or something similar, I'd like to
hear how it's worked out.
As a side note - I've worked in tract housing - Zero chance of this sort of
testing happening there.
Thanks,
P&L
splatz (04-06-2017)
Old 04-06-2017, 08:46 AM   #62
Rewards Points: 23,906
the procedure be?
Thanks,
P&L
That is exactly how I have done it for sometime now.
Better to know there is an issue with a circuit and look for it than have it happen later down the road.
More than once I traced out a circuit and went box to box with the megger until I found a wire pinched down in a connector or the box clamp on a romex cable.
Some guys really like to tighten clamps to excess.
I will add I've found more problems with romex, UF and Sj type cables than MC or conduit circuits by far.
PlugsAndLights likes this.
Old 04-06-2017, 11:14 AM   #63
Band Member
emtnut's Avatar
Rewards Points: 2,524
the procedure be?
Thanks,
P&L
I remove the neutral as well ... Test between:
L - N
L - E
N - E
the neutral to ground test will keep your afci's happy
telsa, splatz and PlugsAndLights like this.
Old 04-06-2017, 11:16 AM   #64
L - N
L - E
N - E
So happy I've missed out on playing with them. From all the talk here they sound like a total pain.
glen1971 and emtnut like this.
Old 04-06-2017, 11:25 AM   #65
Band Member
emtnut's Avatar
Just curious how many members own a Megger.
Just here to give you a hard time .... Which product from Megger are we talking about ?
Not often I see you slip up (Never ?) ... so I just had to jump on it
btw ... I voted "What's a Megger"
brian john likes this.
Old 04-06-2017, 11:28 AM   #66
I sure hope the others that voted as you are just joking!
Old 04-06-2017, 11:41 AM   #67
Safety Pin Member
L - N
L - E
N - E
Guess I could do N - E all at once in an MLO panel by disconnecting
either the N or E feeding the panel.....
Could do the same, I think, in main panel if I also removed the bond
screw.
Not sure it'd be worth it to me......maybe.
P&L
emtnut likes this.
Old 04-06-2017, 12:52 PM   #68
Rewards Points: 920
I never owned a megger because everywhere I have worked either supplied them or I asked them to supply one.
Now I want one and have zero use for it!
brian john and emtnut like this.
Old 04-06-2017, 01:24 PM   #69
Band Member
emtnut's Avatar
Maybe I'm just stating the obvious here ... but watch out for hardwired stuff in an existing house .
Alarm systems, door bell cct ... etc !
I've heard if you Meg with L and N connected together, to ground, that you won't see the magic smoke ... but I can't confirm
Maybe @brian john can comment.
Old 04-06-2017, 01:57 PM   #70
Sounds like me and the M12 bandsaw. I don't need it but want it bad.
I think it would be a pleasure to use instead of the corded or 18v ones I have.
John Valdes likes this.
Old 04-06-2017, 06:54 PM   #71
Rewards Points: 26,838
I'm not allowed to shop for tools without a chaperone.
MechanicalDVR and emtnut like this.
Old 04-06-2017, 07:34 PM   #72
I wish my wife would say something, she always says "well if you want it".
Self control isn't that easy.
Thank God I realize I have too much already.
Old 04-06-2017, 07:44 PM   #73
Rewards Points: 3,360
I have a BK Precision 307A megger. It's a basic analog type, 250, 500 and 1000VDC. It also has 3Ω and 500Ω resistance ranges.
It gets used once or twice a week, batteries last 6 months or so.
I like analog meggers more than digital ones, maybe it's just the old school in me......lol.
One of the more idiotic things I do with my megger is every time I change batteries, I get out my DMMs and 'megger' them. All of them will go up to 1000VDC, so I set them to read DC volts and blast them with 1000VDC. I figure is the internal electronics will stand 1000 VDC, it'll very likely stand 480 VAC too.
Yes, this is not a UL listed, OSHA approved MSHA required test but I cringe a bit every time I touch test leads to any system that has a fairly high incident energy level.
emtnut and splatz like this.
Old 04-06-2017, 07:57 PM   #74
LOL, I do that as well. I will also retest if the readings are higher than I expect just to make sure.
micromind likes this.
Old 04-06-2017, 08:13 PM   #75
Rewards Points: 3,240
Very true and electronics in switchboards, start at 100 VDC if you see a dead short or a very low reading investigate.
We were getting calls several weeks in a row on Sunday, after a competitor did maintenances on switchboards, we finally figured out there were begging the phase failure relays seems one particular brand would be damaged by this and would hold for a while then trip, hold for a while trip.
Why they called us and not the company that did the maintenance was another story.
I set a letter to my competitor telling him what was the issue.
Al wiring repair ponyboy General Electrical Discussion 140 04-06-2017 05:29 PM
Megger motor windings ElectricMetalTuba PLCs, VFDs, Motors and Controls 15 03-28-2017 08:21 PM
Megger Tester for PM's? Sparky Mcgregor PLCs, VFDs, Motors and Controls 34 10-30-2016 03:24 PM
How do we megger DC Cable ? Mikebro General Electrical Discussion 8 09-19-2016 10:55 AM
Heater megger reading chrisfnl General Electrical Discussion 21 05-01-2016 11:47 PM
