Do You Really Need an IR Camera - Electrician Talk - Professional Electrical Contractors Forum
Like Tree35Likes
  • 8 Post By brian john
  • 3 Post By brian john
  • 1 Post By brian john
  • 4 Post By brian john
  • 2 Post By Bird dog
  • 4 Post By RePhase277
  • 4 Post By emtnut
  • 1 Post By sbrn33
  • 3 Post By macmikeman
  • 1 Post By micromind
  • 1 Post By LARMGUY
Old 09-04-2017, 06:40 AM   #1
Rewards Points: 1,902
Default Do You Really Need an IR Camera
Sometimes the good old eyeball works just fine
Old 09-04-2017, 06:47 AM   #2
Wider shot
micromind, Jarp Habib and Majewski like this.
Old 09-04-2017, 06:50 AM   #3
wwwwwwwwwwwwwwwwwwwww
micromind likes this.
Old 09-04-2017, 06:57 AM   #4
Cropped, straightened and exposure adjusted
Old 09-04-2017, 09:55 AM   #5
Rewards Points: 798
Even Ray Charles could see that (post #3).
brian john and glen1971 like this.
Old 09-04-2017, 10:21 AM   #6
Rewards Points: 1,360
That looks warm. You should pour a bottle of water on it to cool it down.
brian john, emtnut, splatz and 1 others like this.
Old 09-04-2017, 10:27 AM   #7
Band Member
emtnut's Avatar
Rewards Points: 1,860
I'd touch it first, to see if it's hot, before you pour water on it.
The steam is not good for it
Old 09-04-2017, 11:07 AM   #8
sbrn33's Avatar
Rewards Points: 3,490
Looks like you scanned it anyway. Price gouger.
Majewski likes this.
Old 09-04-2017, 11:12 AM   #9
I pulled it from an email an employee sent me. The building engineer did not want to act on this issue and he wanted to know what to do.
sbrn33, Jarp Habib and Majewski like this.
Old 09-04-2017, 12:08 PM   #10
Rewards Points: 17,765
Tell him it would be very James Dean'ish of him if he calmly bent over and lit his cigarette with it.....
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 09-04-2017, 02:14 PM   #11
Rewards Points: 3,052
Considering the amount of general hackery in that panel, I'm not surprised by the loose lug........lol.
Old 09-04-2017, 02:20 PM   #12
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
That is jacked up.
Old 09-04-2017, 04:05 PM   #13
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 126
I can't read the little yellow sticker.. Can you reach in there and get it?
Cowboy words of wisdom.
Old 09-04-2017, 07:22 PM   #14
Rewards Points: 274
Looks like an energy management set up with 480/277, If wires are marked right they show 480/3 phase is 4th wire on left supposed to be a neutral for 277? Those taps are jacked. Is this system supplying Parking lot and wallpack lighting. Looks that way to me if not turn everything on and get it hot, light a cigarette and sit back and think. When you're done with cigarette bang your head against the wall three times, it always workes for me.
seriously though can you give some more info. Forget the thermal, you have eyes check in and out voltages and connections on terminals as well. Use your nose also, cause it smell like a bad contactor to me. I don't know if you are serious about this or not but be sure no one has a BBQ hooked up.
GeneC is offline   Reply With Quote
Old 09-04-2017, 08:34 PM   #15
480/277 VAC 3 phase 4-wire general purpose lighting panel commercial office building.
The neutral termination connector was loose of the neutral bus.
Old 09-05-2017, 04:03 AM   #16
Rewards Points: 1,500
Don't fret !
A bit of electrical tape will fix it !
dmxtothemax is online now   Reply With Quote
Old 09-05-2017, 12:01 PM   #17
LuckyLuke's Avatar
Rewards Points: 546
Just put the cover back on for:
A) It can't really be a problem if you can't see it
B) The breeze it's getting will only feed flames
or
C) Say all is good and walk away as the building engineer that did not want to act on this issue knows more than you
It's not that I am afraid to die, I just don't want to be there when it happens.
LuckyLuke is offline   Reply With Quote
Security Camera System Switched General Electrical Discussion 23 08-04-2017 08:41 PM
Parameters for permits for security camera systems in BC? Islander Canadian Electrical Forum 7 04-24-2017 01:55 PM
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 05:20 PM
Milwaukee inspection camera drspec General Electrical Discussion 12 11-20-2016 05:54 PM
I need a scope with a smaller camera head NDC Tools, Equipment and New Products 18 10-12-2016 12:05 AM
