Which do you trust more? (Grounding vs. GFCI) - Electrician Talk - Professional Electrical Contractors Forum
Old 02-09-2015, 12:16 AM   #1
MTW
Rewards Points: 10,228
Default Which do you trust more? (Grounding vs. GFCI)
1) An electrical system that relies on solid equipment bonding (grounding)
2) An electrical system that relies on GFCI protection
Old 02-09-2015, 12:19 AM   #2
Very Long Vacation
Rewards Points: 5,262
1) a good ole EGC.
A GFCI can fail, it doesn't stop shocks outside of electrocution; but it does make for a nice back up should an EGC fail.
Now, the best installations have both 1 and 2, both for safety and fire protection.
The Following 2 Users Say Thank You to meadow For This Useful Post:
Expediter (02-13-2015), MTW (02-09-2015)
Old 02-09-2015, 12:38 AM   #3
Rewards Points: 3,120
In my opinion, a solidly grounded system is far better than a GFI.
I've seen way too many GFIs fail, and most failure modes are fail to trip during an actual ground fault.
Also, a grounded system is proactive while a GFI is reactive. In order for a GFI to trip, a fault has to have already occurred. Then, once it senses the fault, it will trip.....usually.
A system ground will conduct current instantly.
On the plus side of a GFI, they will work with no ground present. A grounded system with an open ground isn't grounded at all.
MTW (02-09-2015)
Old 02-09-2015, 01:01 AM   #4
220/221's Avatar
Rewards Points: 4,124
I have tested a GFCI recep and I trust them.
The system and the grounded demo hammer didn't protect me from a frayed spot on the cord but the GCFI did.
The Following 2 Users Say Thank You to 220/221 For This Useful Post:
jarhead0531 (02-09-2015), shocksystems (02-11-2015)
Old 02-09-2015, 02:41 AM   #5
Rewards Points: 1,464
Don't you check your cord and plug on tools you use.? Any tools from the shop are used and put away for the next guy.
Old 02-09-2015, 06:15 AM   #6
LawnGuyLandSparky's Avatar
Rewards Points: 172
If a cord is damaged to the point where there is exposed copper, it should have been cut off and the tool tagged defective about 100-150 uses ago.
Old 02-09-2015, 06:46 AM   #7
Rewards Points: 14,714
I am reminded of a scene from My Cousin Vinny, it's a trick question.
Why is it a trick question?
Let's see, GFCI stands for Ground Fault Circuit Interrupter. Well if you don't ground the electrical system, there will never be a ground fault (unless two separate conductors get a fault to ground at the same time) so a GFCI won't be needed (usually).
So, a GFCI is a solution to one of the problems created by using solidly grounded electrical systems.
Did I pass the test?
The Following 3 Users Say Thank You to hardworkingstiff For This Useful Post:
cuba_pete (02-09-2015), dronai (02-14-2015), RIVETER (02-10-2015)
Old 02-09-2015, 09:15 PM   #8
220/221's Avatar
Rhetorical question?
Old 02-09-2015, 09:18 PM   #9
I own stock in FotoMat!
Rewards Points: 6,520
Given that GFCI's are designed, and required to protect, receptacles only (not circuits like AFCI's are), I'd say the good old stand-by.... the ECG.
Old 02-09-2015, 09:22 PM   #10
MTW
No trick at all. The question is which do you trust, not which is better. Given the choice between a system with all equipment bonding in place, I would choose that over a GFCI protected system that relies on electronics that can fail.
The Following User Says Thank You to MTW For This Useful Post:
micromind (02-09-2015)
Old 02-09-2015, 09:22 PM   #11
Retired Account
Rewards Points: 14,650
If i touch a grounded xfomer i'm safe.
If i touch a grounded meter i'm safe
BUT, if i stretch my wings out to touch each, am i still safe??
Old 02-09-2015, 09:39 PM   #12
When it was my turn to do the quarterly assured ground inspection on cords and tools, I wasn't suprised at how many ground pins were missing from the plug.
Old 02-09-2015, 11:09 PM   #13
MTW
This bobelectric guy is the best.
Old 02-09-2015, 11:15 PM   #14
A properly grounded system all the way.
I have, like some others posted, had GFCI's fail.
Never trust electronics over a solid (or stranded) wire.
The Following 3 Users Say Thank You to guest For This Useful Post:
dronai (02-14-2015), micromind (02-09-2015), MTW (02-09-2015)
Old 02-10-2015, 02:31 AM   #15
Very Long Vacation
You should see most IEC RCDs But even then, those can fail.
guest (02-10-2015)
Old 02-10-2015, 02:54 AM   #16
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
before cordless drills, breaking off the ground pin was the only way to drill energized bus bars.
Old 02-10-2015, 05:45 AM   #17
Now that's working hot ! No Thanks.
The Following 4 Users Say Thank You to bobelectric For This Useful Post:
220/221 (02-10-2015), B-Nabs (02-15-2015), hardworkingstiff (02-10-2015), Steve W (02-12-2015)
Old 02-10-2015, 06:25 AM   #18
I think you missed my point. The only reason you need a GFCI is because you have a grounded system. Without a grounded system, the shock hazard drops tremendously. I believe that's the main reason they use isolated ground systems in operating rooms, to significantly reduce shock hazards.
If you don't have a grounded system, you really don't need a GFCI. It's not a choice of A over B, it's you need B because of A.
The Following User Says Thank You to hardworkingstiff For This Useful Post:
Dennis Alwon (02-15-2015)
Old 02-10-2015, 01:29 PM   #19
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Gfci protect people grounding protects equipmemt.
Full time Bovine Scatologist.
Old 02-10-2015, 02:19 PM   #20
220/221's Avatar
So, tools are grounded to protect the tool?
I don't think you thought that one through.
Trust your gut. 99cents Business, Marketing, and Sales 10 06-24-2014 10:00 AM
Trust your intuition... 99cents Business, Marketing, and Sales 6 07-03-2013 06:43 PM
Do you always trust your instincts? Magnettica General Electrical Discussion 38 07-08-2011 10:29 PM
Never trust a contractor Bob Badger Off Topic (Non Trade) 3 08-10-2010 02:49 PM
losing trust 3phase General Electrical Discussion 14 04-24-2008 09:42 PM
