Does anyone here have a lot of experience with high noise environments? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-11-2015, 04:44 PM   #1
NC Plc's Avatar
Rewards Points: 7,888
Default Does anyone here have a lot of experience with high noise environments?
I know at least a few of you do, every electrical topic has at least one expert on here.
Anyway, I'm having an electrical noise issue so I am replacing a missing piece of tinned copper shielding sleeve and a drain wire. My question is what's the best way to connect the shielding that is already there to the shielding I am buying? Solder? My assumption is that as long as the connection between the two pieces of shielding is solid enough and the drain wire is properly sized, it will be fine.
My boss isn't 100% sure so I am researching it, I figure asking here while I look around for answers should speed things up.
Last edited by NC Plc; 02-11-2015 at 07:12 PM. Reason: I can't stand double negatives.
NC Plc is offline   Reply With Quote
Old 02-11-2015, 05:18 PM   #2
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Yes 3 kids under 5
Full time Bovine Scatologist.
The Following 7 Users Say Thank You to captkirk For This Useful Post:
8V71 (02-12-2015), CADPoint (02-11-2015), chicken steve (02-11-2015), Cow (02-12-2015), eric7379 (02-13-2015), five.five-six (02-11-2015), glen1971 (02-11-2015)
Old 02-11-2015, 05:31 PM   #3
Retired Account
Rewards Points: 14,650
wha.....? ~CS~
Old 02-11-2015, 05:48 PM   #4
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Originally Posted by NC EET View Post
I know at least a few of you do, I doubt there is an electrical topic that no one on here is an expert on.
Rock solid connections are a must.
What are you picking up the electrical noise with?
Old 02-11-2015, 06:24 PM   #5
NC Plc's Avatar
One section consists of 3 wires going to an RTD sensor, the second section consists of 3 wires going to a magnetic pickup sensor.
My idea is to put a small metal piece over the wires and under the shielding/bleed wire and solder the two pieces of shielding together.
Old 02-11-2015, 06:37 PM   #6
Sparks fly from my finger
Jhellwig's Avatar
Location: Where you live. Feel free to be as specific as you like. THANKS!
Rewards Points: 4,677
Only ground one end of the shield. Don't run the rtd in the same conduit as the switch.
Why is part of the shielding missing?
Old 02-11-2015, 07:01 PM   #7
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
more details ? Is this a new apparatus that is ill equipped for noise rejection in the ckt or something that has been jerry rigged ?
Old 02-11-2015, 07:07 PM   #8
NC Plc's Avatar
They're not in conduit, they're wires that come out of a rail that cannot be replaced. All sensors have dedicated shielding and are separate.
The shielding is missing because of age, part of the insulation and then the braided shielding wore off for some reason, I don't know why but it was roughly a 6" section. Then heat caused an issue and a large section of multiple wires had to be replaced, but they were not replaced with shielding just wires. I was not here when the shielding was removed, I am just getting it put back into place. It's been a great learning experience and I ordered some books on EMI, it's an interesting subject. I'm also going to pick up a book about harmonics.
I have to get this fixed as soon as possible because I have a cabinet and VFD to install and this is holding up that project.
It's old wiring that was ignored for a long time, I explained a little more above.
The rail that these wires go into can not be replaced, that's a $20,000 no-no. They are hardwired into this rail.
Old 02-11-2015, 07:19 PM   #9
Senior Moment
drsparky's Avatar
Rewards Points: 44
Jhellwig has it spot on, only ground one end (usually the supply end) of the shield.
Old 02-11-2015, 07:21 PM   #10
NC Plc's Avatar
Yea that will be the end coming out of this rail. The sensors do not ground, they have a rubber stopper in their plugs where the shielding terminates at the end.
Honestly, I had no idea why that rubber was in the plug for the longest time. Now I know.
Old 02-11-2015, 07:22 PM   #11
wildleg's Avatar
well, emi on something as simple as an rtd could probably fixed by something as simple as the right noise filter (capacitor).
Old 02-11-2015, 10:07 PM   #12
Ty Wrapp's Avatar
Rewards Points: 2,044
Maybe you can find something here...
http://www.electricmotioncompany.com/
Ty Wrapp is offline   Reply With Quote
Old 02-12-2015, 02:36 AM   #13
Jlarson's Avatar
Rewards Points: 340
We use shielded heat shrink to repair damaged sensor cables in certain cases.
Old 02-12-2015, 03:04 AM   #14
Data Tech/Apprentice.
Rewards Points: 22
Ive never seen that, is it just a drain or a complete enclosure of foil?
Old 02-12-2015, 10:09 PM   #15
Rewards Points: 1,004
In my most considerable experience the shielding needs not to be continuous as long as the drain wire is, and as said before make sure it is only grounded at one end so you don't get a ground loop.
An RTD is generally pretty good at not being susceptible to outside interference, rfi, emi or harmonics, especially if not near a noisy source as you say.
Disconnect the white wires and ohm them to each other, they should read zero or there about as they are connected at the source, the second white is only used for voltage drop compensation on extended lead lengths. Short runs don't need 3 wire RTDs.
If your controller does not accept a two wire RTD then just jumper the terminals where the 2 white go and only connect one white at a time to see if there is a difference.
If you have the typical 100 ohm RTD then each separate white wire will read approx 100 ohms to the red wire depending on the probes temperature. Also check if any of the 3 wires are grounded, verify that your probe is not internally grounded as some are.
What is the exact nature of your problem, how long is the run? personally I have not seen noise on an RTD in the several thousands that I have worked on outside of a bad connection that is..
xpertpc is offline   Reply With Quote
Corrosion - Extreme Coastal Environments coledar General Electrical Discussion 2 10-09-2014 06:02 PM
Continuity Tester for LOUDER environments... Miller6386 Tools, Equipment and New Products 10 06-18-2014 12:23 AM
Accessing electrical panels in light manufacturing environments henderson14 Commercial Electrical Forum 12 06-24-2013 12:47 PM
Survey for electricians working in hazardous environments 5circles General Electrical Discussion 1 07-28-2011 12:42 AM
Electricians working in hazardous environments 5circles General Electrical Discussion 7 07-05-2011 12:18 AM
