Does the breaker have to match panel? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-18-2015, 04:44 PM   #41
Rewards Points: 86
Heard some one discussing this before about using different breakers for different panels.
Seems that someone said it was against code. Show me the reference in the code book please? Panels have a U/L listing, breakers have a U/L listing.
b-cap is offline   Reply With Quote
Old 02-18-2015, 04:53 PM   #42
Rewards Points: 1,830
The reference is 110.3(B)
(B) Installation and Use. Listed or labeled equipment
shall be installed and used in accordance with any instructions
included in the listing or labeling.
hardworkingstiff (02-18-2015)
Old 02-18-2015, 05:13 PM   #43
220/221's Avatar
Rewards Points: 4,126
Does the breaker match the panel?
This is my new "Does the carpet match the drapes" ^
The Following 8 Users Say Thank You to 220/221 For This Useful Post:
51360 (02-20-2015), BuzzKill (02-18-2015), electricdrummer (02-18-2015), five.five-six (02-18-2015), mcclary's electrical (02-18-2015), millelec (02-22-2015), samgregger (02-21-2015), Vintage Sounds (02-18-2015)
Old 02-18-2015, 05:32 PM   #44
The_kid's Avatar
Rewards Points: 12
I will use this one day.
The_kid is offline   Reply With Quote
The Following User Says Thank You to The_kid For This Useful Post:
Old 02-18-2015, 06:16 PM   #45
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Originally Posted by b-cap View Post
Strange to me all paneland breaker mfgs. make breakers for their competitors products. Except square D, QO panels and Cutler Hammer CH.
Wrong. Cutler hammer makes a breaker that fits qo. Bad thing is, it cost more than qo, and doesn't have a trip indicator.
Old 02-19-2015, 10:50 AM   #46
Rewards Points: 86
You are correct, something about the patent expiring on the Q/O.
Old 02-20-2015, 12:12 PM   #47
Rewards Points: 124
I've always thought that the breaker has to be listed for the panel other wise use the same brand breaker as the panel. Some inspectors are just more on the ball than others.
Mike
Circuit Tracer is offline   Reply With Quote
Old 02-21-2015, 07:47 PM   #48
Rewards Points: 88
We install all Siemens products in all of our new construction, but the HVAC contractor has caused a red tag a few times because he insists upon installing Eaton brand beakers in our panels. His excuse is "they fit and they are cheaper" even after a fail. The first time I tried to educate him and the builder his response was to download the UL listing from the internet and tape it to the front of the panel neither I nor the inspector were impressed. Even after all of this he still installs Eaton and most inspectors don't notice. Sometimes you can't fight city hall.
I am an Electrician....not a magician.....
Lectric is offline   Reply With Quote
Old 02-21-2015, 08:17 PM   #49
Can't Remember
Rewards Points: 562
While argued about here, if he installs the Eaton CL breakers, he has a leg to stand on. Regular BR, not so much.
Old 02-21-2015, 08:19 PM   #50
Rewards Points: 88
Pretty sure they are the regular BR as noticed by an savvy inspectors but I will check at the next house.
Old 02-21-2015, 08:26 PM   #51
Can't Remember
Rewards Points: 562
CL breakers are likely more expensive than a Siemens QP. I didn't think BR was listed for anything other than BR panels, Westinghouse, Bryant etc.
Lectric (02-22-2015)
Old 02-21-2015, 10:27 PM   #52
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
110.3b as I said before. Read it learn it love it.
Old 02-22-2015, 01:54 AM   #53
Going_Commando's Avatar
Rewards Points: 1,542
Why is the HVAC contractor wiring stuff to your panels? Isnt that what electricians are for?
The Following 2 Users Say Thank You to Going_Commando For This Useful Post:
amishman Elec (02-22-2015), NacBooster29 (02-22-2015)
Old 02-22-2015, 06:34 PM   #54
Rewards Points: 88
The builder we work for likes things in neat packages, that being said HVAC is responsible for all of his wiring. Also they often finish out "especially in winter" before we do and the builder likes the heat on.
Old 02-22-2015, 06:44 PM   #55
Here is the issue. UL listed the panel for the manufacturer breakers only as that was all they tested them for. So UL says only manufacturer breakers
Then UL or some 3rd party testing lab tests these other manufacturers breakers and says they are safe to install in those panels. So now we are in a pickle.
I know around here there has been some movement to not allow these other breakers as they do not follow the 110.3(B) rule.
Are they safe-- IMO, absolutely but that doesn't help you much if the authority having jurisdiction turns it down.
The Following 3 Users Say Thank You to Dennis Alwon For This Useful Post:
Chris1971 (02-22-2015), hardworkingstiff (02-22-2015), papaotis (02-22-2015)
Old 02-22-2015, 09:29 PM   #56
MTW
Rewards Points: 10,272
Only a hack or DIYer would mix and match breakers.
Old 02-22-2015, 09:40 PM   #57
Rns
Rewards Points: 29
It clearly states right here I can use Siemens in all of these panels! Must be ok.
Rns is offline   Reply With Quote
The Following 2 Users Say Thank You to Rns For This Useful Post:
chicken steve (02-23-2015), mcclary's electrical (02-22-2015)
Old 02-22-2015, 09:42 PM   #58
MTW
It says fuse boxes, that's even more ridiculous.
But, at least they aren't dumb enough to put Square D on that list.
Old 02-22-2015, 09:57 PM   #59
amishman Elec's Avatar
Rewards Points: 44
Notice that Siemens made their own list.
amishman Elec is offline   Reply With Quote
Old 02-22-2015, 09:57 PM   #60
Rewards Points: 2,950
Is this a Joke? I hope some HD electrical aisle delinquent didn't print this up and hang it up for real.
The Match Game stuiec Off Topic (Non Trade) 14 03-28-2014 11:21 PM
Circuit Breaker Panel maintenanceman NEC Code Forum 1 09-18-2013 10:58 PM
Panel Schedules don't match the drawings abelect General Electrical Discussion 24 08-18-2013 12:29 PM
India Breaker Rating in Residential Breaker Panel foreverof Commercial Electrical Forum 3 03-19-2013 08:26 PM
Sub panel Mix and match Chris1971 General Electrical Discussion 9 01-27-2011 12:23 AM
