Does this exist? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 2 Post By 99cents
  • 5 Post By samgregger
  • 1 Post By 99cents
  • 1 Post By MechanicalDVR
  • 1 Post By 99cents
Old 08-22-2018, 05:53 AM   #1
Default Does this exist?
Looking for a wireless LED dimmer switch.
We managed to install 17 can lights in two different rooms by only making 2 small holes. There is a box in the center of one of the rooms that has constant power with a switch loop to a single pole switch, but the homeowner wants to control different rows of lights with different switches. We’d like to avoid anymore patch work for the switching. Does anyone make a wireless dimmer for LEDs, if so does it actually work reliably?
Travvy is offline   Reply With Quote
Old 08-22-2018, 06:07 AM   #2
Rewards Points: 14,293
Lutron
MechanicalDVR and Max C. like this.
Old 08-22-2018, 10:42 AM   #3
Rewards Points: 844
TCP had a connect lamp that was ip addressable. I dont know if it still available or there is another product like that.
Old 08-22-2018, 05:33 PM   #4
Do either of them work with power at the light only?
Old 08-23-2018, 10:42 AM   #5
Rewards Points: 1,369
Maybe I'm just old, but I would rather just run the wire and patch the drywall than find an IP addressable programmable LED dimmable retrofit 2.4ghz remote controllable app configurable module, install it, then the over complicated thing stops working for some reason because it looses GPS sync or some such crap and it costs me service calls.
The Following 2 Users Say Thank You to samgregger For This Useful Post:
LARMGUY (08-23-2018), MechanicalDVR (08-23-2018)
Old 08-23-2018, 10:51 AM   #6
Rewards Points: 844
The TCP does, but buyer beware. We had lousy tech support and trouble
Old 08-23-2018, 11:01 AM   #7
In its simplest form, the Lutron Caseta replaces a single pole switch. The wireless remote is a battery powered device that can be stuck to the wall with a cover plate. If you want smartphone control, a bridge is available.
I have never had callbacks on Lutron and use it a lot.
Old 08-23-2018, 11:19 AM   #8
Rewards Points: 3,062
Confucius says:
High tech is often high trouble!
tmessner likes this.
Old 08-23-2018, 11:26 AM   #9
Confucius says:
About as high tech as your TV remote.
Old 08-23-2018, 11:56 AM   #10
I'm talking the smartphone compatible models.
Do you really need to dim your lights from work?
Old 08-23-2018, 12:17 PM   #11
The bridge is a simple plug-in device. It means nothing to me if the customer wants to play with apps.
Old 08-23-2018, 12:31 PM   #12
Dark Knight's Avatar
Rewards Points: 120
Lutron Caseta is fantastic. You do however still need a wire to the switch. I suppose you could stick the dimmer in the attic beside the JB and put the remotes wherever you want down below. That would likely work very well. But is it really that hard to fish a wire down the wall from the attic? Exterior walls are tough but if you can find an interior wall it’s pretty easy most of the time.
Dark Knight is offline   Reply With Quote
Old 08-23-2018, 12:37 PM   #13
Rewards Points: 120
Well when your kids are constantly leaving every light in the house on it comes in handy. Plus it does a lot of other things as well, like timers, geofencing (lights come on when you pull into the driveway), scene and mood control, etc. Not for everyone, but for those who like that kind of stuff it works really well.
Edit: fixed it.
Old 08-23-2018, 05:08 PM   #14
I appreciate everyone’s input. I’m not sure how I feel about it either. As part of a whole home smart lighting system I understand it. But one wireless switch to avoid a small hole, when you already have two other holes, is impractical. The customer is actually the one who asked about it. We ended up running a wire down to a switch, but it’s a nice to know the option is available.
Old 08-23-2018, 09:35 PM   #15
Rewards Points: 797
It's a real simple install and they work well. There is a module that you install at your switch leg (which also acts as a wall switch) and then a simple remote that can either be used hand held or mounted to the wall where it looks exactly like a decora switch. And then you can mix it up with additional remotes etc. if you want.
Gnome is online now   Reply With Quote
Old 08-24-2018, 01:28 AM   #16
NDC
NDC's Avatar
Rewards Points: 2,422
Curious to know if you guys in Canada are passing inspections with these casetas where a switch is required by code? Like finishing a basement and adding a 3 way switch with Pico.
Old 08-24-2018, 02:15 AM   #17
Rewards Points: 6
Alberta standata was updated in February to recognize all wireless switches as an acceptable means of switching. No problems using Pico's anymore.
aduck337 is offline   Reply With Quote
why doesn't 4/2 NM cable exist? mikewillnot Residential Electrical Forum 39 06-09-2018 07:10 PM
Do 2 pole stab lok AFCI breakers exist? Islander Canadian Electrical Forum 28 03-21-2018 09:52 PM
Do Ac Line Splitters exist in the UK davedave Tools, Equipment and New Products 26 06-28-2017 08:36 PM
