Does High voltage require a "hot work permit" - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 3 Post By Lone Crapshooter
  • 1 Post By HackWork
  • 1 Post By bus01010
Old 12-06-2017, 09:16 AM   #1
Default Does High voltage require a "hot work permit"
Just curious about a question I recently came across, does working on high voltage require a "hot work permit"?
Thanks
Mcarthur00
Mcarthur00 is offline   Reply With Quote
Old 12-06-2017, 09:31 AM   #2
Rewards Points: 2,236
Generally HOT WORK refers to welding burning cutting grinding use of spark producing tools not working on energized circuits.
To work on energized circuits other than troubleshooting there is a certain criteria that must be met and several signatures are required.
Then only then you will be issued a ENERGIZED WORK PERMIT as well as a safe work permit.
This is in a industrial setting.
LC
Old 12-06-2017, 09:41 AM   #3
Rewards Points: 1,651
I sell Hot Work Permits on the side. They are universal and have no expiration date. $1,000 each, PM me for payment options.
active1 likes this.
Old 12-06-2017, 10:43 AM   #4
Rewards Points: 3,062
I see!
Old 12-06-2017, 10:56 AM   #5
I see!
That's strike 1.
Old 12-06-2017, 12:46 PM   #6
Southeast Power's Avatar
Rewards Points: 8,728
Thanks
Mcarthur00
Cletis, did you move to Canada??
Old 12-06-2017, 12:47 PM   #7
$1,200 Canadian
Old 12-06-2017, 01:17 PM   #8
So no hot working permit needed, thanks guys!
Old 12-06-2017, 01:33 PM   #9
Rewards Points: 256
How high is high?
Old 12-06-2017, 02:09 PM   #10
trentonmakes's Avatar
Rewards Points: 138
They made me use a hot work permit for a heat gun before
4 hour fire watch when work was done
Texting and Driving
Old 12-06-2017, 02:30 PM   #11
Texting and Driving
You should have came to me for the permit.
active1 likes this.
Old 12-06-2017, 03:09 PM   #12
Rewards Points: 350
Assuming you are using the colloquial term "hot work" to mean "energized work", the NFPA 70E does not differentiate for voltage levels. Energized is energized, meaning you have voltage potential of over 50V on at least one circuit in the system. Doesn't matter how much higher than 50V is is, or even if it is AC or DC.
In a lot of cases though, you must be specifically qualified to perform work on any system above 1000V (Medium Voltage or higher), but that type of work is almost NEVER allowed to be performed "hot", so getting an energized work permit on MV or HV equipment is all but impossible (unless you are a utility lineman).
Old 12-06-2017, 05:28 PM   #13
Rewards Points: 16
Somebody throw that man a heat blanket and a fire extinguisher! I used to be a pipefitter. Hot work refers to welding or anything else that could reasonably catch fire. ie welding, brazing, oxy acetylne cutting.
glen1971 likes this.
bus01010 is offline   Reply With Quote
Old 12-06-2017, 05:29 PM   #14
Rewards Points: 16
But then again you might have to get a hot work permit for cad welding. Depends on where you're working and the regulations of the plant / site.
Old 12-06-2017, 06:14 PM   #15
Rewards Points: 138
This!
Some places go by the letter and the safety nazis go overboard!
They have thier own safety code and regulations
Texting and Driving
Old 12-06-2017, 08:28 PM   #16
Rewards Points: 1,230
If you mean energized circuits then no at least in my area. We now need to get hot work permits when we are welding or doing anything that causes sparks in Boston because several years ago a fire was started by welding sparks that landed on a roof of a brownstone next door to the welding and it caused a huge fire that killed several fire fighters.
On jobs with pan decking we no longer cut away pan decking with a torch when installing riser pipes in large high rises instead choosing to lay down insulation to keep out concrete, then cut away pan decking with a demo blade and use those Hilti 2 hour fire rated sheets. No need to pay for a fire fighter to sit and watch you work this way
bostonPedro is offline   Reply With Quote
Old 12-06-2017, 08:32 PM   #17
Didn't some ladies cow kick over a lantern in Chicago a while back?
Old 12-08-2017, 08:48 AM   #18
Rewards Points: 16
heil safety say the safety Nazis
Old 12-10-2017, 08:34 AM   #19
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
hot work is job specific and depends on the facility/ahj.
when we did gas plant work for DOT, anything that could cause any spark was hot work. same applied for gov work on munitions sites.
High Priced Work Clothes mdnitedrftr Tools, Equipment and New Products 59 11-02-2017 09:43 PM
So you want to become an apprentice in Canada... Vintage Sounds Electrician Apprentice Forum 52 08-07-2017 04:59 PM
Work in SW Virginia andytheham Looking For Work 0 03-19-2016 05:43 PM
High Voltage Splicing JOHNNYARCNSPARK General Electrical Discussion 4 03-17-2016 06:19 PM
