Does Siemens replace Murray? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 3 Post By MechanicalDVR
  • 3 Post By HackWork
  • 1 Post By Bzzzzzt
Old 04-22-2017, 10:47 AM   #1
Rewards Points: 554
Default Does Siemens replace Murray?
I have a Murray LC230PC panel with a burnt bus. Does Siemens make a replacement for this, with copper bus? Customer doesnt want to pay to replace the whole panel.
John M. is offline   Reply With Quote
Old 04-22-2017, 12:33 PM   #2
Rewards Points: 1,360
I don't know, but Cutler Hammer makes listed replacement guts for existing panel cans. But that approach might be just as pricey as the replacement panel.
Old 04-22-2017, 12:40 PM   #3
Rewards Points: 3,078
I think the closest you'll find is a Murray LC3040B1200CU. You would have to check dimensions and door fit. This is a new panel. The only thing he'll save is the labor of swapping out the tub.
LC = load center
30 = 1" spaces
40 = max circuits
B = main breaker
1= single phase
200 = amperage
CU = copper bus
Greg
Old 04-22-2017, 02:56 PM   #4
Rewards Points: 3,006
Sometimes they have to bite the bullet and do what needs to be done.
Old 04-22-2017, 03:57 PM   #5
Rewards Points: 1,243
I just had a crotchety old geezer replace a panel for me in 3 hours while I threw wirenuts at him.
Don't let the customer's unwillingness to pay for a new panel make you do hours worth of free work finding new guts.
frenchelectrican, nrp3 and telsa like this.
Old 04-23-2017, 03:44 PM   #6
Rewards Points: 76
When I run into this situation I usually go to the supply house and purchase a panel of similar construction with the same physical panel can size and just pull the guts out of it and put them in the existing panel can. Lots of times these new panels come with a few extra breakers. I have discovered that purchasing panel components is often more expensive than a whole panel. As long as you're not trying this with some old FPE stab-lok panels it's usually fairly easy to find a suitable replacement.
samgregger likes this.
Bzzzzzt is offline   Reply With Quote
Old 04-23-2017, 10:13 PM   #7
Rewards Points: 320
Siemens owns Murray, there is no difference other than the name. So yes, they are 100% interchangeable. If you can find a Siemens interior that matches, use it.
Murray breakers reliable? Hanford43 Residential Electrical Forum 11 04-06-2017 09:52 AM
Siemens BR series load center? rotax91 Residential Electrical Forum 3 10-06-2016 09:46 PM
Murray main panel bonding strap griinder73 General Electrical Discussion 17 07-02-2016 10:42 PM
is it code requiring to replace an old receptacle without a ground with a GFCI plug? mike883 General Electrical Discussion 48 06-21-2016 11:52 AM
how to replace dc motor with ac motor power calculation waff PLCs, VFDs, Motors and Controls 10 03-31-2016 03:47 PM
