Door Jamb Switches - Electrician Talk - Professional Electrical Contractors Forum
Old 04-29-2014, 11:26 PM   #1
Rewards Points: 562
Default Door Jamb Switches
Any tips on installing these? I always find them a pain in the ass so I was hoping for some tips. It is new construction. I will be using this type of switch.
Also they have multiple double door closets and they want both doors to be able to turn on lights. Anyone see a code problem with wiring both to the light.
CanadianSparky is offline   Reply With Quote
Old 04-29-2014, 11:30 PM   #2
wendon's Avatar
Rewards Points: 54
I use a motion sensor mounted on the ceiling towards the front of the closet. Works great and if they leave the door open, the light shuts off.
The Following 3 Users Say Thank You to wendon For This Useful Post:
chicken steve (04-30-2014), glen1971 (05-02-2014), The_Modifier (05-02-2014)
Old 04-29-2014, 11:34 PM   #3
Rewards Points: 77
we have used both the door switch ( pain in the ass) and the motion. i really like the motion. however if the home owners gonna leave the doors open the lights will be on as soon as they walk near the closet. the ones we use stay on for about 3 mins after no movement
swissmiss177 is offline   Reply With Quote
Old 04-29-2014, 11:35 PM   #4
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,168
Due to insanely high failure rates in the door jamb switches, we have gone to occupancy instead.
I see no code problem with your proposal.
farlsincharge is offline   Reply With Quote
Old 04-30-2014, 12:36 AM   #5
Yeah. Really sharp????? Oh what the hell are those called???? Those carpenter blade chisel tools. They worked for me.
Chrisibew440 is offline   Reply With Quote
Old 04-30-2014, 12:46 AM   #6
Classic_Toby's Avatar
We use a low voltage, magnetic style called "better switch".
The controller is mounted in the fixture or j box then low voltage wire is ran to the door. Does not have to be in the hing jab. We mount them on top. Also you can order as many of the switch parts as you want to operate one controller.
Classic_Toby is offline   Reply With Quote
The Following 2 Users Say Thank You to Classic_Toby For This Useful Post:
bryantobando (04-30-2014), Dash Dingo (04-30-2014)
Old 04-30-2014, 07:16 AM   #7
Rewards Points: 648
Multi-tool with the small blade that is about 1/4" wide.
We install a lot of them, but I do my best to talk the customer in to an occupancy/motion sensor instead. Especially when there are two doors, the client doesn't want to pay for two jamb switches when the motion will do the same thing.
svh19044 is offline   Reply With Quote
Old 04-30-2014, 07:40 AM   #8
Rewards Points: 4,114
I don't know who, but someone makes a round door switch with a cylindrical box. Much easier and cleaner install.
Old 04-30-2014, 07:47 AM   #9
Retired Account
Rewards Points: 14,650
LV to a RIB relay has been my shtick for a while....~CS~
Old 04-30-2014, 08:19 AM   #10
http://www.betterswitch.com/1.html
Here is the website for what we use.
The Following User Says Thank You to Classic_Toby For This Useful Post:
Old 04-30-2014, 08:57 AM   #11
wendon's Avatar
Rewards Points: 54
If they're coming on when they walk by the closet, you're not mounting them in the right place. If you mount them on the ceiling about 6" from the front wall, they have to stick their arm (or something) into the closet to turn the light on.
Old 04-30-2014, 12:37 PM   #12
Rewards Points: 562
Do you put the wiring box in during rough in stage or do it all after?
Old 04-30-2014, 01:40 PM   #13
Rewards Points: 274
Better switch with a magnetic contact
ecelectric is offline   Reply With Quote
The Following User Says Thank You to ecelectric For This Useful Post:
Classic_Toby (04-30-2014)
Old 05-02-2014, 01:21 AM   #14
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 390
se a P.I.R. motion combo switch.
Old 05-02-2014, 06:54 AM   #15
Rewards Points: 1,072
Carpenters hate those things. I usually notch the stud about half way thru part way down making sure I miss the hinges. I think hinges are about 10" or so down so check with the builder.
I just run my wire out and hang the box on the wire so the trim carpenters have it when they get there.
CanadianSparky (05-02-2014)
Old 05-02-2014, 07:12 AM   #16
Hmacanada's Avatar
Originally Posted by Dennis Alwon
Carpenters hate those things. I usually notch the stud about half way thru part way down making sure I miss the hinges. I think hinges are about 10" or so down so check with the builder. I just run my wire out and hang the box on the wire so the trim carpenters have it when they get there.
Me too, usually drill through rough opening with a 1" hole saw so they ,or I don't have to get to close to the wire when chiseling out.
Pop a box connector on and slide her back in place
Hmacanada is offline   Reply With Quote
The Following User Says Thank You to Hmacanada For This Useful Post:
Old 05-02-2014, 09:14 AM   #17
Rewards Points: 648
We have the contractor pull the wire through the jamb then cut in the box at final. It's never fun, but they have gotten easier.
Years ago, before using the multi-tool, those things sucked a million times more. It was always borderline "is the jamb going to crack"?
The Following User Says Thank You to svh19044 For This Useful Post:
Old 05-02-2014, 09:52 AM   #18
Rewards Points: 10,943
Occ sensors work well. I did have to disable one. Cats running into the closet in the middle of the night woke up the home owners.
Old 05-02-2014, 10:18 AM   #19
Rewards Points: 562
I have talked them into the leviton occ sensor closet lights. It beats installing 15 separate door switches.
Thanks for the advice on installing them though guys...it will hopefully make it easier the next time I have to do them.
Client called a Handyman just to change old 3way switches to Decora Type switches HARRY304E Code Violation Discussion 30 01-27-2014 12:20 AM
Door Hangers HackWork Business, Marketing, and Sales 5 09-08-2013 01:34 AM
Door switches watts77 Residential Electrical Forum 12 04-05-2012 11:55 AM
Getting your name out there, door to door Magnettica Business, Marketing, and Sales 34 11-10-2009 11:38 PM
Where is the door? Kaptan Solo Union Topics 9 04-19-2008 02:33 PM
