Double Transfer Switch Install - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 11-14-2017, 10:02 AM   #21
Rewards Points: 1,537
Originally Posted by RePhase277 View Post
I've driven by jobs I did 15 years ago with no expansion joint and metal straps, and they are still fine, if sunfaded. I know it's OK, and you know it's OK, and BigSquirmy knows it's OK.... but the manufacturers on the code panels, and therefore the guy having "authority", say different.
Funny you mention that. I started using EMT outdoors because I found that after only a few years some of the 1/2" PVC runs I did up to motion lights (about 10-14' of pipe) were all squiggly.
Of course now there are possibilities of rust with EMT so who knows which is best.
Old 11-14-2017, 10:14 AM   #22
Rewards Points: 1,360
Yeah that's going to happen anyway. I always strapped the crap out of PVC to reduce it. I strap PVC more than Chicken Steve straps his service risers, but better looking.
Kevin_Essiambre likes this.
Old 11-14-2017, 01:50 PM   #23
Rewards Points: 1,894
If rust is that much of a concern, could you use galvanize spray?
Old 11-14-2017, 02:36 PM   #24
Rewards Points: 978
This is why I'm curious why the OP, or anyone, would not use EMT
active1 likes this.
cdslotz is offline   Reply With Quote
Old 11-14-2017, 02:38 PM   #25
BigSquirmy's Avatar
Rewards Points: 18
Cause i already had the pvc and everything else was already pvc so why not use it.
Sent from my SAMSUNG-SM-G935A using Tapatalk
BigSquirmy is offline   Reply With Quote
Old 11-14-2017, 02:51 PM   #26
Rewards Points: 26,838
PVC does require straps every 3 feet in this situation.
Other than that, no complaints.
Old 11-14-2017, 03:01 PM   #27
Sure. But I'm not sure if rust is that big of an issue where I am. Just a possibility.
I often see the straps rusted while the pipe is ok on other people's older work.
Old 11-14-2017, 03:02 PM   #28
When I mentioned EMT I was talking about smaller stuff. For any type of service raceway I always use PVC, I've never used EMT for that.
Old 11-17-2017, 06:57 PM   #29
rrolleston's Avatar
Rewards Points: 1,134
Originally Posted by BigSquirmy View Post
Sealing washers
Did you do Myers hubs with sealing washers. I really like Myers hubs for entering and box in the top.
Sent from my SM-S727VL using Tapatalk
Signal1 likes this.
Old 11-17-2017, 09:36 PM   #30
BigSquirmy's Avatar
Rewards Points: 18
No just pvc male adapters with sealing washers. Worked great. I water tested after.
FLIR Pic of transfer Switch under load Moonshot180 General Electrical Discussion 24 08-19-2016 04:45 PM
First transfer switch, gen backup install. 04gixx6 Services and Service Equipment 1 07-15-2016 11:42 PM
Installation Manual for Manual Transfer Switch swimmer General Electrical Discussion 5 06-02-2016 07:07 AM
transfer switch for generator blacknpurplejs General Electrical Discussion 2 02-21-2016 09:17 PM
