The Dreaded Nuetral conductor - Electrician Talk - Professional Electrical Contractors Forum
Old 10-04-2013, 05:35 PM   #1
Rewards Points: 29
Default The Dreaded Nuetral conductor
I got a customer of mine with a 60 amp service in an apartment complex with a $250.00 electric bill. I go to check out his service and I get 15.08 amps on A phase, 13.36 amps on B phase, and 15.15 amps on the neutral with A.C running. I was always taught that the nuetral wire carries the difference of the 2 phase conductors. Any ideas why the neutral current is so high? Voltage was 120 volt from each phase to ground.
whittom is offline   Reply With Quote
Old 10-04-2013, 05:38 PM   #2
rrolleston's Avatar
Rewards Points: 1,134
Was anything else running like a fridge or freezer?
Old 10-04-2013, 05:40 PM   #3
Very Long Vacation
Rewards Points: 5,262
Was the voltage 208 by chance between the 2 phases?
The Following 3 Users Say Thank You to meadow For This Useful Post:
Arc'n'Spark (10-04-2013), Awg-Dawg (10-04-2013), someonespecial (10-04-2013)
Old 10-04-2013, 05:42 PM   #4
Rewards Points: 252
The complex probably uses 208Y/120 with single phase feeders to each apartment. If this is the case and all the load is phase to neutral, the neutral is exactly where it should be, roughly even with the phase conductors.
Arc'n'Spark is offline   Reply With Quote
The Following 2 Users Say Thank You to Arc'n'Spark For This Useful Post:
BBQ (10-05-2013), someonespecial (10-04-2013)
Old 10-04-2013, 05:43 PM   #5
Rewards Points: 252
You type faster than me.
Old 10-04-2013, 05:43 PM   #6
Surge03's Avatar
Rewards Points: 290
is there any other branch circuits other than the A/C? There could be circuits on the same phase sharing a neutral. Is this a single phase service or three phase?
Surge03 is offline   Reply With Quote
Old 10-04-2013, 06:04 PM   #7
Rewards Points: 29
This is a single phase service. Phase to phase was 242.8 volts. Old fuse panel with 5 circuits in it besides the AC. This is a sub-panel being feed from a 60 amp breaker from an old distribution panel.
Old 10-04-2013, 06:25 PM   #8
Rewards Points: 252
Could some of the wiring be intermingled with the neighboring units?
Old 10-04-2013, 06:31 PM   #9
Retired Account
Rewards Points: 14,650
Ever go into apt's with mutual walls & see the world plugged into one....?
Old 10-04-2013, 06:41 PM   #10
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Did you try unplugging the grow lamps?
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
Next72969 (10-05-2013)
Old 10-04-2013, 06:54 PM   #11
I own stock in FotoMat!
Rewards Points: 6,520
Never use the DOLLARS on an electric bill to indicate a problem.
Look at the WATTHOURS. Compare several months of use.....that will tell you if there's an electrical issue.
It could easily be an annual adjustment due to budget billing.
Celtic (10-04-2013), papaotis (10-04-2013)
Old 10-04-2013, 07:01 PM   #12
Very Long Vacation
Is it possible a load could've switched on or off in between the readings?
Old 10-04-2013, 09:43 PM   #13
Rewards Points: 250
someonespecial is offline   Reply With Quote
Old 10-05-2013, 10:11 AM   #14
Rewards Points: 1,006
Test with only 240v load(s), then test with only 120v loads. This may give a more comprehensive picture.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Grounding conductor bow tied to grounded conductor inspectorman2003 General Electrical Discussion 19 05-26-2012 09:31 AM
Neutral conductor to ground conductor measurements megw junky Residential Electrical Forum 7 04-08-2012 08:57 AM
re: on the nuetral problem roach1521 General Electrical Discussion 0 12-02-2010 08:34 PM
Jacuzzi w/no nuetral skinny General Electrical Discussion 5 09-30-2009 12:13 PM
grounding electrode conductor and grounded conductor nolabama Services and Service Equipment 6 01-12-2009 01:51 AM
