dryer receptacle burnt - Electrician Talk - Professional Electrical Contractors Forum
Old 08-06-2013, 02:44 PM   #1
NacBooster29's Avatar
Rewards Points: 1,018
Default dryer receptacle burnt
My cousin called yesterday. Her son was doing laundry when the dryer receptacle started sparking and smoking..
It tripped the breaker eventually.
I didn't notice any loose connections on the wiring side. I'm guessing poor connection with the cord and receptacle is the culprit.
I didn't get a pic but there is smolder marks all up the wall above where the receptacle used to be.
I had to strip it back a foot or so and re mount it higher on the wall.
I would say they were lucky someone was home to notice.. could have been bad.
Old 08-06-2013, 02:49 PM   #2
Never Used Scotchkote
JoeKP's Avatar
Rewards Points: 2,032
Yeah looks kind of worn.
Don't believe me? too bad....
JoeKP is offline   Reply With Quote
Old 08-06-2013, 03:41 PM   #3
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I hear some scientist working deep underground in Virginia are creating a 30 amp DP AFCI breaker as I write.
The Following User Says Thank You to Shockdoc For This Useful Post:
owl (08-06-2013)
Old 08-06-2013, 03:52 PM   #4
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,412
Please check & clean the heating coils in the dryer.
Old 08-06-2013, 04:36 PM   #5
Very Long Vacation
Rewards Points: 5,262
How would that make a difference in terms of what happened to the plug? If air flow is a concern the blower and venting assembly is often an even bigger problem.
Old 08-06-2013, 05:00 PM   #6
The dryer wasn't even running when my cousins son saw it smoking.which is weird but....
Old 08-06-2013, 05:50 PM   #7
Wirenuting's Avatar
I've seen in the past were a dirty heating coil snaps & grounds out. Not enough to trip the breaker, but enough to melt the receptacle.
The OP stated he saw no loose connections, so IMO, start looking for the less obvious.
Old 08-06-2013, 05:59 PM   #8
Very Long Vacation
True, but its more of an issue with age, usually accelerated by those who don't clean the lint trap or have ridiculously long runs to the exterior. Whats sad with most dryers is only one side is protected via high limits/thermal fuses and the other by the motor centrifugal switch which is non temperature dependent. Things get interesting when a ground out happens during a cycle
Old 08-06-2013, 06:03 PM   #9
Wirenuting's Avatar
Your right, and it can be dangerous.. I also hate seeing them darn plastic ducts. Man they smoke quickly..
I moved my fridge once a few years ago. The plug was a melted goo when I went to unplug it. The fridge looked and ran great, until that moment. LoL
Old 08-06-2013, 06:53 PM   #10
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I don't know what difference that would make, since the damn things don't work anyway.
JoeKP (08-06-2013)
Med Bi-Pins Burnt BytheBook General Electrical Discussion 3 07-13-2013 04:02 PM
Burnt out and dragging my a$$ 99cents General Electrical Discussion 17 05-27-2013 11:57 PM
How much burnt meter? Cletis General Electrical Discussion 45 01-22-2013 09:47 AM
Washer and Dryer on the same receptacle?? pawirenut General Electrical Discussion 15 10-15-2010 01:49 PM
Burnt connection kbsparky General Electrical Discussion 24 04-27-2009 08:05 AM
