Duplex : Customer asks for 3 meters - Electrician Talk - Professional Electrical Contractors Forum
Old 02-26-2015, 03:06 AM   #1
Rewards Points: 241
Default Duplex : Customer asks for 3 meters
Hello,
I'm not sure about this. Just got customer request, he has a Duplex, wants service Upgrade (200A) to serve 2 Addresses. 1 Building, split in half.
He wants 3 meters, 1 for unit1, 1 for unit 2, and a 3rd "House meter" for the whole house (both Duplexes).
Perhaps I just don't know this one, but I thought PG&E will only give 2 meters, 1 for each address.
Why would he ask for a "House meter", why not just 2 meters?
onilozay is offline   Reply With Quote
Old 02-26-2015, 03:06 AM   #2
Rewards Points: 241
typo correction, not both "Duplexes", both Units
Old 02-26-2015, 05:22 AM   #3
Rewards Points: 1,508
Maybe he has been stung before by someone
Tampering with the meter
Or at least he's worried about it ?
Could have seen a hyped up media story about it.
Old 02-26-2015, 06:15 AM   #4
cabletie's Avatar
Rewards Points: 1,274
Usually the house meter/panel feeds loads common to both areas that the landlord would pay for, or split the bill with the tenants. The loads could be outside/common area lights, maybe fire alarm panel or laundry room.
The Following 4 Users Say Thank You to cabletie For This Useful Post:
220/221 (02-26-2015), guest (02-27-2015), Imwired (02-26-2015), John Valdes (02-26-2015)
Old 02-26-2015, 07:45 AM   #5
Retired Account
Rewards Points: 14,650
Isn't this some recent code? I'm too lazy to look.....~CS~
Old 02-26-2015, 08:47 AM   #6
jw0445's Avatar
Rewards Points: 1,818
House meter would also pick up well pump, septic pump, dusk to dawn lighting, etc.
Old 02-26-2015, 09:04 AM   #7
Rewards Points: 274
That's the norm around here
ecelectric is offline   Reply With Quote
The Following User Says Thank You to ecelectric For This Useful Post:
Old 02-26-2015, 10:56 AM   #8
Rewards Points: 374
Yup extra meter is common and required above a certain number of units (NEC is two units but there are local exceptions). 210.25(B) requires a separate panel if there are any common area circuits in a building with two or more dwelling units.
Hawkrod is offline   Reply With Quote
The Following User Says Thank You to Hawkrod For This Useful Post:
chicken steve (02-26-2015)
Old 02-26-2015, 11:02 AM   #9
Rewards Points: 274
I had houses with just a 6'by 6' entry hall and that was the only common area but they still wanted the house meter
Old 02-26-2015, 11:18 AM   #10
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Yep I've installed house meters for one single common area light.
Old 02-26-2015, 11:51 AM   #11
Fond of three phase
Rewards Points: 928
It seems to be a common practice, around here as well. Some of these duplexes are only 50-60 years old.
Is there an exemption, if the owner lives in one of the units. Of course, that's always subject to change.
retiredsparktech is offline   Reply With Quote
The Following User Says Thank You to retiredsparktech For This Useful Post:
Old 02-26-2015, 12:39 PM   #12
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,606
Don't get quite a few service changes because of the need for a house meter now. People just leave the existing decrepit service until total failure.
Often it isn't just adding the extra meter and panel, but you have to rewire to get those common loads off of the tenants service. Can get quite pricey with a front stairwell, rear stairwell, outdoor lighting, garage, and basement.
Used to be ok if owner lived there, now that's not good enough.
Many duplexes around here you'll see 2 fixtures where there would normally be only one, each tied to the separate service. Looks ridiculous.
Were you born retaŕded or did you pick that up on your own?
CTshockhazard is online now   Reply With Quote
Old 02-26-2015, 07:16 PM   #13
LawnGuyLandSparky's Avatar
Rewards Points: 172
Around here, a duplex has to be 2 completely independent units, and cannot share any "common area," laundry, hall, boiler, water, cesspool or sewer, etc. Just like 2 single family residences that share a common party wall. Even the basements are separate. When a duplex owner wants a "house meter" it's usually because an illegal apartment or apartments are going into the basement(s).
The Following User Says Thank You to LawnGuyLandSparky For This Useful Post:
Old 02-26-2015, 08:54 PM   #14
Rewards Points: 42
Would you not have to upsize the service feeders to accommodate for the house panel? Assuming each unit will have a 100A panel. Or is there some derating that takes place allowing for the house panel?
Mista Bojangles is offline   Reply With Quote
Old 02-27-2015, 05:08 PM   #15
Sentimental Mental
Pretty unlikely in these situations that the load(s) on the house panel would be large enough to increase the service size.
When adding it to an existing service, the load doesn't really change, just the distribution of the load.
When a customer asks what the problem was.... Speedy Petey Off Topic (Non Trade) 5 12-24-2013 03:14 PM
HI asks a Question Bob Sisson General Electrical Discussion 52 12-22-2012 02:08 AM
When a customer asks... Stab&Shoot General Electrical Discussion 7 02-15-2012 05:38 PM
Just in Case someone asks why you are a member Southeast Power Union Topics 69 05-24-2009 08:56 PM
