Earth bonding for AC units - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 1 Post By HackWork
  • 5 Post By drspec
  • 2 Post By HackWork
  • 1 Post By brian john
  • 3 Post By PlugsAndLights
  • 1 Post By Essex
  • 1 Post By PlugsAndLights
  • 2 Post By PlugsAndLights
  • 1 Post By Essex
  • 1 Post By MikeFL
  • 1 Post By MikeFL
Old 11-02-2016, 05:26 PM   #1
Rewards Points: 8
Default Earth bonding for AC units
Hi Guys,
I'm a bit confused about earth bonding for AC units as I found some suppliers do an earth bonding connection between their units chassis and the main earth point in the control panel and some they got nothing bonded to the frame or the chassis with the earth wiring,The question is :
- Is there any kind of requirement or standards to tell that there must be some kind of bonding connection between all the metal part inside the AC unit?
Thanks
Steve
razouki is offline   Reply With Quote
Old 11-02-2016, 05:56 PM   #2
Rewards Points: 1,651
Hey Steve, welcome.
I know of a few Australians, but I don't think I've seen any New Zealanders here. Hopefully there will be someone who can help you with your requirements and code.
razouki likes this.
Old 11-02-2016, 06:00 PM   #3
drspec's Avatar
Rewards Points: 1,116
wasnt Chewy from NZ?
The Following User Says Thank You to drspec For This Useful Post:
Southeast Power (11-03-2016)
Old 11-02-2016, 06:02 PM   #4
I miss that gay happy bastard. I was thinking he was Aussie, but you may be right.
brian john and razouki like this.
Old 11-02-2016, 06:03 PM   #5
Rewards Points: 1,986
Yep
Not sure what standards NZ uses but I am pretty positive world wide bonding between electrical components is mandatory with a few exceptions.
razouki likes this.
Old 11-02-2016, 07:10 PM   #6
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
First, you should revisit your profile and spell "electrcican" correctly.
As for the standards for bonding of internal parts of electrical device, it's
not the responsibility of the electrician. If it's certified by the appropriate
body that's all that matters. Around here the 2 main main bodies are CSA
and ULc.
While it doesn't matter to us, the fact is that manufactures can bond metal
parts by way of wires, straps, screws, etc.. They can also ensure that parts
will not become live by double insulating them. In this case no bonding is
necessary. At least, that's the way it works up here.
P&L
brian john, emtnut and razouki like this.
The Following 2 Users Say Thank You to PlugsAndLights For This Useful Post:
raldous (11-29-2016), razouki (11-02-2016)
Old 11-02-2016, 07:33 PM   #7
Rewards Points: 8
Thanks for your information,
You mentioned that the manufacturer can do bonding by screws.
Do you mean screw all the body parts together and that's it? don't they need at least one main wire from the main supply earth to the nearest point in the chassis?
Cheers
Steve
Old 11-02-2016, 07:55 PM   #8
Essex's Avatar
Rewards Points: 466
I would expect the metal casing of an AC unit to need earthing not bonding.
Some AC units have a plastic casing are you 100% sure the ones without the earth bolt are steel?
razouki likes this.
Life is too short to get angry.
Essex is offline   Reply With Quote
The Following User Says Thank You to Essex For This Useful Post:
razouki (11-03-2016)
Old 11-02-2016, 08:10 PM   #9
Safety Pin Member
Cheers
Steve
Main thing the testing authorities will be interested in is that the bonding
is low impedance and capable of carrying a min specified current. They'll
also want to ensure the bonding will not come loose, oxidized, or
otherwise become ineffective. How those specs are achieved are the
responsibility of the engineer(s) designing the product.
No reason that a screw, bolt or other fastener, wouldn't meet these
requirements as well as a wire. Fact is the wires are usually attached by
screws anyways.
P&L
razouki likes this.
Old 11-02-2016, 08:13 PM   #10
Safety Pin Member
Not sure if the meaning of earthing and bonding are the same around the
world. But I'd rather not open that can of worms right now as I'm not sure
it matters to this thread.
P&L
Essex and razouki like this.
Service Call (11-03-2016)
Old 11-03-2016, 04:11 AM   #11
Essex's Avatar
Rewards Points: 466
P&L
You may be correct. Here anything that can become live through fault conditions is earthed (metallic case of AC unit).
Anything that cannot become live through fault conditions but could introduce a difference in potential is bonded (possibly the AC system pipework)
Back to the op - a simple continuity test between the earth terminal for the unit and the casing will tell him if the casing is earthed or not.
razouki likes this.
Old 11-03-2016, 08:09 AM   #12
MikeFL's Avatar
Rewards Points: 630
Hi Guys,
Thanks
Steve
Wow this guy's down under down under! Welcome to the forum NZ.
I agree as far as bonding everything inside the cabinet, that's on the NRTL that issued the listing. The electric code is going to require the bonded conductor to be run with the circuit. No electric code is going to require you to get inside that cabinet and test everything for continuity and bond it; that's the NRTL's job and the manufacturer's job during manufacturing of the unit.
Why did the question come up? New construction? Changeout? Servicing an existing system? Did someone get hurt?
razouki likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-03-2016, 03:58 PM   #13
Rewards Points: 8
Hi Mike,
Many thanks for your comments , I'm just one step away from down under...)
My question came to mind as I'm contracting now for a small company that manufacturing AC units to inspect their wiring diagrams, looms, and if it complies with safety and standards so while I was doing the inspection, I noticed that there is no earth bonding to any part of the unit outside the electrical box.
Is that legal?
Cheers
Steve
Old 11-03-2016, 04:13 PM   #14
Rewards Points: 3,062
Welcome aboard! Hope you enjoy hanging out here. I have an old GF, well 30 so she really isn't an 'old' GF in Auckland. Also two of my sisters in law living there, small world.
Old 11-03-2016, 08:39 PM   #15
MikeFL's Avatar
Rewards Points: 630
Hi Mike,
Is that legal?
Cheers
Steve
Sounds like your'e the 3rd party inspector then. In that case it is your duty to affirm that everything is bonded. Typically there is a bonding lug on the chassis and everything that a human can touch is bonded to that lug. The lug receives the EGC from the branch circuit. I have no idea who you are working for or what regulations exist down under down under but my advice is to require a label (sticker) that says disco power before servicing and for the manuf. to include a continuity test to that lug prior to labeling the equipment so they have a record of their diligence prior to shipping the unit.
raldous likes this.
GPS Timers
(833) GPS-TIME
Old 11-04-2016, 06:22 AM   #16
Rewards Points: 21,898
Steve.,
Welcome to the fourm here .,,
Now let me get to the quick point here.,,
Do you have the latest infomation on the Aussie / NZ electrical code and what it is required in your area ?
As far for bonding of outside of electrical junction or connection point box.
It should be bonded to the point of earth screw or some type of connection of earth conductor there.
Earth bonding for AC units razouki General Electrical Discussion 0 11-02-2016 05:24 PM
Ceiling rose twin red + earth help JHAR3055 General Electrical Discussion 4 10-19-2016 03:18 PM
interesting question: what if there is no bonding between ground and neutral? mike883 General Electrical Discussion 35 05-29-2016 03:18 PM
Hydro tub Bonding? HackMaster General Electrical Discussion 2 01-30-2016 12:26 PM
Rule 10-906 meadow Canadian Electrical Forum 29 01-19-2016 07:27 PM
