Electric tractor build - Electrician Talk - Professional Electrical Contractors Forum
Like Tree27Likes
Old 09-10-2016, 07:57 PM   #1
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
Default Electric tractor build
Our expiramental department is having one of their tractors taken out of their budget next year so they are wanting to take an electric motor and drive they had from some past expiraments and turn it into a skid to run tests with.
We have a 125 horse 6 pole motor and a drive. It will be mounted in a skid to run a pto shaft above a tractor set up just like it would be on a tractor. The skid will set outside and be powere by a 3/0 flexible cord to a 200 amp metric outlet on the side of the building. The drive will be on the skid and be able to have the speed varied automatically as their test calles for it.
I will use this as a build thread and keep it updated as it progresses. The pictures will be sparse but will hopefully show what is happening. Here is what it is starting out as:
They are working on cutting the steel for the skid now and I am working on getting the electrical parts I need.
For those of you unfamiliar with tractors I will kinda explain what we are replicating. We build hay balers and mowers at this plant. So when that equipment is being used in the field is is pulled by a tractor that provides the various power inputs that the equipment needs like hydraulic for lifting and moving parts of the equipment or pto to operate the equipment. The equipment is hooked to the tractors draw bar so it can be pulled through the field to do its job. Since we are just testing and developing things we only need the pto to drive the equipment. The skid will stay till while they are running their tests with the various sensors all over the equipment.
drsparky likes this.
Old 09-10-2016, 09:03 PM   #2
MikeFL's Avatar
Rewards Points: 586
Sounds like a fun project to work on.
Is this a prototype for possible future product? Just curious how you'd supply power when it's used in the field (no pun intended) or is it a test jig for functional testing completed assemblies?
Jhellwig likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Jhellwig (09-12-2016)
Old 09-10-2016, 09:09 PM   #3
Jhellwig's Avatar
No this isn't a future product or anything. It is to run implements for tests.
When we develop a new product or improve a current one they do all sorts of test for durability. They put all sorts of sensors on everything and run it for a long time to simulate field use. We currently use a tractor to provide the power for these tests. This is going to replace the tractor. They will still use a tractor when they are doing these tests in the field but it is kinda wasteful to use one sitting next to a building all day.
Old 09-10-2016, 10:43 PM   #4
Rewards Points: 3,102
Since PTOs operate at either 540 or 1000 RPM, are you using gear reduction?
It's likely not needed, even at 540 RPM a 6 pole motor can develop pretty good torque, plus not many balers need 125 HP though a swather w/crimper can take some serious HP.
It'll be interesting to see how this finally works.
Be careful of counter-torque at the motor though, 50 HP @ 540 RPM is nearly 500 ft. lbs.
Old 09-10-2016, 10:54 PM   #5
Jhellwig's Avatar
Direct drive. There will be a switch to select 1000 or 540 rpm. I will use a couple digital inputs on the drive to set a fixed speed and then one for variable.
The engineer designing the skid says he figure out how much ballast they need to add to one side. They are going to use tractor weights. I had to convince him that it would be a good idea to have a switch detect if it starts to come off the ground.
They have a 200 horse motor and drive but didn't think the building they are powering it from has enough power. It only has 400 amps to it. We make a baler that can take that much power to run.
micromind likes this.
Old 09-10-2016, 11:16 PM   #6
Rewards Points: 21,896
For the 6 pole motor when you dail in at 1000 rpm you are ok with interal cooling fan but however when you slow down to about 540 it may not have enough air flowage to keep the motor cooling function properly so I really suggest that you may have to add a small squrell cage blower to assit it to keep from the main motor getting hot.
espcally with full load at 540 rpm.
I am not sure how many hp you will get it out on 540 rpm but for my wild guess without getting overloaded or overheated I am guessing about 25 HP give or take few numbers .,,
I am kinda famuair with the HP / rpm chart so it kinda predencted on the speed with HP so the faster it run the more HP it will crank out until you hit rated speed after above rated speed it will stay flat after that.
that based on useing the VFD as long you dont overdraw the main running current you should be fine.
Oh yeah you will need a outrigger to countertract the toqure of the motor.
I have done that before with 300 HP DC shunt motor.
micromind, Jhellwig and Majewski like this.
Jhellwig (09-11-2016)
Old 09-11-2016, 12:36 AM   #7
Jhellwig's Avatar
I mention the cooling thing to the engineer and he said that it is just on the verge of not having enough cooling. He seams to have a very good handle on the limits of the motor.
They are confident they have it figured out how much counter weight they need to keep it on the ground.
frenchelectrican and Majewski like this.
Old 09-11-2016, 12:50 AM   #8
that is good to know and as long they know what the limitation of the motor design it should be ok.
the electric PTO I did make with 300 HP DC shunt motor I did use old diesel engine block to counterweight it I think it did weight in about 2700 KG due one unit I made it did not have outriggers but the latter one yes I did have outrigger so I used lighter counterweights.
but when you make a frame make sure you put a isolater springs mounting for your control panel so keep the viberation to the control panel to minuim
Old 09-11-2016, 01:09 AM   #9
Jhellwig's Avatar
I didn't think about the vibration. Thanks. The big baler we make is a mechanical driven plunger style so it will make some serious shock loads if they decide to try doing the endurance test on the main gearbox again. When they ran that test being powered by a tractor it beat the hell out of the tractor.
Ultimately if we don't get it right the first time we have two more drives and motors.
Old 09-11-2016, 01:18 AM   #10
Ahh ., gotcha .,,
that will be good ground shaking event when they do that kind of test .,,
I think it will be best move to make the control panel on seperated cart and keep it off from the PTO frame.
Mine setup was used with isolateing springs the viberation was not too bad but the toqure load that only thing I was little worry due that pto I used that to run a big arse blower for slio so you get the idea when someone dump the silage too fast in the blower hopper it can stall the PTO power unit if not carefull..
micromind and Jhellwig like this.
Old 09-11-2016, 10:14 AM   #11
rrolleston's Avatar
Rewards Points: 1,134
It's seems to me electric motors would work better at normal speed and using gears to reduce them. I have had bad experiences with slowing motors down and putting a large load on them.
The Following User Says Thank You to rrolleston For This Useful Post:
Old 09-11-2016, 02:23 PM   #12
Jhellwig's Avatar
1000 rpm on a 6 pole motor won't hurt anything. All of our big power needing things are 1000 rpm. The small balers are 540 rpm and don't take much power to run. The small mowers even have a 1000rpm option but don't hardly get tested all together.
Gear boxes are inefficient. If we need a reduction a cog belt is a much better option. We might have to use that if we ever use the 200hp motor as it is only 4 pole.
Old 09-12-2016, 06:00 PM   #13
Rewards Points: 320
I helped this guy build his "electric tractor" years ago when I worked for Motortronics. Not the same scale as what you are doing, but it was fun.
http://www.simpletractors.com/do_it/simply_shocking.htm
I'm helping another guy "electrify" his 1956 Chevy pickup with a 75HP motor and VFD. When he's done, I told him I want his help so I can do something similar, probably with a 1935 Dodge rat-rod pickup body i found. The drive and motor part is easy for me, it's the mounting and coupling issues that will be challenging. He's come up with a cool way to store the batteries under the truck bed, which is raised up, but you can't easily tell from the outside. He's test run it and says that motor and VFD burn the rubber off of the tires if he lets it. that fits my experience with replacing engines with motors and VFDs; the 'instant" nature of torque development with an electric power train changes the way we need to think about "HP" requirements in vehicles.
micromind, Jhellwig and MikeFL like this.
The Following 3 Users Say Thank You to JRaef For This Useful Post:
frenchelectrican (09-13-2016), Jhellwig (09-12-2016), MikeFL (09-13-2016)
Old 09-13-2016, 12:08 AM   #14
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 216
Big green is taking your tractor away?
Cowboy words of wisdom.
LARMGUY is online now   Reply With Quote
The Following User Says Thank You to LARMGUY For This Useful Post:
Jhellwig (09-13-2016)
Old 09-27-2016, 11:11 PM   #15
Jhellwig's Avatar
They are taking one out of their pool at this plant. Dumb thing is they have 3 100+hp expiramental tractors just sitting around free of cost.
Old 09-27-2016, 11:18 PM   #16
Jhellwig's Avatar
I am waiting on a ton of parts but I hooked the motor and drive up and wired in a Plc to test the operation of it. The instructions for yaskawa drives are about as vague as Allen Bradley's so I had some trial and error to get it to do what I want. There are some things about this drive that don't make a bit of sense to me but I figured out the work around for most of it. Still can't get it to jog in both directions without another digital input though. There is no calibration on the analog outputs and they were off by .2 mA so I had to trim them with the bias and gain in a trial and error manor.
And yes that mess of wires is necessary and not even as many as will be in the box when it is done.
micromind and Majewski like this.
Old 09-28-2016, 12:03 AM   #17
Cow
Rewards Points: 4,898
That does seem like a lot of wiring just to make a motor run that's replacing a tractor. What kind of things are you guys monitoring or telling the VFD to do beyond just "start".
Old 09-28-2016, 12:59 AM   #18
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Is that the fluke 173 on the right?
Old 09-28-2016, 03:00 PM   #19
Jhellwig's Avatar
Digital ins: start, stop, not, fixed speed 1, fixed speed 2, analog input 2 enable, drive reset, and fwd/rev. Digital out: run, at speed, fault. Analog in:. Speed rec from a pot, speed rec from 4-20mA. Analog out: horsepower, rpm. There will be two panel meters, an ac unit, transformer, terminals and relays for external monitor it and control. The plc isn't going in it. It is just to test the operation without having a pile of stitches hanging there.
179. The other is an 87v.
Majewski likes this.
Old 09-28-2016, 03:05 PM   #20
Majewski's Avatar
179, that's what I meant! I'm using same one as my daily.
Advice for electric vs hvac business or both ZBat910 Business, Marketing, and Sales 33 10-14-2018 01:25 PM
Electric Company Service Drop Upgrade MustangRider6688 Services and Service Equipment 12 07-11-2016 06:03 PM
Electric train used a energy storage Southeast Power General Electrical Discussion 27 05-24-2016 07:55 AM
Electric heat for log home Grogan14 Residential Electrical Forum 7 03-13-2016 08:15 PM
Lunera Recalls LED Lamps Due to Fire, Burn and Electric Shock Hazards guest Recalls, Safety Notices and References 0 01-27-2016 09:28 PM
