Electrical Insulators - Electrician Talk - Professional Electrical Contractors Forum
Old 03-22-2014, 10:14 AM   #1
Pool Shark
ablyss's Avatar
Rewards Points: 886
Default Electrical Insulators
Was wondering if there is a rule of thumb of knowing what voltage is on the power pole by counting the number of insulators. For example one insulator equals x amount of voltage, and four equals x amount. Thanks all.
-- If you can read this you're about to bump your head.
ablyss is offline   Reply With Quote
Old 03-22-2014, 10:16 AM   #2
ponyboy's Avatar
Rewards Points: 709
I remember hearing one insulator for every 10,000 volts. I don't know if it's true though
The Following User Says Thank You to ponyboy For This Useful Post:
ablyss (03-22-2014)
Old 03-22-2014, 10:43 AM   #3
Fond of three phase
Rewards Points: 928
I always heard, one rib for each 10,000 volts.
Today, it's kind of hard to tell. Poco upped the voltage in the area from 4800 to 13.2KV and are using the same insulators.
This is rural area and on the main roads, when the power poles were replaced, some of the insulators look like they're rated for a lot higher voltage, but those poles are a continuation of the 13.2 KV lines.
They probably did it for increasing the voltage in the future.
retiredsparktech is offline   Reply With Quote
The Following 2 Users Say Thank You to retiredsparktech For This Useful Post:
ablyss (03-22-2014), Big John (03-22-2014)
Old 03-22-2014, 02:02 PM   #4
Senior Moment
drsparky's Avatar
Rewards Points: 406
For clearance it is number of insulators +10'.
I would give this one 22' of clearance.
The Following User Says Thank You to drsparky For This Useful Post:
ablyss (03-22-2014)
Old 03-22-2014, 04:52 PM   #5
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I don't know of any hard and fast rule. I've heard both 10kV and 20kV per bell, but actually putting that in practice will often only get you within about 50kV of the nominal voltage.
For transmission systems I look at the overall insulator length and pole construction. I can usually ballpark it that way.
Always wear your gloves.
ablyss (03-22-2014)
White plastic EMT insulators subelect General Electrical Discussion 17 02-18-2012 03:31 PM
Other Than Electrical A Little Short Residential Electrical Forum 26 07-07-2011 07:52 PM
!)@#$*(%&* Insulators! 480sparky Code Violation Discussion 34 01-02-2011 10:25 AM
Electrical connection question --Over-head electrical works SarahJennifer UK Electrical Forum 6 03-02-2009 10:32 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-28-2007 11:47 PM
