Electrical safety 101 ......do not try this at home. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 04-18-2012, 09:11 PM   #21
ET rocks
3xdad's Avatar
Rewards Points: 2,174
They've had it and are trying to kill Nessie?
Too soon, Black Dog... way too soon...Rock on buddy.
3xdad is offline   Reply With Quote
Old 04-18-2012, 09:18 PM   #22
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
Originally Posted by Big John View Post
Is this something that I should know? I have a feeling it's gonna be some kinda special-drawbridge-unscrewing tool that I never would've guessed in a million years....
-John
yes it is how could you have guessed - they effed up bridge has long outstanding power quality issues soooo what do my engineers send me this time - these a$$hats with the resistance load and inductive load midway thru the cable to help with the capacitance issues the cable has
did it work ??? five whole volts at padmount at end of line snapshot of voltages where taken for thirty whole minutes ( i was a little pissed off at this)
the floatie contraption is four heating elements (they turned in the water where you cant see em)
Old 04-19-2012, 10:03 AM   #23
ET rocks
3xdad's Avatar
Nola, could you explain this short bus style so i can understand/learn what's going on? Thanks
The Following 5 Users Say Thank You to 3xdad For This Useful Post:
erics37 (04-19-2012), guest (04-19-2012), Podagrower (04-19-2012), stuiec (04-19-2012), Wireman191 (04-20-2012)
Old 04-19-2012, 12:36 PM   #24
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
if your going to do something like this why wear a safety vest
for lunch I had three cans of alphabet soup then afterwards I had a huge vowel movement
ampman is offline   Reply With Quote
The Following User Says Thank You to ampman For This Useful Post:
Big John (04-19-2012)
Old 04-19-2012, 01:58 PM   #25
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,714
Easier to find the body.
I hate to see her go, but I sure love watching her walk away.
The Following User Says Thank You to CTshockhazard For This Useful Post:
Boomer (04-19-2012)
Old 04-19-2012, 02:47 PM   #26
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Frijoles!
So, if I follow you, they're using the water-heater elements on the floating SS Minnow there, submerged in the pond as a resistive load, and the motor as an inductive load, to try and cancel out what they think is high capacitance screwing up your power factor? I mean, it sounds smart, but what I see in the pictures looks stupid....
I don't pick up where the 5 volts fits in? Is that all you had at the end of the feeder once this contraption was turned on?
-John
guest (04-19-2012)
Old 04-19-2012, 08:08 PM   #27
Licensed Journeyman
nolabama's Avatar
Frijoles!
-John
You are following correctly. The five volts was all we lost on the dead end. This capacitor effect is/has added as much as 2100 vac to the primary....so we think adding any load would help bleed off any voltage being added. Well one hundred amps worth of load managed to bleed off five volts one the secondary. We are not measuring the primary side.....prolly cause we really dont want to see how ugly those numbers are. An engineering firm is specing out a cap bank and getting numbers ready....this clown car $hit was to see if a temp fix could be attained.
Old 04-19-2012, 08:18 PM   #28
Licensed Journeyman
nolabama's Avatar
Short bus, oh you mean our ride..... Transmission line is a concentric neutral single phase primary apx nine miles long. It has about four or five ground rods in that distance (speaking of dont try this at home). Google capacitance. Wiki will give you some really fancy formulas, use the one for round things. Use nine miles as your distance. Discuss with local poco engineer over beers and give him a good laugh. Tell him btw they only use nine amps athe dead end and intermittetly bounce that up to fiftey amps about once and hour for about four minutes. He should buy you a beer at this point for making him laugh so much. Then tell him the load is very sensitive electronic equipment. Then after he calms down tell him those guys put in all three phase equipment, but that transmission line is single phase. Offer him a napkin to dry his eyes cause he cant stop laughing. Ask him how stable the voltage should be.......
The Following 3 Users Say Thank You to nolabama For This Useful Post:
3xdad (04-19-2012), Big John (04-20-2012), RobRoy (04-19-2012)
Old 04-19-2012, 09:12 PM   #29
IET
RobRoy's Avatar
Rewards Points: 1,008
I've got one word for this..................
WOW!!!!!!
RobRoy is offline   Reply With Quote
Old 04-20-2012, 03:43 AM   #30
Rewards Points: 1,464
Must be another government project where time ain't money.
Old 04-20-2012, 07:19 AM   #31
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Nola, I know you've had VFD issues out there. Is it possible to ramp in your loads, or a similar load, slow enough that you wouldn't see the sudden charge?
Who's feeder is it? What about making it the POCO's problem: Drop in a HV line reactor?
-John
Old 04-20-2012, 09:21 AM   #32
Licensed Journeyman
nolabama's Avatar
-John
Loads are ramped in slowly. 5hz 10hz and then i think l around 25 hz. Its for sure my feeder. POCO has all but told us to eff off . I dont know what a hv line reactor is. The photos were posted for amusement not for getting any answers. I know a lot of the commercial and resi guys never get to do any silliness like this.
Old 04-20-2012, 10:37 AM   #33
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
...I dont know what a hv line reactor is....
It's the solution to your problems. The ones in that link are big guys, but you can get them in the kVA range.
-John
nolabama (04-20-2012)
PRS Electrical Safety Campaign KevA UK Electrical Forum 1 04-25-2012 05:29 PM
Home electrical safety check knob and tube wiring mikeh Business, Marketing, and Sales 22 04-07-2012 11:37 AM
Electrical Safety Joe Tedesco Workplace Safety 43 05-07-2011 03:19 PM
electrical safety z07jcb General Electrical Discussion 5 11-24-2010 05:12 PM
Electrical Safety bobelectric Workplace Safety 2 05-21-2009 07:45 PM
