electrician (Sump pump GFCI issue) - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2015, 11:13 AM   #1
Rewards Points: 8
Unhappy electrician (Sump pump GFCI issue)
Is it code that you must install gfi receptacle or gfi circuit breaker for a sump pump in a commercial building this gfi tripped and a second gfi also tripped when a flood in the basement happen the branch circuit is clear of any fault
any input will be helpful
sal reno is offline   Reply With Quote
Old 02-27-2015, 11:16 AM   #2
I own stock in FotoMat!
Rewards Points: 6,520
depends on the location of the outlet the code states where they are required 210 8 b has list there are about 7 or 8 requirements there for where receptacles are to be protected
Old 02-27-2015, 12:39 PM   #3
Small Potatoes
flyboy's Avatar
Rewards Points: 3,919
I see what you did there.
Old 02-27-2015, 01:08 PM   #4
Very Long Vacation
Rewards Points: 5,262
Pump has a ground fault, a correctly running pump will not trip a GFCI. Unlike AFCIs, GFCIs will trip when something is actually wrong.
The Following 3 Users Say Thank You to meadow For This Useful Post:
guest (02-27-2015), MTW (02-27-2015), shocksystems (02-28-2015)
Old 02-27-2015, 02:21 PM   #5
Sal, when starting a thread please do not use "electrician" as the thread title, that is known in forums as a "teaser title" as it does not give any information as to what the thread topic is about.
For this thread, a proper title would be something like "Sump pump GFCI issue".
You will get more responses with a proper title. (I am editing this thread title. )
Old 02-27-2015, 07:50 PM   #6
Rewards Points: 678
I agree with meadow on bot points. something wrong with motor and AFCIs are not much use.
ELECTRICK2 is offline   Reply With Quote
Sump pump and GFCI Sparkypyro General Electrical Discussion 18 12-09-2012 01:30 PM
Sump Pump Aegis General Electrical Discussion 4 09-24-2012 04:24 PM
No GFCI protection, non-dwelling sump pump? Chris Kennedy NEC Code Forum 5 07-08-2011 07:51 PM
Sump Pump BIGRED NEC Code Forum 9 03-05-2011 03:10 AM
Sump Pump Installation Magnettica General Electrical Discussion 5 03-17-2010 12:38 AM
