elevator code gurus - Electrician Talk - Professional Electrical Contractors Forum
Old 10-30-2013, 07:56 PM   #1
flashover's Avatar
Rewards Points: 121
Default elevator code gurus
Scenario: passenger elevator from basement to roof.
Machine room is on the roof, "plans" call for ckts (cab lights, hvac,) to be pulled from basement house panel to a disconnect, then on to the elevator loads.
My question:
Does a ckt breaker or fuse type disconnect located in the machine room qualify as the "overcurrent device supplying the branch ckt" per 620.22?
Or does the machine room need a sub panel to satisfy the requirement of 620.22 a and b
flashover is offline   Reply With Quote
Old 10-30-2013, 08:01 PM   #2
Rewards Points: 1,464
We run the elevator feed to the room. Lights and recptacles we do.The elevator union does the rest.
Old 10-30-2013, 08:03 PM   #3
di11igaf's Avatar
Rewards Points: 282
The couple I've done start to finish I used fused disco(I believe this can be an enclosed CB) in machine room to feed elevator controller(sub panel not required), fed from shunt trip breaker elsewhere.
IBEW
There's no place like ~/
di11igaf is offline   Reply With Quote
Old 10-30-2013, 08:09 PM   #4
flashover's Avatar
Rewards Points: 121
Originally Posted by di11igaf View Post
The couple I've done start to finish I used fused disco in machine room to feed elevator controller(sub panel not required), fed from shunt trip breaker elsewhere.
Does the elevator controller do the cab lights and hvac as well?
Old 10-30-2013, 08:17 PM   #5
Bkessler's Avatar
Rewards Points: 2,002
That about sums up the one I just did.
When ls lunch?
Old 10-30-2013, 08:25 PM   #6
Fluke Skywalker
walkerj's Avatar
Rewards Points: 1,002
My question:
Either way but I would not design this yourself.
I'm sure there is an engineer involved.
Better yet, get with the elevator installer.
Jason
walkerj is offline   Reply With Quote
The Following User Says Thank You to walkerj For This Useful Post:
rlc3854 (10-30-2013)
Old 10-30-2013, 08:32 PM   #7
flashover's Avatar
Rewards Points: 121
Im simply questioning some very vague stuff that was handed to me, I would never design, strictly install, even with the masters license.
Old 10-30-2013, 09:36 PM   #8
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
Based on location... I have no freakin clue where you are. If you are in Ohio you simply provide a feed to the elevator controller and the State takes over from there.
Pete
The Following User Says Thank You to Pete m. For This Useful Post:
Old 11-02-2013, 02:10 PM   #9
"A" Inside Wireman LU 134
Rewards Points: 97
I do a lot of elevator work. Install as I do it as follows:
1. Heavy duty fusible lockable disconnect for elevator mainline
2. Heavy duty fusible lockable disconnect for elevator cab lighting
3. All new lighting in elevator machine room
4. New GFCI receptacle at each elevator machine
5. Install lighting and GFCI receptacle in elevator pit. Also provide single
receptacle in pit if sump pump is present.
6. Provide new circuit for HVAC unit.
This is a standard install. Of course elevator consultants and the inspectors can throw some changes in from time to time.
Piping as long as I can...
pugz134 is offline   Reply With Quote
Old 11-02-2013, 06:55 PM   #10
Mate's Avatar
Rewards Points: 264
Don't forget smoke detectors and relays from firealarm panel.
Mate is offline   Reply With Quote
Old 11-02-2013, 08:46 PM   #11
CADPoint's Avatar
Rewards Points: 1,852
I just finished one of those new penthouse layout's.
Your'll need a certain number of duplicate equipment (previous stated) at both the top and the bottom of the lift way.
Disconnect in both service room and above in penthouse, smoke and light and GCFI both high and low.
In most States the elevator has their own way of doing things (Code)and to get a good location for circuit should be directed by elevator installers.
In no case in NC will they let any foriegn circuits be within the elevator equipment (except as required) and they will not be used infact as a raceway, and no pipe vertically from you either.
Get with the installers, they will work with you.
Good luck, stay safe
If you are even thirsty, you are two quarts low.
Old 11-02-2013, 08:55 PM   #12
Rewards Points: 562
Install I have done:
Elevator pit GFCI and Light
Elevator Machine room lighting
Elevator Main Disconnect and conduit/wiring to controller
Elevator Cab lighting disconnect and conduit/wiring to controller
Convenience receptacle in machine room.
Disconnect and wring to HVAC in machine room where needed.
Everything from the controller on is not my problem.
We have to install circuits to a fusible disconnect IN the machine room. Also we aren't allowed to do work in the room without an elevator tech on site.
It's always nice to have a subpanel up on the roof top for future but if money is an issue it's just the circuits needed.
CanadianSparky is offline   Reply With Quote
Any Auto/Tire Gurus out there? CanadianSparky Off Topic (Non Trade) 20 02-21-2013 03:29 PM
Q for the RSLogix 5000 gurus MDShunk PLCs, VFDs, Motors and Controls 10 01-24-2012 07:05 PM
Q for the lighting gurus user4818 Lighting Design 25 09-30-2011 08:29 PM
GURUS-Wheres the Code Violation? TexasElectric NEC Code Forum 2 05-03-2011 08:24 PM
G'day Gurus Air_wolfie New Member Introductions 5 12-14-2009 08:44 AM
