Emergency "bugeyes" coverage requirements - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 06-23-2015, 11:54 PM   #21
Rewards Points: 99
It's about a 1000 Sq ft with a 10 ft ceiling.
Jamie7613 is offline   Reply With Quote
Old 06-24-2015, 07:49 AM   #22
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by Jamie7613 View Post
So what kind of e lights would you suggest? Can you sight a code reference?
E lighting is a building code and is not really addressed by the NEC . This means it will vary according to the standard the AHJ has adopted.
Old 06-24-2015, 10:07 AM   #23
Rewards Points: 99
So I should be able to walk threw the stores nearby and see what kind of coverage they are looking for then right?
Old 06-24-2015, 10:12 AM   #24
sbrn33's Avatar
Rewards Points: 3,578
Or you could read some building code and maybe make a quik call to the building inspector.
Old 06-24-2015, 12:26 PM   #25
Going_Commando's Avatar
Rewards Points: 1,620
Get outa here with logic and reasoning.
Old 06-24-2015, 03:49 PM   #26
Rewards Points: 310
1st red flag: owner of building is trying to get over on code enforcement office
2nd red flag: owner is late on first payout/trying to get over on you
bkmichael65 is offline   Reply With Quote
Old 06-25-2015, 12:13 AM   #27
BEAMEUP's Avatar
Rewards Points: 26
You're kidding, right? There's no way this can be an actual rule.
nope, i'm not
BEAMEUP is offline   Reply With Quote
Old 06-25-2015, 12:42 AM   #28
Rewards Points: 44
Yes, national construction codes are 1 ft candle at ground level at all exit doors that lead outside.
And egress path ways.
FF301 is offline   Reply With Quote
Old 06-25-2015, 07:24 AM   #29
Originally Posted by BEAMEUP View Post
nope, i'm not
There's light all the way to all the property lines when the power goes out? Where do you install these lights? I can see adding them to the lot lights, but what about other areas? Do you install additional poles all over hither and yon?
I'm sure such a requirement can be quite profitable, having to charge hundreds of thousands of dollars to install lighting all over a property just to comply with such a silly rule.
sbrn33 (06-25-2015)
Old 06-25-2015, 08:28 AM   #30
Do you even egress path, bro?
Old 06-25-2015, 11:22 AM   #31
Rewards Points: 44
Egress path way is the area just outside the exit doors
Didn't think i needed to explain that one, but i'll try to be more specific in the future.
Old 06-25-2015, 12:10 PM   #32
No. I prefer the Lindy or the Twist.
Old 06-25-2015, 05:33 PM   #33
Awg-Dawg's Avatar
Rewards Points: 726
It was my understanding that every public bathroom needs at least a remote head.
If I remember right, while its common to put them in there, there aren't required.
Kinda makes sense, it's not a means of egress.
Although , I agree, it would be a good place for one.
I feel sorry for people who don't drink, when they wake up in the morning, that's the best they will feel all day.
Awg-Dawg is offline   Reply With Quote
Old 06-25-2015, 09:13 PM   #34
Rewards Points: 3,043
Minimum here is 1 ft candle per sq ft at the floor ( Wa St ) How you get it is up to you as far as the kind of E lights you use. But all exit paths have to meet this rule all the way to the exterior of the building to the property line.
Those of you in NH have probably dealt with this bullshi. Dover NH enforces this same crap Inspections after dusk with Jimmy and Rebecca dragging a light meter ALONG THE FLOOR
Last inspection I failed, I kept asking why they haven't tripped and fallen yet
The Following User Says Thank You to JoeSparky For This Useful Post:
BEAMEUP (06-26-2015)
Old 06-26-2015, 11:08 PM   #35
BEAMEUP's Avatar
Rewards Points: 26
You did read the thread title right " bug-eyes" coverage requirements right? they are "E" lights as in battery back up lights. The power goes out they come on.
There's light all the way to all the property lines when the power goes out? Yes, but only those areas that are called out as egress paths only Where do you install these lights? on walls. I can see adding them to the lot lights, but what about other areas? Do you install additional poles all over hither and yon? Seriously????
not quit, a few hundred at most
Old 06-26-2015, 11:11 PM   #36
BEAMEUP's Avatar
Rewards Points: 26
Exactly like that, glad its not just local with my town
Old 06-27-2015, 08:18 AM   #37
You wrote it, not me.
Very few structures are built right up to the property lines.
Old 06-27-2015, 11:34 AM   #38
BEAMEUP's Avatar
Rewards Points: 26
True, but when you start getting cities like Seattle changing the building code to reduce the setbacks and allowing buildings to be on the property lines, you will start to see these crazy codes pop up.
Surge Protector Says "Grounded" and "Protected," but... eric_carlisle General Electrical Discussion 2 05-10-2015 04:04 PM
license & exams: "residential/single-phase" v "journeyman" mikewillnot General Electrical Discussion 8 01-21-2015 07:43 PM
"GFCI" means "waterproof" jhartz Code Violation Discussion 14 02-27-2014 01:57 PM
A "Private Citizen" "Saves" the Day? pudge565 Off Topic (Non Trade) 43 11-07-2013 12:46 AM
"electricians" advertising "recession pricing" "super low prices to fit your budget" lovethetrade General Electrical Discussion 17 11-30-2011 11:44 PM
