Enclosure wiring colors for VDC - Electrician Talk - Professional Electrical Contractors Forum
Old 07-22-2013, 03:19 PM   #1
Default Enclosure wiring colors for VDC
Are there any NEC codes or rules relating to DC wires with specific regard to color? We will be installing a light sculpture in NY and we have to connect the wiring from the power supplies to the terminals within an enclosure. I know generally red is positive and black is negative, but if I use a different color for red such as white, could we encounter issues with our installation being not to code?
Thank you in advance!
jkaras is offline   Reply With Quote
Old 07-22-2013, 04:21 PM   #2
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 5,518
The NEC doesn't mandate color for DC wiring.
guest (07-22-2013)
Old 07-22-2013, 04:58 PM   #3
ponyboy's Avatar
Rewards Points: 709
Typically round here as far as cabinets go- red is 120 volt control, blue is dc, yellow is outside source. Probably not what you mean though
The Following User Says Thank You to ponyboy For This Useful Post:
Big John (07-27-2013)
Old 07-22-2013, 05:02 PM   #4
Rewards Points: 195
Although there are no NEC rules for DC wiring colours, I recommend that you do not use colours that are already used in AC wiring, this has the potential to confuse others further down the track.
Here, we build quite a lot of equipment that gets installed in US factories, and we tend to use plain blue for +24VDC, and blue with white stripe for 0VDC. Some US customers have asked for brown for +24VDC and blue for 0VDC.
Paulusgnome is offline   Reply With Quote
Old 07-22-2013, 07:29 PM   #5
Rewards Points: 1,620
Normally in the US, blue is the color of choice for DC +. The the COM or DC- varies depending on the client. Normally I use gray for the COM. I have also seen/used blue with a white tracer or black.
There is no code mandated color code for DC. If necessary, you could post a legend on the panel showing your color code(s).
Most control panels will have black for power, red for 120 VAC control, and blue for 24 VDC control. This has been a common standard for as long as I have been around.
Old 07-22-2013, 10:16 PM   #6
Rewards Points: 2,950
I use invisible wire for 0vdc.
The Following User Says Thank You to btharmy For This Useful Post:
John Valdes (07-23-2013)
Old 07-22-2013, 10:33 PM   #7
I would refrain from using white or green.
big2bird is offline   Reply With Quote
Old 07-22-2013, 11:17 PM   #8
Rewards Points: 195
So does that make you half an electrician?
Old 07-22-2013, 11:18 PM   #9
Rewards Points: 159
brown +ve, blue -ve. Hope that quake did'nt cause too much damage in your area.
sparkywannabee is offline   Reply With Quote
Old 07-23-2013, 01:40 AM   #10
Rewards Points: 1,000
I would seriously recommend getting those large sticker that say VDC and/or VOLTS D.C., and have those placed on any enclosures, panels or wherever there are terminations just for the simple fact that DC is not so common and non-contact testers aren't likely to give warning of voltage present. I worked on a large industrial project last year that had a fair amount of DC equipment, IIRC we were using black for positive and white for negative but I could be wrong.
uconduit is offline   Reply With Quote
Old 07-26-2013, 02:19 PM   #11
My point was, we have 24vdc, + & -. I have never seen it referred to a 0vdc. Around here, that means there is no voltage. "0" volts is no volts, thus no wire required. Anyway, I have been told, "If you have to explain your own joke, it wasn't that good of a joke to start with". Oh well.
Old 07-26-2013, 04:16 PM   #12
Rewards Points: 195
In using the designations +24VDC and 0VDC I am indicating that we have a 24VDC system where the -ve lines from the power supplies are all tied to ground at one central point.
In my work, we build large multi-station factory machines. These have an extensive 24VDC network in which it is vital that we avoid nasties such as ground loops, multiple connections between AC and DC grounds etc.
To make this clear, for both our own build electricians and for the factory electricians who maintain the machinery, all of the schematics that I prepare use the designation 0VDC to distinguish from AC ground. This is just a convention taken from electronics and DC power industries that we have adopted, I guess we could use another label, but this works OK for us.
Note that we would not want to use +24VDC and -24VDC for the two rails because this would indicate a DC system of 48V centered on 0V.
Old 07-26-2013, 06:15 PM   #13
Rewards Points: 25
We have always wired with orange +24 and blue 0v. Twenty years now with no rule and no complaints.
Concept is offline   Reply With Quote
Old 07-27-2013, 11:45 AM   #14
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
NFPA79:
Within a common enclosure:
Black = Supply power.
Red = Reduced voltage control power
Yellow = Power supplied from outside enclosure
Blue = Direct current
White = Any grounded conductor. Put a corresponding colored marker on it to indicate system (e.g.: Blue stripe = Grounded DC)
Green = EGC
Always wear your gloves.
Tag colors? Elephante General Electrical Discussion 7 07-06-2013 02:57 AM
Service conductors entering ats enclosure before service disconnect enclosure Electron_Sam78 NEC Code Forum 36 02-18-2013 09:38 AM
Colors mean nothing BBQ General Electrical Discussion 34 06-25-2011 09:49 PM
Wiring colors btr General Electrical Discussion 19 10-23-2010 12:53 PM
wiring colors s.kelly General Electrical Discussion 25 08-19-2010 05:52 AM
