Entering the top of a 3R trough - Electrician Talk - Professional Electrical Contractors Forum
Old 04-15-2012, 04:20 PM   #1
Can't Remember
Rewards Points: 1,422
Default Entering the top of a 3R trough
I am doing a service upgrade on a two family and adding a house panel. I have a three gang horizontal meter socket with three 100a disconnects underneath. I want to put a 3R trough under the disconnects to give me a easy way to bring the ser into the disconnects. Can I bring a pvc male adapter into the top of the trough or do I need one of those myers hub things? I hate trying to sleeve ser through an LB.
Old 04-15-2012, 04:23 PM   #2
myers
Bbsound is offline   Reply With Quote
Old 04-15-2012, 04:29 PM   #3
Can't Remember
Thats what I thought. Anyone care to point to a code reference for my or anyone else's benefit?
Old 04-15-2012, 04:32 PM   #4
Cletis's Avatar
Rewards Points: 2,050
Why not pvc then run ser?
I'm shakin it boss..I'm shakin it
Old 04-15-2012, 04:36 PM   #5
Can't Remember
Because I am inherently lazy and hate trying to stuff a piece of #2 ser through a LB. The line to the house panel is a #1 ser, even more fun. SER into the back of the trough with a romex connector, stripped and up the nipple into the disconnect.
Old 04-15-2012, 06:02 PM   #6
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
You can use a sealing locknut if you use rigid nipples. I find it easier when working w/ Se and SER to stub pvc from LB into basement w/ female adaptor and cable connector. Strip down sheathing and push conductors thru connector and LB. It works good for me .
Old 04-15-2012, 06:10 PM   #7
Chris Kennedy's Avatar
Rewards Points: 2,000
I say meyers hub not required, see 312.2.
Old 04-15-2012, 06:13 PM   #8
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Half the time I use sealing locknuts with a bead of silicone over them.
Old 04-15-2012, 06:15 PM   #9
Rewards Points: 6,421
I try my best not to come in the top of outdoor equpiment, but when I must I either use the factory hub adaptor or a Meyers hub. In your case, I'm struggling with why you're not just using a 3-socket meter main assembly? They go up so slick.
Big John (04-15-2012)
Old 04-15-2012, 06:35 PM   #10
Can't Remember
I would love to use one of those, but this is one of those low budget deals. PSNH gives us the socket. I really wish someone made a weather proof ser connector and sill plate to match (round opening). Just looking for an easier way.
Old 04-15-2012, 06:38 PM   #11
There are weatherproof SER connectors. Same connectors you'd use on trailing cables for mining equipment. About every brand makes them. About 20 bucks. BUT... the kicker is that you're supposed to connect PIPE to a Meyers hub.
Old 04-15-2012, 06:41 PM   #12
Can't Remember
What would one of those be called? I will finish this off one way or another tomorrow. Maybe putting #1 and 2 ser in 1 1/2 lb won't be that bad.
Old 04-15-2012, 06:44 PM   #13
Rewards Points: 115
I use meter mains when we do multi-family units. Using seperate disconnects how would you ground that. Does each disconnect require a ground, or could you bond them together. I have never installed multiple disconnects, just meter mains. Sorry for the basic question.
guy2073 is offline   Reply With Quote
Old 04-15-2012, 06:47 PM   #14
Can't Remember
I bring the water pipe ground and the ground rods into the socket, remove the single barrel lug and swap it for a double. The utility wants a ground in the can here.
Old 04-15-2012, 06:48 PM   #15
I drop the grounding electrode conductor out of each disco and use an H-tap or C-tap onto the actual grounding electrode conductor.
NMD Entering a Panel! CEC09 Canadian Electrical Forum 4 03-26-2012 07:19 PM
Small current leakage livestock trough heater archibald tuttle General Electrical Discussion 135 01-05-2012 04:41 PM
Service in to trough to 5 meter sockets The-Engineer NEC Code Forum 5 06-21-2011 01:04 PM
Entering wirless realm sparky1423 Residential Electrical Forum 21 11-08-2010 07:15 PM
Entering field at ag 30 astratton78 General Electrical Discussion 22 01-03-2009 03:46 PM
