Equipotential bonding of spa - Electrician Talk - Professional Electrical Contractors Forum
Old 08-08-2015, 09:03 AM   #1
PowerPlusCt.com's Avatar
Rewards Points: 14
Default Equipotential bonding of spa
I have a spa to wire on a pad that is existing. How can I conform to article 680?
PowerPlusCt.com is offline   Reply With Quote
Old 08-08-2015, 09:03 AM   #2
Rewards Points: 14
Old 08-08-2015, 09:30 AM   #3
backstay's Avatar
Rewards Points: 296
Is there rebar in the existing slab?
Old 08-08-2015, 09:31 AM   #4
Rewards Points: 14
Fiber mesh
Old 08-08-2015, 09:38 AM   #5
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
680.42 outdoor installations. A spa or hot tub installed
outdoors shall comply with the provisions of parts i and ii
of this article, except as permitted in 680.42(a) and (b),
that would otherwise apply to pools installed outdoors.
680.42(b)
bonding. Bonding by metal-to-metal mounting on a
common frame or base shall be permitted. The metal bands
or hoops used to secure wooden staves shall not be required
to be bonded as required in 680.26.
Equipotential bonding of perimeter surfaces in accordance
with 680.26(b)(2) shall not be required to be provided
for spas and hot tubs where all of the following
conditions apply:
(1) the spa or hot tub shall be listed as a self-contained spa
for aboveground use.
(2) the spa or hot tub shall not be identified as suitable
only for indoor use.
(3) the installation shall be in accordance with the manufacturer's
instructions and sha11 be located on or above
grade.
(4) the top rim of the spa or hot tub shall be at least
710 mm (28 in.) above all perimeter surfaces that are
within 760 mm (30 in.), measured horizontally from
the spa or hot tub. The height of nonconductive external
steps for entry to or exit from the self-contained spa
shall not be used to reduce or increase this rim height
measurement.
Old 08-08-2015, 10:38 AM   #6
Rewards Points: 14
Wildleg thank you very much.. I appreciate it.
Old 08-09-2015, 09:17 AM   #7
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,608
Unfortunately, CT is on the 2011 NEC and technically 680.26(b)(2) applies.
2011 NEC
680.42 Outdoor Installations. A spa or hot tub installed outdoors
shall comply with the provisions of Parts I and II of this
article, except as permitted in 680.42(A) and (B), that would
(B) Bonding. Bonding by metal-to-metal mounting on a
common frame or base shall be permitted. The metal bands or
hoops used to secure wooden staves shall not be required to be
(C) Interior Wiring to Outdoor Installations.......
Fortunately, most inspectors in this state, well let's just say, ***** **** ****, and there wont be any issue.
Unfortunately, you may run across a ******** that wants it done exactly per the 2011's requirements.
Fortunately, in most cases the state will grant permission to use the verbiage of the 2014 in lieu of the 2011 as it is an updated document.
Were you born retaƕded or did you pick that up on your own?
Old 08-09-2015, 12:51 PM   #8
Rewards Points: 123
Were there not 2011 TIA's about this subject?
brichter is offline   Reply With Quote
Old 08-09-2015, 12:54 PM   #9
Rewards Points: 14
Tia? What's that.. Sorry
Old 08-09-2015, 12:55 PM   #10
Rewards Points: 14
He has a deck he will eventually bring up to the spa...
Old 08-09-2015, 12:57 PM   #11
Rewards Points: 1,250
Yes
http://www.iaeisj.org/sitebuildercon...le_680_tia.pdf
Old 08-09-2015, 01:09 PM   #12
Rewards Points: 14
Yea I guess I gotta read through all the amendments
Old 08-09-2015, 01:27 PM   #13
Flex Bits & Blindfolds
Mshow1323's Avatar
Rewards Points: 2,210
Is the spa going to be recessed into the deck? Because if it is you won't meet the criteria of 680.26(b)(2). Which means you need to saw cut the slab and sink your EPB.
conditions apply:
grade.
the spa or hot tub.
measurement.
NOT MY REAL NAME!
Mshow1323 is offline   Reply With Quote
Old 08-09-2015, 01:32 PM   #14
Rewards Points: 14
I see what you are saying, kinda dumb code verbiage because deck is wood, there should be no need for equipotential bond. But you brought up a good point Thanks
Equipotential bonding above ground pools watts77 Residential Electrical Forum 0 05-30-2012 11:53 PM
Retro Equipotential Bonding RePhase277 General Electrical Discussion 19 03-08-2012 09:32 PM
Spa Tub - Equipotential Grid Jupe Blue General Electrical Discussion 13 01-07-2012 02:59 PM
equipotential bonding AMPED General Electrical Discussion 6 05-30-2011 04:51 PM
equipotential bonding grid (pool) njspark83 General Electrical Discussion 17 05-12-2010 04:25 PM
