Explanation of Main Panel Circuitry/Design - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 07:43 PM   #1
Rewards Points: 100
Default Explanation of Main Panel Circuitry/Design
As the title states I am creating this post because I would like to better understand how a panel I came across is designed.
The panel is a Square D QO Load center, Model# QO-16-408, Series: A-10.
I tried looking up information on the panel via google but couldn't find any relevant search results.
Based on what I see when I remove the panel cover it looks like the two hots(single phase 120v/240v) are connected to a double pole breaker. It isn't a typical setup with a main breaker above the bus bar and two hots connected to the lugs above it.
The two hot service conductors are 4 AWG, there is another 4 AWG that is tightened to a lug above the bus bar A and goes behind some breakers and I can't see the other end. There also is a sticker inside the panel stating it doesn't use a neutral, which seems odd because it has a neutral bar with the service neutral in it along with all the branch circuits neutrals as well.
So based on my limited description does anyone have an idea of what exactly is the reasoning behind this type of panel design and how it works?
I mean I can understand that the two hots going to the double pole breaker basically function as a Main Breaker. But I don't understand why there is another 4 AWG which almost seems like its a jumper between the two bus bars. I also don't understand what the previously mentioned sticker about no neutral is referring to. I will take a picture later if need be.
[IMG]"http://s690.photobucket.com/user/badreligion9265/media/IMG_20150217_1851387731_zpsf7dcbb80.jpg.html[/IMG]
badreligion9265 is offline   Reply With Quote
Old 02-17-2015, 07:47 PM   #2
Rewards Points: 1,806
A pic would be good. The wire in the middle is the neutral that runs behind the buss itself. The others are hot conductors. If the panel states 240/120 then it has a neutral.
Old 02-17-2015, 07:57 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Yeah pic please
Old 02-17-2015, 08:09 PM   #4
Rewards Points: 100
[IMG][/IMG]
From the pics you can see that there are wires in the main lugs that go behind the breakers. And the two Hot service entrance conductors go to a double pole breaker. I want to know what those other 4 gauge wires are going to and why the panel is set up like this.
Old 02-17-2015, 08:12 PM   #5
corn-fused
papaotis's Avatar
Rewards Points: 620
maybe those wires from the lugs are feeding another panel?
Old 02-17-2015, 08:13 PM   #6
Rewards Points: 100
There is no other panel, this is from my house, so I'm pretty certain there is no hidden sub-panel. It looks like they either go directly to the bus-bar or to a breaker(s). It just seems like a weird design either way.
Old 02-17-2015, 08:17 PM   #7
Retired Account
Rewards Points: 14,650
It looks like someone used a SqD MLO as a feed through panel
Old 02-17-2015, 08:23 PM   #8
HTTR
Jack Legg's Avatar
Rewards Points: 804
its a split buss panel. the wiring diagram is right on that label
Jack Legg is offline   Reply With Quote
The Following User Says Thank You to Jack Legg For This Useful Post:
Dennis Alwon (02-17-2015)
Old 02-17-2015, 08:26 PM   #9
HTTR
Jack Legg's Avatar
Rewards Points: 804
oh, I see what happened...someone is a meathead
Old 02-17-2015, 08:29 PM   #10
Rewards Points: 100
Can you guys elaborate a little more please, I don't understand what Chicken or Jack is saying really.
Old 02-17-2015, 08:33 PM   #11
Retired Account
Jack thinks it's a split bus, good eyes if so
I thought FPE ran than market into the ground...>>>
badreligion9265 (02-17-2015)
Old 02-17-2015, 08:40 PM   #12
HTTR
Jack Legg's Avatar
Rewards Points: 804
see how the wires on the lugs are all jacked up? they used to go on that 2 pole 60. That's the lighting main breaker, it feeds the bottom half of the panel
look at that label on the side under the yellow wirenut
Old 02-17-2015, 08:57 PM   #13
Rewards Points: 100
Okay so I think I get it now. It used to be so the SE cable fed the top two buses and then that double pole fed the bottom bus.
But now it is wired so that the 60 AMP double pole truly acts as a Main breaker because the SE cable's ungrounded conductors are connected to it, feeding the top bus which then has jumper wires connected to the top bus feeding the bottom bus. But those jumper wires are downstream from the 60 Amp breaker so if it is off the bottom bus is off as well.
Does that sound right?
Old 02-17-2015, 09:02 PM   #14
Definitely a split buss. You are allowed 6 handles to disconnect the building. The top of the panel has room for 6 dp one of which feeds the bottom half of the panel
Old 02-17-2015, 09:12 PM   #15
Rewards Points: 100
Thanks for the pictures and explanations guys! So based off the confirmation of this being a split-bus panel is what I wrote in my last post correct about the 60Amp double-pole now acting as a main by cutting power to both top and bottom buses?
Old 02-17-2015, 09:19 PM   #16
HTTR
Jack Legg's Avatar
Rewards Points: 804
yep, and you got two neutrals under one screw in a couple spots, just tear it all out and start over
chicken steve (02-17-2015)
Old 02-17-2015, 09:19 PM   #17
Retired Account
It looks that way, but it wasn't designed for that. Those top lugs should be fed
Someone 'effed it up ....
Old 02-17-2015, 09:20 PM   #18
Retired Account
Jack, you win the kewpie doll in this thread.....~CS~
Old 02-17-2015, 09:23 PM   #19
HTTR
Jack Legg's Avatar
Rewards Points: 804
no one really understands what Chicken is saying
Old 02-17-2015, 09:28 PM   #20
Rewards Points: 100
lol well his picture certainly helped alot of what I didn't understand.
Ya I don't understand why this panel wasn't replaced because during hurricane Sandy the weather-head was knocked off the house and that along with the meter-pan got replaced. Would seem like a good time to replace the panel as well but for whatever reason it wasn't. Landlord supplied the electrician so I guess probably just a money factor.
Panel Grounding : Duplex Main + 2 Main-Subs onilozay NEC Code Forum 6 10-16-2014 11:08 PM
main lug panel next to main breaker panel Paul S. General Electrical Discussion 8 01-13-2014 11:18 PM
Main Panel Design noxcuses NEC Code Forum 4 08-01-2012 04:22 PM
Old style 200 amp panel explanation newspark80 General Electrical Discussion 9 10-06-2011 08:08 PM
Main breaker panel cheaper than main lug Shockdoc General Electrical Discussion 5 07-19-2011 09:51 PM
